New to forum, new CJ 6 owner - JeepForum.com
 3Likes
  • 1 Post By popascj7
  • 2 Post By BagusJeep
post #1 of 5 Old 10-09-2019, 02:40 PM Thread Starter
Jethro294
Have a CJ-6 that I acquired, its a CJ-6,According to the Serial number it’s the last one in the 1960 year range according to the Kaiser catalog. I was told it’s a 1961 have to look at the title to see what it says. Was told it ran 20 years ago when parked in a barn in TN. Well after a little work the motor I found the motor is locked up, bottom end looks good but looking through the spark plug holes it looks pretty gummed up! Were the 4 cylinder engines prone to head or head gasket issues? Trying to just do what I need to do to get it Road worthy. Any advice would be appreciated. 647805ea-37b7-4801-a73c-5b672dfe7f36_1570649475553.jpgClick image for larger version
DE7935E3-1368-4837-B73F-C244DC3124D8_1570649855822.jpg   ED6C2BED-ECE7-4FA4-B9D9-F0A605971158_1570649898644.jpg
Jethro294 is offline
post #2 of 5 Old 10-10-2019, 10:59 PM
Trapshooter
Trapshooter's Avatar
Welcome to the JeepForum. There is a ton of info here. Your CJ6 is quite unique. I'm afraid I do not have any answers for you on the engine as my experience is with the V8's and I-6.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 5 Old 10-11-2019, 12:10 AM
popascj7
1976 CJ7
The first thing I noticed is that your vehicle ID plate is screwed on instead of riveted. I'm not sure if all used rivets but all that I have looked at were.
The first thing I would do for the engine is to drain the oil and leave the drain plug out. Put a clean drain pan under it and fill all the cylinders with your choice of magic rust remover and let it sit for several days to try and break the piston rings loose before trying to turn the engine over.
The purpose of the clean drain pan is to see what comes through the cylinders. Some times it doesn't take much to break the pistons loose and some times it doesn't matter what you do you'll wind up with a complete rebuild, broken rings and scored cylinders.
Welcome to the forum and good luck with your project.
OrangeCJ-5 likes this.
popascj7 is online now
post #4 of 5 Old 10-11-2019, 01:06 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The F head Hurricane is a very easy engine to work on, not hugely powerful. It has great parts support and can be very cheap to rebuild. the head and valves were an improvement on the Go Devil engine with the inlet valve moved to the head but many parts are common. The heads are not particularly problemmatic, just the usual blown gaskets and leaks.
Onc you have the piston rings well soaked i find rocking it in 2nd gear is useful, if the brakes are not frozen of course. The gentle rocking is easier than trying to force it on the crank pulley. Sometimes they will give and everything is fine.
Hurricane4 and pedal2themetai like this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 5 Old 10-12-2019, 07:53 AM
Hurricane4
1979 CJ5
Try KROIL in the cylinders to help break engine free.
http://www.kanolabs.com/
http://www.kanolabs.com/penLub.html#anchor173855
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
