New CJ7 - Been sitting for 8 years... - Page 4 - JeepForum.com
 5Likes
post #46 of 54 Old 11-03-2019, 02:40 PM Thread Starter
danno_CJ7
1983 CJ7
Originally Posted by Matt1981CJ7 View Post
Hi Danno,
I could be seeing things, but it appears the balled end of your t-case shifter is broken off.
Yup, I think you got it. Thanks for that diagram. Now to figure out how to replace the t-case shifter...
danno_CJ7 is offline
post #47 of 54 Old 11-03-2019, 03:05 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It's pretty easy. Just remove the shifter shaft nut and the 2 link pins. Then push the control link forward and slide the shifter off the shaft. Don't lose the cotter pins for the link pins.
Good luck,
Matt
Matt1981CJ7 is offline
post #48 of 54 Old 11-03-2019, 03:22 PM Thread Starter
danno_CJ7
1983 CJ7
It's pretty easy. Just remove the shifter shaft nut and the 2 link pins. Then push the control link forward and slide the shifter off the shaft. Don't loose the cotter pins for the link pins.
Good luck,
Matt
Thanks - been googling for the past hour or so. I was thinking it may be worth it to twin stick it. I don't think the install is that much more complicated; however, getting the new boot to fit appears to be a problem in some cases. I don't think I need to take the transfer case out for any of this (twin stick or no)...?
Thanks a bunch,
Dan
post #49 of 54 Old 11-03-2019, 04:08 PM
Matt1981CJ7
1981 CJ7
No, you won't have to remove the t-case either route you go. Twin sticks will probably require cutting the tub, and of course a different boot, however.
Unless you plan on some hard-core wheeling, twin sticks probably aren't worth the effort.
Matt
JoonHoss likes this.
post #50 of 54 Old 11-04-2019, 05:29 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Good luck,
Matt
I don't know about the '83 t-case shifter but on my 1980 t-case, the shifter shaft actually screwed into the shifter. The flat on the shifter shaft is there to put a wrench on it to unscrew the shaft.
Oh, and take the nut off first.
The shifter on my 1984 t-case, the shifter shaft did not screw into the shifter.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #51 of 54 Old 11-04-2019, 07:28 AM
Matt1981CJ7
1981 CJ7
It must have changed in '81, John. My t-case shifter does not screw into the shaft.
Matt
John Strenk likes this.
post #52 of 54 Old 11-11-2019, 06:49 AM Thread Starter
danno_CJ7
1983 CJ7
So I ordered a nice looking twin stick replacement, and finally got around to playing with this. What I found was surprising - and worked out fine:
1. The bottom of the original shifter did not shear off - something had gotten jostled, and the shifter had become disconnected from the shift control link. I was able to get it back together, and it works.
2. I assume when the transmission was replaced, it pinned in the shifter shaft. Even with the nut removed, the shifter shaft can't be removed, it hits either the transmission or the body. To remove it I'd have to drop the T-case, or cut it. Thus, I can't swap in the twin shifter without a bit more effort.
3. Probably also when the transmission was replaced, some of the parts for the t-case shifting mechanism appear to have been removed or left out, including all the washers and pins that hold in shifter shaft - and also, maybe the back of the shift control link (circled in blue, not entirely sure, didn't get that far before I put it back together). Again, the fact that the shifter shaft CAN'T be removed, probably makes it not a huge deal that the washers and pins holding it in place are missing. However, I'm willing to bet the play in the shaft is the culprit for shifter popping out of the control link. I'm happy to leave the shifter and shaft in place, but putting in some washers and spacers and a pin to secure the shaft might be smart.
Thanks!
D
post #53 of 54 Old 11-11-2019, 07:56 AM
Hoover7
Hoover7's Avatar
D
Danno, after removing the shifter shaft nut, you can use a pry bar (or a mallet if you have room) to slide the shifter shaft through the bushings towards the transmission- that will give you the clearance to remove the shift lever with out too much effort. Just make certain the shaft is lubricated and clean so it will slide through those plastic bushings. You probably won't have to move it far to give you the needed clearance.
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is online now
post #54 of 54 Old 11-11-2019, 11:11 AM Thread Starter
danno_CJ7
1983 CJ7
Hoov
Thanks, Hoov. Actually, I was able to slide the shaft far enough to remove the shift lever - you're exactly right. However, if I ever wanted to put in the twin shifter, I'd need to drop the T-case, I think.
D
carburetor , cj7 , jeep
