New CJ7 - Been sitting for 8 years... - JeepForum.com
 5Likes
post #1 of 54 Old 09-24-2019, 09:59 AM Thread Starter
danno_CJ7
1983 CJ7
Cj New CJ7 - Been sitting for 8 years...
Hello All,
I am new to this forum, and new to CJ's. And, new to tinkering with an inoperable vehicle (aka, a noob).
A friend sold me a 1983 CJ7 that has been sitting in her garage for about 8 years for $800. The jeep was apparently running fine before storage. Before garaging, it had a used Chevy v6 and transmission put in. I think the carburetor was also replaced at that time. Rust is moderate - just surface.
I've already gotten some good advice on what to do first (listed below), but thought I'd start this thread to document the process of getting the CJ started. I will need all the help I can get.
1. Take out the plugs, squirt in some oil, and turn the engine over to make sure it's not seized.
2. Drain (and flush?) the gas.
3. Drain and change oil/filter.
4. Change fuel filters.
5. Fill fluids - radiator.
6. Spray in carb cleaner? Take carb apart?
7. Put in new battery.
8. Fuel pump working? (Carb squiring?)
9. See if it will start.
Open to any and all thoughts and suggestions. I've already learned a lot from this forum's older posts.
Thanks a bunch!
Dan
IMG_2852_sm.jpg   IMG_2851.jpg   IMG_2854_sm.jpg   IMG_2855_sm.jpg   IMG_2856_sm.jpg
danno_CJ7 is offline
post #2 of 54 Old 09-24-2019, 10:20 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would first see if you can turn the engine over by hand just to be sure that the rings haven't rusted to the cylinder wall.
Take all the plugs out so you are not fighting compresion. Squirt some penetrating oil down each spark plug hole.
Then take a breaker bar with a socket on it and put it on the end of the crankshaft and see if you can turn it over.
Make sure it's in neutral before you start turning it over.
The carb you will probably have to take it apart just to inspect it to see if any corrosion started inside.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 54 Old 09-24-2019, 10:22 AM
John Strenk
1976 CJ5
Originally Posted by danno_CJ7 View Post
Thanks a bunch. Is there an additive I should add to oil that will breakup any old crud?
PB Blaster would be good. Let it sit a day or so.
post #4 of 54 Old 09-24-2019, 10:40 AM
John Strenk
1976 CJ5
Moved comments from other posts to give OP his own thread.
post #5 of 54 Old 09-25-2019, 08:30 AM
bob4703
1974 CJ5
Don't think that is a Chevy V6. It kinda looks like a 258, but I can't tell for sure because I'm not used to looking at one with all the unnecessary trash hanging on it!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #6 of 54 Old 09-25-2019, 08:34 AM Thread Starter
danno_CJ7
1983 CJ7
Thanks - I actually have no idea how to tell, and don't have any documentation. I'm going to start digging around this weekend.
post #7 of 54 Old 09-25-2019, 08:43 AM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
A V6 would have three cylinders/spark plugs on each side of the engine. The stock Jeep engine of that time would be a 4.2 liter/258 cu. in./ 6 cyl. All the cylinders are one side.
The engine pictured is a straight 6.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #8 of 54 Old 09-25-2019, 08:58 AM
Hoover7
Hoover7's Avatar
Yes, agree. This engine appears to be the stock straight six, most likely a 258 based on the year model. Great find at a great price. Looks to be in really nice shape!
Nice hibiscus flower above the spare tire stop.
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #9 of 54 Old 09-25-2019, 03:42 PM
only in a jeep cj
Don’t try to crank it until you check for water in the components.
When they sit for years and years, the temperature changes (even in a garage) can sweat the metal casings and engine block. That condensation will run down the inside walls and go to the bottom as water is heavier than oil. So what appears as clean oil when you check it before you crank it, will turn to chocolate milk fast as you get it running. Then it’s all through the engine, transmission, whatever.
Oil doesn’t go bad with time, it goes bad with use. Old oil can still be fine.
Loosen the drain plugs and keep them pressed into the hole as they are almost about to come out. If there is water, it will come out first, then the oil. I picked up a jeep that had been sitting in a barn for five years, and I drained almost a full liter of clean water from the pan before I started it. I’m glad I did because it’s been a great running motor to this day.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #10 of 54 Old 09-26-2019, 09:13 AM Thread Starter
danno_CJ7
1983 CJ7
Hoover
Ha! My wife has been relentlessly pointing out that sticker, as well. I have since gotten in touch with my friend, and she does think it's a Jeep straight six - but wasn't the one this Jeep came off the line with.
post #11 of 54 Old 09-26-2019, 09:24 AM Thread Starter
danno_CJ7
1983 CJ7
Originally Posted by only in a jeep cj View Post
Donít try to crank it until you check for water in the components.
When they sit for years and years, the temperature changes (even in a garage) can sweat the metal casings and engine block. That condensation will run down the inside walls and go to the bottom as water is heavier than oil. So what appears as clean oil when you check it before you crank it, will turn to chocolate milk fast as you get it running. Then itís all through the engine, transmission, whatever.
Oil doesnít go bad with time, it goes bad with use. Old oil can still be fine.
Loosen the drain plugs and keep them pressed into the hole as they are almost about to come out. If there is water, it will come out first, then the oil. I picked up a jeep that had been sitting in a barn for five years, and I drained almost a full liter of clean water from the pan before I started it. Iím glad I did because itís been a great running motor to this day.
This is excellent advice. Thank you. Before cranking the engine I will drain any water from the pan, drain the fuel (just to be safe), pop off the plugs and spray in some penetrating oil.
post #12 of 54 Old 09-26-2019, 12:31 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
What a ridiculously incredible score!
I had a red '83 CJ7 in Sebring red as well, I paid 3 times that amount 10 years ago, it was in worse shape (visually) than yours (Though it was running), and that was a helluva deal then.
A little bit of sweat equity and elbow grease later...
You did great, that was/is a steal of a price in that condition,
You are absolutely on the correct tract as far as getting it fired up.
Good luck!
Hoss
John Strenk likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #13 of 54 Old 09-26-2019, 05:15 PM
Axhammer
Axhammer's Avatar
Nice score! Thatís my favorite Jeep of all time, a 1980ís Sebring Red CJ-7 with steel doors. It even has a plastic valve cover. My 1986 Sebring Red CJ-7 had a plastic valve cover, steel doors and a black hardtop when I bought it new. My current 1985 CJ-7 is Sebring Red, with steel doors and a white hardtop, but itís still topless for the summer.
I donít know how it was stored for those eight years, but hopefully after refreshing the fluids you can get it fired up and start enjoying it. The best part about owning a CJ-7, is driving it, and I prefer driving mine with the top off in the summer.
Congrats! And welcome to the CJ forum.
This is what I had back in the eighties.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #14 of 54 Old 09-27-2019, 03:51 PM
aillon
aillon's Avatar
That is an original 258 engine just the valve cover has been replaced. It looks exactly like mine. Wow 800$. It looks like those are original seats? I would say those are worth 1000$ alone. I do not see any rust, and the wagon wheels look pristine. How many miles on it? I bet less than 60k?
That seller must be pretty well off, because she walked away from 7-10k depending on rust.
aillon is offline
post #15 of 54 Old 09-28-2019, 10:36 AM Thread Starter
danno_CJ7
1983 CJ7
Truth be told, I had to spend a pretty penny to ship it... But yes, a good deal! There's 75k miles on it.
carburetor , cj7 , jeep
