New CJ5 Project - Page 2 - JeepForum.com
 28Likes
post #16 of 46 Old 08-17-2020, 07:31 AM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
I like the color,,,
Rustoleum Kubota Orange implement paint.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is online now
post #17 of 46 Old 08-17-2020, 08:24 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Tcase out. Both outputs have a pretty good amount of play so may go ahead and rebuild it. Front drive shaft is also shot. Slipyoke has a good half inch of play in all directions.
Sent from my SM-G892A using Tapatalk
downs is online now
post #18 of 46 Old 08-18-2020, 06:14 AM
Fldvr
Fldvr's Avatar
1974 CJ5
Take good pictures of the shims and spacers when you take it apart. Mine had some hacks done over the last 40 years or so that made proper reassembly a lot more work and extra money than it should of been.
Sent from my iPhone using Tapatalk
downs likes this.
Fldvr is offline
post #19 of 46 Old 08-20-2020, 09:07 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Trans and clutch out. Going to pickup a cherry picker tomorrow to pull the engine to get to the frame better.
downs is online now
post #20 of 46 Old 08-21-2020, 11:34 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Engine out. Frame cleanup and spray tomorrow. Also dug up part of the backyard to find a water leak.
downs is online now
post #21 of 46 Old 08-22-2020, 01:54 PM
Axhammer
Axhammer's Avatar
Originally Posted by downs View Post
Got the tub off and power washed along with the frame. We though the frame was full of mud. Was actually full of dirt dauber nests. Those things are quite resistant to even the power washer but I think i got the frame blasted out. Got the caked on oil blasted off as well. Going to roll the frame back into the garage today after everything dries out and going to start pulling the t-case and transmission later this week. Before I do that I'm going to hook the engine back up to the battery and do a compression test. A few things need to be sealed up on the engine as well. Still a ways to go but making steady progress.
Some more janky wiring by one of the previous owners. Pretty sure it was a kill switch of some kind. It was screwed to the bottom of the steering column.
The master cylinder is so full of gunk I'm not even going to try to salvage it. Not for the 30 or 40 dollars a new one costs.
Throwing down some paint as well. Been doing it one piece at a time. Sanding a body piece one evening and spraying it the next morning before I leave for work. In another week or so I'll wet sand each piece and bust out the polisher.
Downs,
You have a lot of energy...good for you. I was reading the thread and saw the picture of the front grill during tear-down. I was thinking what a great picture. The CJ grill is a beautiful thing. Then a few posts down I see you have already re-painted the grill. Damn, you work fast, and it looks good too. Good luck with the resto.
Ax
downs likes this.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #22 of 46 Old 08-22-2020, 06:25 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Originally Posted by Axhammer View Post
Downs,
Ax
I dont feel like i have a lot of energy. Im afraid if I slowdown I wont finish lol.
downs is online now
post #23 of 46 Old 08-23-2020, 07:29 AM
braindamage
braindamage's Avatar
1978 CJ5
Ax[/quote]I dont feel like i have a lot of energy. Im afraid if I slowdown I wont finish lol.
Sent from my SM-G892A using Tapatalk[/QUOTE]
True that. There’s a lot to be said for inertia! Pick some event in the future as a goal to keep you on track.
braindamage is offline
post #24 of 46 Old 08-28-2020, 07:43 AM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Tore the CJ carb down this morning. Cleaned up the main body and have the rest of the parts standing by for carb dip when i get home today. Goal this evening is to have that put back together and get started on the transmission.
downs is online now
post #25 of 46 Old 08-29-2020, 12:32 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Transmission torn down, case cleaned up and painted. Going to have to order at least a new reverse idler gear i think. Maybe a first gear syncro. Not sure what this originally looked like. Going to run it by thr CJ5 forum and see what they say.
downs is online now
post #26 of 46 Old 08-31-2020, 05:38 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I would run both of those gears without hesitation.
cjoffroad and downs like this.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is online now
post #27 of 46 Old 08-31-2020, 06:19 AM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Im going to use that syncro but the reverse idler is getting replaced just waiting on the part.
downs is online now
post #28 of 46 Old 08-31-2020, 09:46 PM
jeepdaddy2000
1971 CJ5
If it were me, I would reverse that and replace the syncro and run the gear.
Chesty Puller
post #29 of 46 Old 09-13-2020, 03:46 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Too late. Comparing the new reverse idler with the old one about a 1/3 of each of the straight cut teeth were worn off. I did replace all the syncro plates and springs with new pieces while I was in there which seemed to tighten up the 1st reverse syncro compared to when I took it apart.
John Strenk and turbogus like this.
downs is online now
post #30 of 46 Old 09-16-2020, 12:34 PM Thread Starter
downs
downs's Avatar
1995 XJ Cherokee
Tore the CJ transfer case down (Dana20) had to order a few parts that wont be here for a week or two. Ill start cleaning it up today but it was a big greaseball when i pulled it out.
downs is online now
