New 1980 258 harmonic balancer - JeepForum.com
 1Likes
  • 1 Post By Horatio
post #1 of 6 Old 01-07-2021, 05:21 PM Thread Starter
Horatio
1980 CJ7
Learned a hard lesson on how not to pull a harmonic balancer from my 1980 258. After screwing up the original I ordered a new replacement from Dayco. The new unit does not have the same cutout as the original. I'm assuming the original's cutout was for balancing. Does the new one need to be balanced? OK to bolt and go?
Horatio is offline
post #2 of 6 Old 01-07-2021, 05:32 PM
greganthonyb
Attachment 3958915
From Dayco:
"Dayco Harmonic Balancer
Made to strict requirements for proper fit and performance
Developed with exceptional-quality materials and Spheroidal Graphite iron casting
Features inserted and pressure-bonded rubber for maximum strength and longevit
-Fit and Quality Guaranteed!
Harmonic balancers*are misnamed. They*do*not*balance*an engine, rather they absorb and remove unwanted vibration due to torsional twisting of the crankshaft. ... Dampeners are like torsional shock absorbers used to dampen torsional twist and vibration in an engine."
I'd say you're good to go!
greganthonyb is offline
post #3 of 6 Old 01-07-2021, 05:41 PM Thread Starter
Horatio
1980 CJ7
Originally Posted by greganthonyb View Post
From Dayco:
Good to know. Thanks for the help!
greganthonyb likes this.
Horatio is offline
post #4 of 6 Old 01-07-2021, 06:26 PM
whollsee
1982 CJ7
Yep, if it is the Dayco Powerbond HB1440N it is good to go. That is what I have installed. Great quality and made right here in Australia not too far from me.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #5 of 6 Old 01-07-2021, 07:19 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Sometimes this is a point in time whereas you might replace your timing chain (or timing set) or the gasket on your timing chain cover (for the harmonic balance)
It kinda all depends on your plans and use of your Jeep. There are better options for the timing set
Maybe a light hazing of anti-seize on the crank.
Find a bolt with the same thread but longer and a nut to go with it.
Run the nut up the temporary bolt (tool) and stick on the original washer.
Pick up the balancer and smear a little oil on the surface that will run in the rubber seal of the timing chain cover
Hover the balancer in place and run your "Tool" Bolt assembly into the crank. Run it in a lot--you want lots of thread engagement when you start pulling!
Now run the nut in and washer down and pull the balancer on (at least halfway in place)
Remove "Tool Bolt" and install it as it was originally----That is : Washer and original bolt.
Pull it fully into place and torque it to 80 ft.lbs.
TOOL BOLT??????
This will Start the balancer onto the crank.
It will prevent you from using the original bolt, which may BARELY catch the female threads----WHOOSH! You just ruined the starter threads of either end or both!
I've witnessed the original bolt not quite grabbing and the owner "Beating" the balancer onto the shaft.
This is the reason for the long tool bolt!!!
----JEEPFELLER
JEEPFELLER is offline
post #6 of 6 Old 01-08-2021, 04:17 PM Thread Starter
Horatio
1980 CJ7
TOOL BOLT??????
----JEEPFELLER
Great advice. Thank you
Horatio is offline
