Needed: 4.2L Air Cleaner Bracket or different style Air Cleaner Housing - Page 5 - JeepForum.com
 3Likes
post #61 of 84 Old 12-06-2013, 01:28 PM
capt205
1983 CJ7
For anyone interested...I was able to order the 2 gasket type things that sit on top of the offset mount, and under the cleaner housing, from www.factorychryslerparts.com
1 SLIDER , SPACER. 1982-86. J3241389 $0.68
1 GASKET, GASKET, Air Cleaner Mounting to Bracket. J3234485 $9.12
They have a nice selection of the hard to find small bits and pieces...such as the pieces mentioned, the valve cover mount, stud, sliding nut, ect
capt205 is offline
post #62 of 84 Old 12-06-2013, 03:25 PM
lukenicwalker
lukenicwalker's Avatar
1982 CJ7
Nice! Thanks for the update!
ldw
lukenicwalker is offline
post #63 of 84 Old 12-06-2013, 03:45 PM
JayCO
1982 CJ7
great stuff! thanks for posting.
JayCO is offline
post #64 of 84 Old 12-07-2013, 11:18 PM Thread Starter
SouthernGypsy
SouthernGypsy's Avatar
Awesome!
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
post #65 of 84 Old 07-21-2015, 11:14 PM
mvd1968
1977 CJ7
Sorry to bump this thread but Looking for this domed shaped gasket too. Anyone made one at home and can share some pics or info.
mvd1968 is offline
post #66 of 84 Old 04-28-2020, 08:19 AM
JeepdaddyRC
1983 CJ5
Reviving an old thread.
1. Does anyone have a source for the plastic domed shaped spacer that the teardrop style OEM air cleaner sits on (used for power brakes)?
2. Any examples or suggestions for a home made version?
JeepdaddyRC is offline
post #67 of 84 Old 04-28-2020, 09:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
If someone gave me dimensions, I could probably print some up.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #68 of 84 Old 04-28-2020, 04:29 PM
keith460
keith460's Avatar
Hard part to find to say the least.
I can offer to take measurements of mine and post them and maybe someone with a 3D plastic printer could make it.
Sent from my iPhone using Tapatalk
1984 CJ-7 Renegade
keith460 is offline
post #69 of 84 Old 04-29-2020, 07:45 AM
JeepdaddyRC
1983 CJ5
That would be terrific Keith. It is an elusive part and I haven't figured out how to make an "almost OEM" version.
post #70 of 84 Old 04-29-2020, 05:53 PM
keith460
keith460's Avatar
Hope these pictures help.
Air Cleaner Plastic Thingy (3).jpg   Air Cleaner Plastic Thingy (4).jpg   Air Cleaner Plastic Thingy (5).jpg   Air Cleaner Plastic Thingy (2).jpg   Air Cleaner Plastic Thingy (6).jpg
John Strenk and cjoffroad like this.
1984 CJ-7 Renegade
keith460 is offline
post #71 of 84 Old 04-30-2020, 04:34 AM
John Strenk
1976 CJ5
Thanks Keith, do you know the thickness at the edges.
post #72 of 84 Old 05-01-2020, 04:06 AM
keith460
keith460's Avatar
Averages out to 13/64".
1984 CJ-7 Renegade
keith460 is offline
post #73 of 84 Old 05-14-2020, 04:46 PM
DaveMueller
DaveMueller's Avatar
1976 CJ5
John, what material would you use that would stand up to an engine compartment environment?
I just scored the OEM air cleaner (for under $5000!) and am looking for the hardware. I have the bracket that goes on the rocker cover.
"You came here in that thing? You're braver than I thought."
DaveMueller is offline
post #74 of 84 Old 05-18-2020, 08:37 PM
devildog80
devildog80's Avatar
1981 CJ5
As we speak of the OEM air cleaner, I am asking what carb was OEM for 4.2 in 1981, No brake boost, 4 spd manual? Bought '81 CJ5 and has a Weber carb with one of those little crap filters and chrome clips to hold it on. If I can find a cold air system to fit it, carb not too bad and will rebuild unless I can replace Weber with more of an OEM type to have complete system right.
Oh, and no emissions stuff possible so would cap/plug any of that as charcoal canister not connected from PO x 1-2-4 (?) no telling for sure, just working with what I have now!
devildog80 is offline
post #75 of 84 Old 05-18-2020, 09:07 PM
DaveMueller
1976 CJ5
I believe either a Carter BBD or an MC2100/MC2150 would have been stock in '81. Both are in the later shop manual but I never paid attention to which one was used based on engine and options.
