Need help swapping TO 2.72 gears - JeepForum.com
 1Likes
  • 1 Post By jeepdaddy2000
post #1 of 11 Old 04-07-2018, 01:56 PM Thread Starter
nickgentleman
I have stock axles front and rear with 3.31 gears. After my cummins swap, Iíd like to swap down to 2.72 gears. I think Iíll need a new carrier in the amc 20 to work with the 2.72 gears, but Iím not sure. Will I be able to swap the ring and pinions for both axles? Or will I need new carriers as well for both or just one?
1984 CJ7 Laredo - "Jenny"
Cummins 4BT
T19
nickgentleman is offline
post #2 of 11 Old 04-07-2018, 02:29 PM
jeepwhore
jeepwhore's Avatar
Like was mentioned in your other post, you'll only need a new carrier for the rear. But you can probably find a matching set of 2.72 axles for less than the cost of new gears and install kits.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 11 Old 04-08-2018, 02:08 PM Thread Starter
nickgentleman
Good point, Iím hoping I can find someone that doesnít need their old gears/carrier that will ship it to me for cheap. On a college student budget If you know anyone or are anyone PM me!
Cummins 4BT
T19
post #4 of 11 Old 04-08-2018, 03:23 PM
only in a jeep cj
Too bad your not closer. I have an extra set of widetrack 272s that we could just trade. Why go to all the trouble to set up gears when swapping the housing when it’s out is easier.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 11 Old 04-08-2018, 05:26 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
There you go. only a 12 hour round trip drive and your good. I once drove from Norfolk to Cincinnati for a set of axles
cjoffroad is offline
post #6 of 11 Old 04-08-2018, 07:42 PM
jp360cj
1977 CJ7
As mentioned, the cheapest and easiest way will be to find someone to swap complete axles
Sent from my iPhone using Tapatalk
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #7 of 11 Old 04-08-2018, 10:27 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Just out of curiosity:
What tire size are you running?
What RPM range are you looking at @60MPH?
What RPM's are you running now?
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #8 of 11 Old 04-09-2018, 04:13 AM Thread Starter
nickgentleman
Iím on 33s, maxing out speed at 55 (somewhere right around 2000 rpm), and not sure whatís being asked by the third question
Cummins 4BT
T19
post #9 of 11 Old 04-09-2018, 04:21 AM Thread Starter
nickgentleman
Originally Posted by only in a jeep cj View Post
Too bad your not closer. I have an extra set of widetrack 272s that we could just trade. Why go to all the trouble to set up gears when swapping the housing when itís out is easier.
Iíll tell ya what, if you have a garage we could swap them in, I might just take you up on that. I have friends at Florida State (Tallahassee) I could stop and stay with, and youíd only be about 3.5 hours from there.
Cummins 4BT
T19
post #10 of 11 Old 04-09-2018, 05:43 AM
jeepdaddy2000
1971 CJ5
I’m on 33s, maxing out speed at 55 (somewhere right around 2000 rpm), and not sure what’s being asked by the third question
Might get a tach and double check your actual running RPM's. Things like fans and engine noise can make the motor sound like it's running a lot afster than it actually is.
RPM's Seem a bit low for "maxing out". Many of these 4BT's should run up into the 2800-3000 range.
My only worry is 2.73's with 33" tires will drop your RPM's down so low that the rig becomes a slug.......
Just something to think on.....
jp360cj likes this.
Thomas Payne
post #11 of 11 Old 04-09-2018, 06:17 AM
jp360cj
1977 CJ7
What jeepdaddy said. Sounds like you are still doing a lot of guessing and assuming.
Get a tach so you exactly what RPM you are running.
Use GPS to verify speed.
Verify your current axle ratio.
Then you'll have the info to truly understand how big of a change you will be making. You may find you already have 2.72 gears. You may discover your current gears are lower than you think and you may be more satisfied with something other than 2.72s. You may discover the best course is an o/d transmission instead of a gear swap. You may find that your RPM's aren't as high as you think.
jp360cj is offline
carrier , cj , gear ratio
