Need help with a noise - JeepForum.com
post #1 of 4 Old 05-23-2020, 09:39 AM Thread Starter
GADJIT98
Hello, it’s been a while since I posted. I was hoping someone could help me with a noise that seems to be coming from underneath my Jeep. It sounds similar to what a Cicada sounds like. It’s an odd squeal/squeak that happens at speed and only every few minutes. It’s not a belt - sounds more metallic. I was thinking t-case rear bearing possibly.
Has anyone ever had a similar experience? What did you do?
Thank you for your help
David
83 CJ7 258, T-176, d300, Heddman Headers, Weber 32/36, 3" lift, HEI ignition, Power Brake upgrade, 33x12.5's, 3:31 gears w/ one piece axles.
GADJIT98 is offline
post #2 of 4 Old 05-23-2020, 09:46 AM
Axhammer
Axhammer's Avatar
My hood latches squeak pretty good. When I first drove my Jeep I thought it was coming from the front suspension. After I drove it a while I replace the latches and it went away for a little while, but now it is back...and Im used to it, so it is no longer an issue.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #3 of 4 Old 05-23-2020, 09:52 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Could literally be any bushing; I'd start by seeing if you can recreate it byhaving a buddy pushing up/down on each corner. Check your shackle and shocks in particular.
If it's only while running/ driving, could be a belt, or possibly bearing, or even steering?
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #4 of 4 Old 05-23-2020, 01:53 PM
258
It sounds like it could be the hoods latches. Just squeeze some grease inside the ball pivots and lube them up. While you're at it, lube their shafts as well. Also, does it do it at acceleration? Have you noticed any slight power loss? It could be a loose timing chain as well that expands causing the chain to rub the sides of the cover when you rev it.
258 is offline
