Need help - JeepForum.com
post #1 of 9 Old 10-14-2020, 12:22 PM Thread Starter
themodelnut
Need help
I am trying to restore my late father's 1977 Jeep CJ7. I found a black wire with a factory plug at the end of it coming off the steering column connector however it is not attached to anything. Does anyone know where this wire plugs into.
themodelnut is offline
post #2 of 9 Old 10-14-2020, 12:42 PM
ShopJock
1980 CJ5
I think that is the horn wire. Should go to the horn relay.
I only need the tools that I can't find.
ShopJock is offline
post #3 of 9 Old 10-14-2020, 12:44 PM
John Strenk
John Strenk's Avatar
1976 CJ5
See if you can match it up with this diagram
Turn Signal Switch plug:
Wiring harness side of plug.
Name:  TS Harness Plug Front Light Detail.jpg
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 9 Old 10-14-2020, 12:49 PM
John Strenk
1976 CJ5
I thought it was the long one but if he's talking about the short one with the end cut off and twisted into a ball, then you're right, that should go to the Horn relay..
post #5 of 9 Old 10-14-2020, 01:13 PM
ShopJock
1980 CJ5
That longer black wire with the push-on plug is confusing. Seems like it may not belong there. Can we get another photo showing that wire going into the big harness plug?
If that wire is in the same place as the pink emergency flasher wire, could it be that your Jeep once had an extra set of flashing lights? Like perhaps for a mail delivery truck or a parking meter enforcement vehicle?
ShopJock is offline
post #6 of 9 Old 10-15-2020, 09:04 PM Thread Starter
themodelnut
Thanks everyone for your help. When I went to get a better pic of the wire today it just came right out of the steering column connector. There was no metal piece in the connector for it so I am still baffled about what the wire was used for.
post #7 of 9 Old 10-16-2020, 12:50 AM
Hoover7
Hoover7's Avatar
The connector on the loose black wire looks similar to the e-brake indicator signal wire on mine. Does/did your emergency brake have a wire connected to the backside? I'll admit, I'm guessing, as I've little experience with the pre-80's era jeeps. Just perplexing to have an errant black wire with a 90* connector in that area
Good luck-
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #8 of 9 Old 10-17-2020, 08:01 PM
braindamage
braindamage's Avatar
1978 CJ5
Being pragmatic...is anything not working with it disconnected? If not, shrug and move on with your life.
braindamage is offline
post #9 of 9 Old Yesterday, 01:06 PM
CSP
Go to oljeep.com and look for the '77 factory service manual. I can't remember if 77 is there, but 76 is and would be identical for wiring. You can download these in pdf form for free and every factory manual has the wiring diagrams.
CSP is offline
