Need Front Wheel Hub Reassembly Help - JeepForum.com
 2Likes
  • 1 Post By jurgen24
  • 1 Post By 77CJ5ME
post #1 of 6 Old 02-19-2020, 04:56 PM Thread Starter
77CJ5ME
77CJ5ME's Avatar
1977 CJ5
I've just repacked my front hubs and mounted back on the axle with the original bearings, nuts and washers (torqued to 50 ft-lbs). My problem is that after bolting the drive flange to the hub there's not enough clearance to put the snap ring back on the axle. Am I missing something obvious? Suggestions on what to check first. Thanks.
1977 CJ5 Base, Completely Stock, 23,000 miles
77CJ5ME is offline
post #2 of 6 Old 02-19-2020, 05:06 PM
jurgen24
Pull/pry the axle outward, you should be able to move it a bit.
Sent from my iPhone using Tapatalk
cjoffroad likes this.
jurgen24 is offline
post #3 of 6 Old 02-19-2020, 11:24 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I hope you didn't torque the inner nut to 50 ft lbs.......
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #4 of 6 Old 02-22-2020, 03:53 PM
80cj
80cj's Avatar
1980 CJ5
The end of the axle is threaded so you can stick a bolt in to pull on but it shouldn't be required.
80cj is offline
post #5 of 6 Old 02-22-2020, 04:06 PM Thread Starter
77CJ5ME
77CJ5ME's Avatar
1977 CJ5
Problem solved, needed to push the axle outward from the knuckle. Btw if you haven't checked out metalshaper on YouTube he has THE best axle rebuild videos. So front brakes and hubs complete, moving to rear brakes. Already found the left drum looks like its hasn't had any brake shoe contact for a long time.
MikeyDeezy likes this.
77CJ5ME is offline
post #6 of 6 Old 02-23-2020, 09:30 PM
CSP
Good to know about metalshaper. I've watched many of his videos making tubs, but nothing mechanical. Will have to check those out.
CSP is offline
