My Megasquirt efi and turbo build - JeepForum.com
 4Likes
post #1 of 116 Old 11-17-2015, 09:08 PM Thread Starter
dn101009
Well I have finally got the time and money to start working on my 84 cj7 4cyl again. It developed a bad knock last spring and has sat in the garage ever since. I thought I would do efi and a small turbo at the same time as rebuild. I will be keeping this thing as stock looking as possible and I'm going to try to do this clean and simple. Today I started building an engine run stand so I can do all my wireing and fab work outside of the rig. I may even try to find another running 2.5 to use as a test engine.
Here is my stand. I ran out of some steel so I got around to pulling the transfer case and tranny. I just need to finish up the motor mounts and maybe a gauge panel.
dn101009 is offline
post #2 of 116 Old 11-17-2015, 09:09 PM Thread Starter
dn101009
Another pic
dn101009 is offline
post #3 of 116 Old 11-17-2015, 09:11 PM Thread Starter
dn101009
Confused why it only lets me do one pic at a time.
dn101009 is offline
post #4 of 116 Old 11-17-2015, 09:27 PM Thread Starter
dn101009
Here is what I am working on.
dn101009 is offline
post #5 of 116 Old 11-18-2015, 03:26 AM
Jcowart62
1979 CJ7
Nice looking jeep, I really like the color, like mine , but with a black top, looking forward to the turbo build
Jcowart62 is offline
post #6 of 116 Old 11-19-2015, 07:15 PM Thread Starter
dn101009
Engine out and mounted up on the stand. Next is to steam clean the engine and see what is actually wrong with it. Ordered my efi stuff as well.
dn101009 is offline
post #7 of 116 Old 11-19-2015, 08:23 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This sounds like a great project. What kind of turbo will you be using?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 116 Old 11-19-2015, 08:35 PM Thread Starter
dn101009
I am not sure yet. I am reading up on turbos right now, so hopefully I will figure out what will work best for my application. I really am pretty unfamiliar with turbos on this small stuff. My guess is if I called turbonetics or garret they could probably set me up with what I need. I guess Im kinda waiting to find out whats wrong with my engine. If it needs some major components I may end up buying components that can take some decent boost. If its something simple, I will probably just keep it limited to around 6-7 psi. So... what I am saying is I am waiting to see what kind of rotating assembly I have before I order a turbo.
dn101009 is offline
post #9 of 116 Old 11-20-2015, 05:59 PM Thread Starter
dn101009
All steam cleaned up and ready to take apart
Found the culprit. Piston was seized to the rod too.
All taken apart and ready to head off to the machine shop.
dn101009 is offline
post #10 of 116 Old 11-23-2015, 12:06 AM Thread Starter
dn101009
Efi is here! Anybody where to get good fuse blocks and relay boards?
dn101009 is offline
post #11 of 116 Old 11-23-2015, 06:53 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
I'll be watching this build for sure. Really like the MegaSquirt stuff!
Check Waytek Wiring and Terminal Supply for electrical stuff. There are other places too.
How much boost do you plan on running?
"In the end...It's all Hack."
HackFabrication is offline
post #12 of 116 Old 11-23-2015, 07:28 AM
orange150
1982 CJ8
Waytech and Delcity are both good supply places that each carry a little bit different stuff.
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #13 of 116 Old 11-23-2015, 12:56 PM Thread Starter
dn101009
Thanks.
Im not entirely sure yet. I just got pricing for some forged pistons and rods from 505 performance. If I go that route I may try to run 10+ Psi, if not ill probably limit it to around 6-7 psi. I just need to figure out all the machining and balancing prices before I decide to go the forged route. I just don't want to end up polishing a turd with good money. Im ok with a stock rebuild and small boost. This project is more of a hands on learning experience for EFI and turbo than it is for performance.
dn101009 is offline
post #14 of 116 Old 11-23-2015, 08:50 PM
levergun
levergun's Avatar
1979 CJ5
I would probably find another source. 505 has horrible reviews and poor customer service. There are numerous threads on their shoddy craftsmanship and pore customer service
1979 CJ5 MB OM602 diesel, dana 60/14b, T18, d300
1948 Willys CJ2a LS 4.8/sm465 dana 60's, 38's
levergun is offline
post #15 of 116 Old 11-23-2015, 09:16 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Awesome pics! The microsquirt comes with a nicer box than mine. I just had to return the wideband sensor (it was borrowed), so I purchased and AEM and I'm going to wire it to the Megasquirt, after I do that I may be able to help you install your 02 thingy.
I managed to rev mine up to 2500 RPM's today, my timing was excessively retarded and it was hurting engine temps. I will tweak more tomorrow night too much midnight oil for today.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
