My cj7 stalls when I accelerate - JeepForum.com
 2Likes
  • 1 Post By LumpyGrits
  • 1 Post By ddawg16
post #1 of 14 Old 06-12-2019, 06:42 PM Thread Starter
Hunter Petersen
Hunter Petersen's Avatar
Hey everyone, just got my jeep running, cleaned up the carb. Now it will start running, and it will idle all day. It will go if I slowly give it gas, but if I try to accelerate too quickly it will stall. Any ideas what could be the issue?
Hunter Petersen is offline
post #2 of 14 Old 06-12-2019, 06:47 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Probably fuel related.
You need to figure out if it's a rich bog, or a lean cut out. The plugs should offer some clues.
Matt
Matt1981CJ7 is offline
post #3 of 14 Old 06-13-2019, 05:49 AM
Deer-Slayer_5
What year is it and what engine? When I bought my 85 CJ, the guy I bought it from had done a "nutter bypass" on the 258 and didn't change the carburetor. That and the engine was worn out. Mine would idle but as soon as you gave it gas it would die. Slapped a pre-emmisons carb on the jeep and it ran fine other than having a lot of blow by. Since I've had it running, I tore it apart and had it rebuilt but haven't started it yet. Just thought I would share my experience with an 84 to 86 258.
Deer-Slayer_5 is offline
post #4 of 14 Old 06-13-2019, 09:14 AM
hp_lovecraft
1981 CJ5
Lots of things can cause that problem. It can be maddening. Too much fuel, not enough fuel, not enough air, clogged exhaust, poor spark, bad timing, etc
I think on mine, I've had that happen with a clogged cat, a clogged carb jet, a loose distributor (way off!), a pinched fuel line, sticky float, a stick choke.
hp_lovecraft is offline
post #5 of 14 Old 06-13-2019, 04:21 PM
LumpyGrits
Cj
Worn accelerator pump or low setting of float level, is where I would start.
If you would fill out your profile-That would help us, to help you.........
LG
TIPPEDITOVER likes this.
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 14 Old 06-13-2019, 06:35 PM
Dryseals
1980 CJ7
Originally Posted by Hunter Petersen View Post
Hey everyone, just got my jeep running, cleaned up the carb. Now it will start running, and it will idle all day. It will go if I slowly give it gas, but if I try to accelerate to quickly it will stall. Any ideas what could be the issue?
Does it hesitate when you give it gas? If so look down the carb and give it a little gas, if you see a fuel spray into the carb, then thats going to be OK. Timing would be next....one thing at a time.
Dryseals is offline
post #7 of 14 Old 06-15-2019, 09:34 PM
willyboy123
willyboy123's Avatar
stick a piece of wire in there and hold the choke in the off position. Ive seen the vacumm from the intake pull the choke shut. just an idea
willyboy123 is offline
post #8 of 14 Old 06-16-2019, 09:43 PM
ddawg16
ddawg16's Avatar
Dist advance hooked up right?
As you can see from above, lots of reasons.
I'd start with the accel pump. With the engine off and the air cleaner off, look down the throat of the carb. Move the accel linkage. If you see squirts of gas in the throat, accel pump might be ok.
And as Deer asked....year, engine, carb, etc.
ddawg16 is offline
post #9 of 14 Old 06-17-2019, 09:43 AM
Deer-Slayer_5
As I am seeing more replys, take a look at your fuel lines leading to the carb to see how close they are to the engine. If the engine is getting warm and the fuel lines are close to the engine, I wonder if you are experiencing "vapor lock" in the fuel lines. Heat causes the fuel to vaporize prematurely and will cause bogging or no fuel to the carb. It may run at idle in vapor lock but as soon as you want to give it gas it will die.
I'm having to keep this in mind while routing my fuel lines on my jeep because it goes over the valve cover on the 258.
post #10 of 14 Old 06-17-2019, 10:01 AM
jimdubose
1978 CJ5
look in your fuel tank, drop it and clean it out, I had the same issues with my 78 cj5, it would idle all day long like yours, but bog down under load. I dropped the tank and cleaned it out, it was full of sludge and mud (how????), but once I got that out and POR coated the inside of the tank and buttoned it back up and hooked everything back u and problem solved
jimdubose is offline
post #11 of 14 Old 06-17-2019, 11:10 PM
ddawg16
ddawg16's Avatar
258's don't vapor lock. Cracked fuel lines and sucking air? Yes....vapor lock? No.
ddawg16 is offline
post #12 of 14 Old 06-17-2019, 11:12 PM
ddawg16
ddawg16's Avatar
And your pickup filter was gunked up. A quick vac test with a hand vac pump would have shown that one.
On a jeep that old, I hope you replaced all the rubber fuel lines.
ddawg16 is offline
post #13 of 14 Old 06-18-2019, 08:37 AM Thread Starter
Hunter Petersen
Thank you everyone I’m just going to make a checklist and go through all of this when I get a day. Also it is a 1979 with a 304 and a Holley 470 carb.
post #14 of 14 Old 06-18-2019, 09:51 PM Thread Starter
Hunter Petersen
Something I forgot to mention. It will start with starter fluid and after it is warmed up it will start by itself, but it won’t start with a cold engine.
