Motorcraft 2150 - JeepForum.com
 2Likes
  • 1 Post By uptillnow
  • 1 Post By Green Chile
post #1 of 14 Old 07-22-2021, 10:38 AM Thread Starter
Nicnic
Motorcraft 2150
Hello everybody,
I just got an 83 CJ7 and I’m looking at the motorcraft 2150. It looks like The eBay guy that everyone used to get theirs from isn’t doing it anymore. All I can find is rebuilders and Chinese versions. Are these Chinese carbs good? I have a 2150 that needs rebuilt just hoping to buy one that has been professionally done/tested. Thanks in advance!
Nicnic is offline
post #2 of 14 Old 07-22-2021, 08:18 PM
Jim1611
Jim1611's Avatar
Originally Posted by Nicnic View Post
Hello everybody,
I just got an 83 CJ7 and Iím looking at the motorcraft 2150. It looks like The eBay guy that everyone used to get theirs from isnít doing it anymore. All I can find is rebuilders and Chinese versions. Are these Chinese carbs good? I have a 2150 that needs rebuilt just hoping to buy one that has been professionally done/tested. Thanks in advance!
I'd find someone that can rebuild the one you have and forget the chinese junk.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 14 Old 07-22-2021, 09:16 PM
jeep_boy02
1934 CJ7
Mike's Carbs....
https://www.carburetor-parts.com/2150parts.html
I've always used his rebuild kits and parts.
I don't think he has carbs for sale but states that all parts are US made.
Sent from my SM-A015A using Tapatalk
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #4 of 14 Old 07-22-2021, 09:32 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
If you buy a Chicomm clone for say $80 plus shipping from China (saw one on ebay for this) , deduct the taxes and seller margin and how much do you think it was ex factory? $30?
The seller has not invested in R&D and QA and inwards goods testing in the same way that Ford or GM does. You are therefore taking a risk that it even works.
i bought a cheap Chicomm clone BBD a few years back, supposed to be a direct fit. There was no means of attaching the choke coil so no choke. I persevered and fitted it with no choke, it just about started but there was a whistling at idle as the butterfly plates did not meet the venturi walls exactly. So I rebuilt my original 40 year old BBD, it is missing a few bits of linkages etc but I managed to beat bits of the clone to fit, now it runs sweet.
I don't believe my experience is rare or unique.
So if you want an MC2100 I suggest you get reman / rebuilt original. or buy a scrapyard original and rebuild it yourself, the kits are real cheap.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #5 of 14 Old 07-23-2021, 03:31 AM Thread Starter
Nicnic
Thanks for the replies. I will just have mine rebuilt, just wanted to see if maybe there was some good in the cheap stuff.
Nicnic is offline
post #6 of 14 Old 07-23-2021, 05:06 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Hello everybody,
The 2150 is slightly more complicated than the 2100, which is IMHO the simplest carb in the world.
I wouldn't be afraid to get a kit for your carb and do it yourself.
Watch some videos.
Take some pictures.
Ask for some help.
Get it done.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is online now
post #7 of 14 Old 07-23-2021, 10:44 AM
downs
downs's Avatar
1995 XJ Cherokee
The Motorcraft carbs are dirt simple to rebuild. As long as your throttle shaft is good and not wobbling all over the place you can rebuild it in about an hour including cleaning. A gallon of Berryman's carb dip will be your friend.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #8 of 14 Old 08-13-2021, 08:44 AM
Dkjeepsters21
So Iím in the same predicament, am still having trouble getting a recommendation on a reliable place to purchase a new (?), non-Chinese knockoff for a Motorcraft 2150. Mine is not rebuildable, shaft has way to much play and the flutter valves are very pitted. I can rebuild one fine, but need a good unit to start with and if I can buy one already done Iíd rather spend a few extra bucks and bolt it on and get back running again. Mikeís Crabs sell the whole carb but set up for V8 and if you break it open to jets then warranty if void, which isnít the end of the world butÖ
Dkjeepsters21 is offline
post #9 of 14 Old 08-13-2021, 02:13 PM
uptillnow
uptillnow's Avatar
A Weber 38-DGES (K551-38) for your Jeep is $335.00. New, jetted for your engine, no wobbly shafts, no rebuilding, etc.
UTN
Matt1981CJ7 likes this.
uptillnow is offline
post #10 of 14 Old 08-13-2021, 04:10 PM
MoC
MoC's Avatar
Hello everybody,
National Carburetors rebuild and return service.
They are a major rebuilder and will warranty the carb as long as you don't take it apart.
https://nationalcarburetors.com/RR-S...tor_c_199.html
MoC is offline
post #11 of 14 Old 08-16-2021, 06:54 AM
Dkjeepsters21
I went ahead and ordered one from Mikeís. It comes with .49 jets so I ordered the .47s and will trade them out. Unless it will run with the .49s?
post #12 of 14 Old 08-16-2021, 08:24 PM
Green Chile
Green Chile's Avatar
1977 CJ7
49 will be too rich, 47's were good for me when I had a MC2150 on my 258.
Dkjeepsters21 likes this.
Green Chile is offline
post #13 of 14 Old 08-16-2021, 09:52 PM
Jeep-N-0311
I see that you already ordered.
Just a general FYI, these folks do a good job as well. Spoke to them about exactly what I wanted, got a great 2150.
https://www.allamericancarburetor.com/
28 Industrial Loop Dr E Suite 177, Orange Park, FL 32073
Call with any questions. 904-215-6790
Jeep-N-0311 is offline
post #14 of 14 Old 08-17-2021, 05:14 PM
Dkjeepsters21
Now ya tell me!🤨 😂 Looks like they ďremanufactureĒ, didnít see a purchase option looking quickly. Mine is pretty bad, lots of dings and dents, and the flutter valve shaft has so much play in it. Thanks though, will keep the info for further reference.
