MC2100 Carb tuning - JeepForum.com
post #1 of 8 Old 01-14-2009, 08:42 PM Thread Starter
Kwish
1982 CJ7
MC2100 Carb tuning
Well, I installed a MC2100 carb on my 4.2L last spring, and it seems to be running quite rich. Atleast Im guessing its rich from the massive backfires haha. Anyways, if anyone has tuned a MC2100 could anyone either help me with some pictures, or telling me which screw to turn? I have only found the screw to adjust the idle.
Kwish is offline
post #2 of 8 Old 01-15-2009, 08:56 AM
kavephish
1981 CJ5
There are two screws for idle mixture adjustment on the MC2100, both on the front/bottom of the carb. Make sure they are both turned out the same amount from bottom (ie. turn them all the way in till they TOUCH, not HIT, bottom, then back them out two turns to start) Hook a vacuum guage up to manifold vacuum and start your engine. You are looking for 18-21Hg CONSTANT on the vacuum guage. Turn one screw, then the other, bit by bit, until you reach maximum attainable vacuum on the guage. VERIFY your timing is correct. If this does not help you may have to rebuild your carb. Kits are cheap and easy to install - other than the float/needle and spring, there are no little parts that will go flying out if you open it up and shake it around - very easy rebuild. You may have also blown the power valve on the front/bottom of the carb (looks like a little 1 inch bowl). You will have to pull the carb off to check it. Take out the 4 screws holding it on....if there is gas in the 'bowl',the valve is bad. The valve will come with a rebuild kit, or you can purchase it seperately.
kavephish is offline
post #3 of 8 Old 01-15-2009, 11:04 AM Thread Starter
Kwish
1982 CJ7
Ah, alright thanks alot! now all I need is a vacuum gauge
Kwish is offline
post #4 of 8 Old 07-03-2009, 10:43 PM
oldskull44
1980 CJ7
motorcraft 2100 power valve question on 304
I have a question regarding my carb on an 80 jeep with a 304. all stock.
I have problems with it running rough. sometimes it barely runs and it seems to change every time I hit a bump. I just got a rebuilt carb and I was told the electrical system is okay (it was put on a scope). I checked for vacuum leaks with carb cleaner at the base of the carb.
I was wondering if a back fire would blow the power valve and cause this problem. Or is there a different sympton of a blown power valve?
1980 CJ7 - 304 - T176 - D300 - D30 - M20 - 4" Lift - TJ Flares - 35x13.5x15 Krawler T/A's
oldskull44 is offline
post #5 of 8 Old 06-12-2019, 10:20 PM
swanny88
1983 CJ7
I know this is an older post but it has some great information.
I am trying to fine tune my 258 that has a Clifford intake and a mc2100 carb. Have a variety of jets available as well. When I hook up my vacuum gauge to the intake manifold I noticed the needle bounces rather than remaining steady. The movement is not large, it just bounces about 3*. I suspect I may have an intake leak but when I spray fluid around it the engine doesn’t seem to change. My idle is somewhat rough as well. What things should I look for?
Swanny
1983 CJ 7, 258, 3 speed auto
Colorado
swanny88 is offline
post #6 of 8 Old 06-12-2019, 11:35 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
Is it doing one of these things?
OrangeCJ-5 is offline
post #7 of 8 Old 06-13-2019, 01:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Does it just bounce at idle, or does it bounce at all RPMs?
Matt
Matt1981CJ7 is offline
post #8 of 8 Old 06-13-2019, 09:00 PM
swanny88
1983 CJ7
Thanks guys it bounces at all rpms. The engine was fully rebuilt about 1 Year ago with new rings pistons, etc. I wonder if it’s my gauge.
Swanny
Colorado
swanny88 is offline
Tuning the MC2100, choke off it dies when warmed up Blthomas Jeep CJ Forum 12 07-17-2009 07:43 AM
83 CJ7 HEI and MC2100 tuning help firejeep344 Jeep CJ Forum 46 05-08-2009 10:21 AM
MC2100 Vacuum tuning 304 v8 ehudson94 Jeep CJ Forum 4 01-19-2009 06:53 AM
MC2100 Tuning walkthru? RUH ROHH Jeep CJ Forum 2 10-19-2006 08:30 AM
MC2100 Carb Tuning Help Seether Jeep CJ Forum 4 04-18-2006 02:18 PM
