M20 / D30 Carriers - JeepForum.com
post #1 of 10 Old 02-05-2009, 12:07 PM Thread Starter
bigjoe
bigjoe's Avatar
1977 CJ7
M20 / D30 Carriers
Quick question. Are the carriers the same in a Narrow trac & Wide-trac axle?
I know the shaft lengths are different. If the same can you swap the carriers from a NT axle to a WT axle? Thanks for any help.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #2 of 10 Old 02-05-2009, 12:47 PM
80cj
80cj's Avatar
1980 CJ5
Same carriers whether wide track or narrow track.
80cj is offline
post #3 of 10 Old 02-05-2009, 02:26 PM
Bard
Yes, just remember you will have to reset the backlash, new crush collar for the rear, new seals and it usually requires a kit for front and rear. Much cheaper than having to buy new gears and carriers though.
and remember that the carriers have a break for what ring and pinion they have in them. so don't just swap the carriers, you should keep the same R&P set up.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #4 of 10 Old 02-05-2009, 06:39 PM
plain76cj5
The Dana 30 uses two different carriers: one for 3.54 and down and another for 3.73 and up.
AMC 20 uses the same carrier for 3.07 and up. The 2.73 carrier is only for that ratio.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
post #5 of 10 Old 02-06-2009, 11:16 AM Thread Starter
bigjoe
bigjoe's Avatar
1977 CJ7
That's what I though, but just could not find the info. Thanks guys.
bigjoe is offline
post #6 of 10 Old 02-06-2009, 11:19 AM
Hybrid Jeep
1976 CJ5
Also.. the LSD AMC 20 carrier is different.
Hybrid Jeep is offline
post #7 of 10 Old 02-06-2009, 12:41 PM
80cj
80cj's Avatar
1980 CJ5
In what way? The ratio break is still the same.
80cj is offline
post #8 of 10 Old 02-06-2009, 12:49 PM
Hybrid Jeep
1976 CJ5
I've been told that in order to get a locker in my LSD AMC20.. I will have to purchase a standard carrier... if this isn't the case.. please let me know now!
post #9 of 10 Old 02-06-2009, 01:37 PM
j33pman
j33pman's Avatar
what locker are you trying to put in.
If its a lock right the part number for open carrier and trac-lok carriers are different.
If an ARB, Detroit, or OX the locker is also the carrier
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #10 of 10 Old 02-06-2009, 01:58 PM
foggybottombob
foggybottombob's Avatar
Some lunchbox lockers come in versions for an open case or an LSD case for some axle types. I think that is what you are wanting to know. I'm in Monument if you want to call and ask about some locker.
foggybottombob is offline
What is the difference between AMC 20 open carriers? wrg Jeep CJ Forum 3 07-29-2008 12:52 PM
Rear Tire Carriers seayj7 Jeep CJ Forum 3 07-21-2008 09:39 PM
Is there a place to buy oversized spare tire carriers UGA6 Jeep CJ Forum 16 02-27-2007 08:36 AM
The Final Word on Rear Bumpers/Tire Carriers buckallred Jeep CJ Forum 7 07-18-2004 06:46 PM
