Loss of power - JeepForum.com
 1Likes
  • 1 Post By Fourtrail
post #1 of 13 Old 02-14-2020, 07:54 PM Thread Starter
zeebart
Loss of power
I had a shop work on my '81 CJ7 over last summer to help me get through emissions testing (I kept failing and got turned backwards with the carb adjustments). They adjusted the timing, the carb, and added a fuel regulator. They said that everything else looked really good and were impressed with the Jeep. It still has the original 4 cylinder "Iron Duke" engine. Rebuild tranny and carb. Passed eventually.
Since then it've slowly lost power. When I accelerate or attempt to climb a steep hill the power that I once had (albeit not that much, it's the 4 cylinder Duke) is not there. I hit the gas and the engine does rev, but the tranny doesn't catch up for a little while. There's a sweet spot if I don't push too much on the accelerator it will put out the torque, but it performs like my old '72 VW bus climbing the coast range.
Before I dive into possible solutions, anyone have any ideas? Timing? Carb? Loosing compression in one or more cylinders?
zeebart is offline
post #2 of 13 Old 02-14-2020, 08:51 PM
Fourtrail
1974 CJ6
Too much undercoating weighing you down....
Sorry, with your usename, I couldn't pass it up. You mention the motor revs then the tranny catches up so automatic? Basics, pull the plugs and post some pictures so we can see if it is running rich or lean. Also doing a compression test won't hurt.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 13 Old 02-14-2020, 10:21 PM
jibib
What carb are you running on it? I had same experience on my 86 4 cyl when I put the Carter carb on it to pass smog.
jibib is offline
post #4 of 13 Old 02-14-2020, 11:47 PM
restorationride
Simply put, it sounds like a transmission problem.
Sent from my GM1915 using Tapatalk
restorationride is offline
post #5 of 13 Old 02-14-2020, 11:50 PM
RedNeckCorvette
1979 CJ7
Nothing in your profile about you or your jeep.
Not enough information posted to help. Automatic or manual transmission?
Filling out your profile helps.
RedNeckCorvette is offline
post #6 of 13 Old 02-15-2020, 12:07 AM
restorationride
I thought it was filled out. Anyway, automatic or manual transmission doesn't really make a difference. Sounds like a transmission problem either way...
post #7 of 13 Old 02-25-2020, 04:28 PM Thread Starter
zeebart
Manual transmission. 151 4-cylinder '81 CJ7. Trying to send a pic see if it works...
zeebart is offline
post #8 of 13 Old 02-25-2020, 04:29 PM Thread Starter
zeebart
And here's a couple of the plugs...
zeebart is offline
post #9 of 13 Old 02-25-2020, 04:32 PM Thread Starter
zeebart
Trying again with the pix
zeebart is offline
post #10 of 13 Old 02-25-2020, 04:46 PM
Fourtrail
1974 CJ6
Plugs look ok, but i would swap them to a normal set of plugs from autolite/champion/delco, I have never been a fan of the v-power plugs, they would wear off the outer edges of the 'V' and then your gap would grow and not want to fire correctly. Like already stated though, if your motor revs up and the Jeep doesn't speed up, then you are more looking at a transmission issue. The color/smell does the ATF have when you pull the dipstick?
ddawg16 likes this.
post #11 of 13 Old 02-25-2020, 06:09 PM
uptillnow
uptillnow's Avatar
From your description of how it acts, it sounds like the transmission to me as well. "I hit the gas and the engine does rev, but the tranny doesn't catch up for a little while."
Although you have a Weber carburetor and they take some specific adjustments. This may also be a problem. "(I kept failing and got turned backwards with the carb adjustments). They adjusted the timing, the carb, and added a fuel regulator."
The plugs look reasonably good, so your carburetor, and timing, can't be that far off???
UTN
uptillnow is offline
post #12 of 13 Old Yesterday, 10:14 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
clutch slip?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 13 Old Today, 01:39 AM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by BagusJeep View Post
clutch slip?
That's what it has to be. Otherwise how can a manual trans have to "catch up"?
80cj is offline
