lift spring question - JeepForum.com
post #1 of 5 Old 10-15-2021, 10:25 PM Thread Starter
1matt
Hello... my name is Matt and i registered to ask the jeep brain trust a question .... I recently built a off road camping trailer and used cj7 3 inch lift springs to give me the finished height i was wanting.... trailer is ,of course a bit heavier than i guessed it would be .... is there an add aleaf that i can add to those springs ??? maybe a link or part number ...thanks for any help.... Matt
1matt is offline
post #2 of 5 Old 10-16-2021, 01:39 AM
80cj
80cj's Avatar
1980 CJ5
Not sure who makes add a leaves for 3" lift springs. If you want to experiment, perhaps you could got to a wrecking yard and find spring leaves of the same width (2 1/2") and try adding them in but finding something to match your spring arc may be a problem. If you don't mind my saying so, I would have used springs from a pickup truck. Jeeps are light weight vehicles and those lift springs were probably made to give a good ride so my guess is that the load rating is low .
80cj is offline
post #3 of 5 Old 10-16-2021, 07:00 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
As suggested a junkyard S-10, Ranger, Bronco-II leaf spring donor might work, or any correct width 2"-4" Add-a-Leaf.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #4 of 5 Old 10-16-2021, 04:56 PM Thread Starter
1matt
ok was hoping this had come up for someone in the past ...thanks for the suggestions ..Matt
1matt is offline
post #5 of 5 Old 10-17-2021, 12:28 PM
devildog80
devildog80's Avatar
1981 CJ5
A bit heavier than wanted is ???
Consider if those springs were under your CJ, they are supporting constant weight of the truck (+-2500 lbs), especially in the front. Unless you are building a 16 ft full size camper, which TARE Weight would be about 2500 lbs, your chosen springs should do a good job for many years. Not too stiff, so it shakes your structure above to pieces with every crack in the road, but supportive. Consider a set of shocks too.
In turn, you can go to any spring shop if unable to find other options, and they can make you an overload leaf.
My $0.02
devildog80 is offline
