Lift her or not? - Page 2 - JeepForum.com
 9Likes
post #16 of 25 Old 10-13-2020, 06:07 PM
johnson30
1978 CJ5
If you are going to change the suspension, the YJ spring conversion up front is the way to go. Don't spend money to get more 2" wide front springs at any height. The ride is harsh, sometimes scary depending on speed and bumps.
If you aren't changing tires, I'd stay stock height but get YJ springs. It'll be safer that way and you won't find yourself down the rabbit hole of new driveshafts, pitman arms, caster shims, etc etc.
31x10.5 will look just right.
johnson30 is offline
post #17 of 25 Old 10-13-2020, 07:19 PM Thread Starter
Cuzzi23
Here is where I stand right now.
I want to convert to yj springs, that seems to be clear, everyone agree on that for what I read.
Best yj springs are the Old man Emu, everyone seem to agree on that too.
Emu springs for Yj are for 2.5" lift, or more, correct?
The choices for stock height cj7 are crappy imports with a lousy rep., could not find any others.
I like the 2.5 lift, I'm gonna replace tires, springs and shocks no matter what.
I would like to keep the rest stock.
I would like 31's or 32's.
Daily driver, minimum off road
Is this doable? Someone said don't go over 30's
I'm new to jeeps, love them, know nothing about them.
A couple books, lot of time here. Zillion questions on my head.
Cuzzi23 is offline
post #18 of 25 Old 10-15-2020, 09:40 AM
bob4703
1974 CJ5
Are you sure about stock height springs being made offshore? A few years ago I replaced the front springs on our 74. This is before I knew about the bad rep of Crown and OMIX-ADA parts. I ordered Crown front springs and when they came in one was damaged. I raised heck with the vendor because I had an appointment at the alignment shop to get them installed. They had a spring drop shipped from the factory. I later ordered ADA rears and they were shipped from the factory. One factory is in PA and the other is in MA--I forget which is made where. It is often cheaper to manufacture heavy items like springs in country than pay to ship them from overseas. Of the two the OMIX-ADA were the better made springs. Call the vendor and ask.
Paved roads are prime examples of government over spending!
bob4703 is online now
post #19 of 25 Old 10-16-2020, 09:24 AM Thread Starter
Cuzzi23
bob4703,
thanks for sharing your experience. No, I'm not sure about where the springs are made.
Just trying to order my thoughts. Seems that nobody is recommending Omix-Ada.
I will look more into it.
Thanks again
bob4703 likes this.
Cuzzi23 is offline
post #20 of 25 Old 10-16-2020, 01:37 PM
momo2
1980 CJ7
I'm in the same boat as you. I got 31s on my jeep and would love to convert to yj springs, but as i'm not going to get bigger tires i don't want to get more than 1.5 inches of lift. I consider installing the ome light/medium r37 rear springs all around as they should provide less lift than their heavy springs. However i found no one who could tell me how much lift i would get with this setup? 2 inches? 1.5 inches? There is also a 1.5 inch yj lift from Alloy USA but i didn't find any reviews on this one.
Gesendet von meinem SM-G950U mit Tapatalk
momo2 is offline
post #21 of 25 Old 10-16-2020, 07:04 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by OrangeCJ-5 View Post
Personally, I wouldnít be thinking about spending money on a lift kit. Iíd be more concerned about the hole in in body where the roll bar attaches to the floor. Is there anything under that mounting plate?
Rust.
80cj is offline
post #22 of 25 Old 10-16-2020, 08:20 PM
oldschool74cj5
hello
i really try my hardest to stay away from omix and crown product just because of the quality isnt there. but you have to watch out because omix has other names under there brand that sound like they are american companies or quality. here is the list they have on there website. Rugged Ridge, Omix, Alloy USA, Outland or Precision Gear are all omix companies.
what i do is i ask the company where there parts are made on the phone. if no answer or quality offshore supplier then i know its china. there are some some small spring shops in the usa. they make there springs in the USA but you will pay a little more. but you will get more of what you are paying for.
oldschool
oldschool74cj5 is offline
post #23 of 25 Old 10-17-2020, 07:56 PM
braindamage
braindamage's Avatar
1978 CJ5
No idea why you’d lift if your are keeping to 31’s. They fit with stock, so no need for the lift.
braindamage is offline
post #24 of 25 Old 10-18-2020, 10:37 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
CJ U.S. made leaf springs:
https://www.generalspringkc.com/Leaf..._DJ_s/1949.htm
Wrangler leaf springs:
https://www.generalspringkc.com/Leaf...ler_s/1952.htm
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #25 of 25 Old 10-19-2020, 06:04 AM Thread Starter
Cuzzi23
Thanks Hurricane4, I went and checked that site.
Thatís what I needed.
If I use them I could stay stock with yj springs for an improved ride.
Gonna give them a call, or send them a text.
Cuzzi23 is offline
