Lets talk replacement tail lights. Looking at the quadratech led ones. Any opnions? - Page 3 - JeepForum.com
 7Likes
post #31 of 51 Old 10-15-2020, 01:18 AM
agear
I bought this one yesterday and my brake lights dont come on when my blinkers are on. I put led 1156 and 1157s in.
https://shop.advanceautoparts.com/p/...A_EC_TX_ORDCON &utm_content=ITEM
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #32 of 51 Old 10-15-2020, 03:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Did they both work before you replaced the flasher unit?
Normally, if the right turn signal is ON then only the left brake light will work and if the left turn is ON only the right brake light will work.
1156 is a single contact bulb like those used in the backup lamp
1157 is a dual contact bulb used for taillight/brake light lamp.
which one did you put were?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #33 of 51 Old 10-15-2020, 11:40 AM
steve801
1983 CJ7
Probably should wait for Frankie to answer but these look pretty good.
https://www.amazon.com/AutoSmart-Rou...X21Y0W9FHRZTKA
Thank you!
steve801 is offline
post #34 of 51 Old 10-15-2020, 02:32 PM
agear
Okay in the first paragraph you mean as long as the lights are already on , right ?
I put the 1156 in the top and 1157 in the bottom
agear is offline
post #35 of 51 Old 10-15-2020, 03:41 PM
John Strenk
1976 CJ5
Well no, but that is another situation that we have to consider.
It should work the same way whether the light are on or off. But if you are getting different results depending if the light are on or off, that will help diagnose the problem.
Sounds like you have the bulbs in the right locations.
post #36 of 51 Old 10-16-2020, 05:23 PM
agear
Okay john with my stock flasher in there and led 1157 s and 1156s both sides, they work except the signals flash too slow and when i hit the brakes without my lights on I guess the amps are back feeding to the ftont fender lights. And the led compatible flasher I got doesnt even let the signals work
agear is offline
post #37 of 51 Old 10-16-2020, 08:09 PM
John Strenk
1976 CJ5
Is the emergency flasher button pushed in by mistake?
Are the LEDs just in the Bach or also in the front?
I just finished up one little problem on my lighting system today and now Iím fully LEDs on my parking lights and turn signals.
post #38 of 51 Old 10-17-2020, 02:21 AM
agear
I just finished up one little problem on my lighting system today and now I’m fully LEDs on my parking lights and turn signals.
Just in the back. The emergency flashers aren't on .
agear is offline
post #39 of 51 Old 10-17-2020, 09:42 AM Thread Starter
weapon
1983 CJ7
no one is ever going to be able to find/search for this information on the led blinker issue and your trials. You guys should move it to a new thread because I am sure it will be helpful down the road as more people go led. Otherwise you are going to be repeating yourself. ha
weapon is offline
post #40 of 51 Old 10-17-2020, 09:52 AM
John Strenk
1976 CJ5
What?
There can't be more than 5 or 6 threads on this!!
Even I have problems finding out what thread has what information.
Cutlass327 likes this.
post #41 of 51 Old 10-17-2020, 10:16 AM Thread Starter
weapon
1983 CJ7
What?
so true. the search on here is not robust. I sometimes have to ask where my own threads are. haha
weapon is offline
post #42 of 51 Old 10-18-2020, 06:14 AM
agear
Okay , so i bought this
http://shop.advanceautoparts.com/p/g...A_EC_TX_ORDCON
But with the running lights and headlights off and I hit the brake electricity backfeeds ? To the front fender lights still. Will it hurt to run it like this till I get the flasher you have john ?
agear is offline
post #43 of 51 Old 10-18-2020, 10:43 AM
John Strenk
1976 CJ5
Probably not hurt anything.
post #44 of 51 Old 10-18-2020, 11:51 AM
agear
Thank you. Who knows why it didn't work . My brother in law said ill probably have to put a diode in there .
Would this work
https://shop.advanceautoparts.com/p/...searchTerm=led light bulb resistor
I wouldn't know where to install it
agear is offline
post #45 of 51 Old 10-18-2020, 03:24 PM
John Strenk
1976 CJ5
If you are buying the same flasher as Iím using you wonít need it.
But if you want to use the stock flasher then you need to use the resistor.
The resistor will have to be placed in parallel with each tail light.
