Lets talk replacement tail lights. Looking at the quadratech led ones. Any opnions? - JeepForum.com
 7Likes
post #1 of 51 Old 10-08-2020, 05:22 PM Thread Starter
weapon
1983 CJ7
Lets talk replacement tail lights. Looking at the quadratech led ones. Any opinions?
Need new tailights. Looking at these.
https://www.quadratec.com/products/55213_0111.htm $139.
Opinions? other tail light options? How to get the best price?
Thanks.
weapon is offline
post #2 of 51 Old 10-08-2020, 06:13 PM
Jim1611
Jim1611's Avatar
I used some off of a YJ tub. They have the water tight connections on them too. Then I lined them with some white reflective tape and they really are bright.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 51 Old 10-08-2020, 08:50 PM
franke51
franke51's Avatar
2016 JK Wrangler
I don’t know if you want to cut your tub. I purchased round led semi truck taillights that use a rubber grommet in the hole I cut to hold them. No more broken and torn off own taillights.
XtevanAustin likes this.
franke51 is offline
post #4 of 51 Old 10-09-2020, 03:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I have a similar set of those on mine and my sons JK
They ate great easy to install and very bright.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #5 of 51 Old 10-09-2020, 08:26 AM
aillon
aillon's Avatar
Keep us updated, I would like to see how this turns out. I frequently get beeped at when I pull over to let someone go (that is tailing me). I don't think they can see my blinker. I am positive it works, i have tested it a 1000's times. With the current OEM taillights if the sun hits it in just the right way I don't think you can see the light if its on.
aillon is offline
post #6 of 51 Old 10-09-2020, 11:29 AM Thread Starter
weapon
1983 CJ7
Ordered them up. Will be a bit before I can get them working but will install them when they arrive.
weapon is offline
post #7 of 51 Old 10-09-2020, 07:02 PM
John Strenk
1976 CJ5
When mine first arrived, I compared them side by side with the stock ones.
The old one would light up a wall, these would light up the whole room when pointed at the same wall.
These are so bright, they actually start to hurt your eyes when you look directly in them.
The
firegod33 likes this.
post #8 of 51 Old 10-09-2020, 07:51 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I picked "Low to high" and "80 per page"
This really covers a lot of ground!
Look at the sides and bottom too.
http://www.shopzilla.com/automotive-...p+code&show=80
I found this works well if you can keep your search "Specific" and as short as possible. Otherwise you get swamped with crap you don't want, you'll get a fair amount of it regardless!
-----JEEPFELLER
JEEPFELLER is offline
post #9 of 51 Old 10-10-2020, 03:20 PM
cglax6
1976 CJ5
Do you need the whole housing? If not, it would be MUCH cheaper to just get LED bulbs. There's a thread on here somewhere with part numbers to use at SuperbrightLED website.
cglax6 is offline
post #10 of 51 Old 10-10-2020, 06:36 PM Thread Starter
weapon
1983 CJ7
The jeep has brand new paint and bedliner. It is too nice to put the 30 year old plastics on it. Had to buy all new housings.
weapon is offline
post #11 of 51 Old 10-10-2020, 09:16 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Here's the ones I bought. 3 years later still going good.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Rick
1978 CJ5 5.0HO/T177/D300 TerraLow 4:1 kit, '86 D30/D44 3.54 WT axles w/Aussies, 'glass body, 33x12.5 ProComp A/T, TDK galv'd frame, 2.5 OME YJ lift - DD and weekend toy
Cutlass327 is offline
post #12 of 51 Old 10-11-2020, 04:02 AM Thread Starter
weapon
1983 CJ7
Those look good and great price but no side marker though. Need that to continue the oem look of an 1983.
Did the oem tail lights come with side markers on a '78?
weapon is offline
post #13 of 51 Old 10-11-2020, 04:59 AM
John Strenk
1976 CJ5
I think they had rear side lights until 1980 them they were integrated into the tail light.
I think Lights in the first post from Quadratec have integrated side lights. And plugs.
Cutlass327 likes this.
post #14 of 51 Old 10-11-2020, 06:58 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Yes, my 78 has the side markers on the body.
weapon likes this.
Rick
post #15 of 51 Old 10-11-2020, 07:42 AM
agear
Not to hijack the thread but I see they come with a special relay. Can I just buy l.e.d. 1157 s and use that relay
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
