Let's Trouble Shoot this 360! - Page 7 - JeepForum.com
 59Likes
post #91 of 141 Old 08-29-2019, 11:09 AM
pedal2themetai
1956 CJ5
Sorry NOpe.. its cut into the cam itself..
pedal2themetai is offline
post #92 of 141 Old 08-29-2019, 11:13 AM Thread Starter
garet.friedrich
garet.friedrich's Avatar
1979 CJ5
Originally Posted by pedal2themetai View Post
What does the bottom of your distributor look like????
That damage could only be done by stabbing the distributor in and bolting it down with out engauaging the splines . it looks fresh so the last person to put it in, prior to your taking this picture??
good luck
tim
That picture was taken before I ever ran it. So basically I put a new distributor in and it was only somewhat engauging. Which would make sense why I wasn't getting any power right?
Tim, if what you are saying is actually the issue (which I think it is) then you are my hero
pedal2themetai likes this.
79 CJ5
garet.friedrich is offline
post #93 of 141 Old 08-29-2019, 11:15 AM
Fourtrail
1974 CJ6
Uh, what are you taking about? You have to pull the distributor gear to get to the fuel pump cam and the cam timing gear. Yes you can just replace the Cam drive gear.
Cam and distributor gear set.
http://www.partsmike.com/index.php/p...am-gear-amc-v8
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #94 of 141 Old 08-29-2019, 11:19 AM Thread Starter
garet.friedrich
1979 CJ5
Thanks Fourtrail! I was just finding this pic to back that up.
79 CJ5
post #95 of 141 Old 08-29-2019, 11:22 AM
pedal2themetai
1956 CJ5
Great if it is .. You could pull the cap and crank it and see if the rotor is turning evenly.. definitely change oil and filter as all that metal is going to be in the pan and filter..
Now that might not help with compression and with all the metal in there if you could finish the rebuild with barrens/rings.. and be done with it and not have to tare into it again down the line..
good luck
tim
post #96 of 141 Old 08-29-2019, 11:27 AM
pedal2themetai
1956 CJ5
GREAT.. I see that now.. glad I was wrong there..
good luck
tim
post #97 of 141 Old 08-29-2019, 11:29 AM
Fourtrail
1974 CJ6
good luck
tim
Caused by a bad hardened cam gear on a replacement distributor.
post #98 of 141 Old 08-29-2019, 11:34 AM Thread Starter
garet.friedrich
1979 CJ5
For the record that picture was before I ever put a replacement distributor in. It came like that from the PO.
79 CJ5
post #99 of 141 Old 08-29-2019, 11:41 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It might be ONE problem.
But I don't think that distributor gear will have anything to do with his low compression numbers.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #100 of 141 Old 08-29-2019, 11:42 AM Thread Starter
garet.friedrich
1979 CJ5
That is correct, John. I will still be pulling the heads. Also, I should note that none of the head bolts were loose.
thumperjohn151 likes this.
79 CJ5
post #101 of 141 Old 08-29-2019, 11:48 AM
John Strenk
1976 CJ5
Plan ahead by getting a system to keep the lifters and pushrods in the proper order when you pull the heads. Do't just dump them into a box.
post #102 of 141 Old 08-29-2019, 11:54 AM
Fourtrail
1974 CJ6
Good egg carton works well, drop the lifter in the egg holder and a hole in the top for the pushrod to stick through
post #103 of 141 Old 08-29-2019, 12:01 PM
HuntinDog
1979 CJ5
When you pull those rockers and heads, they still have a bolt pattern to follow.
HuntinDog is offline
post #104 of 141 Old 08-29-2019, 12:51 PM Thread Starter
garet.friedrich
1979 CJ5
They need to be removed in a certain bolt pattern?
79 CJ5
post #105 of 141 Old 08-29-2019, 01:03 PM
John Strenk
1976 CJ5
Doesn't mention it in the FSM. Not sure if it makes a difference in those big cast iron heads.
But it couldn't hurt.
