Let the Build Begin - JeepForum.com
 12Likes
  • 2 Post By CJLoad
  • 1 Post By pedal2themetai
  • 1 Post By Nick4320
  • 7 Post By Matt1981CJ7
  • 1 Post By Razorcj7
post #1 of 10 Old 12-06-2018, 09:19 PM Thread Starter
Razorcj7
Razorcj7's Avatar
1980 CJ7
Let the Build Begin
1980 Jeep CJ 7 i6 Auto
Completed
-YJ conversion just completed
-31" BFG AT Tires
-New Carpet
-New Seats
-New Carb
-Full Exhaust incl Cat
Parts Sitting Waiting to be installed
-Side Steps
-Rocker Guards
-Warn Rear Bumper
-Warn Front Bumper
-Window Tint 3 Back windows
-Warn Winch
-Tire Carrier
Labor planned
-Hard Top Paint
-Fender Flares (Black)
-Cut Wax
Should the hardtop be black or grey? What would the factory color be?
Razorcj7 is offline
post #2 of 10 Old 12-06-2018, 09:29 PM
CJLoad
CJLoad's Avatar
Looks great the way it sits Razor. I think black.
STJP and Razorcj7 like this.
Kenny
CJLoad is offline
post #3 of 10 Old 12-06-2018, 10:00 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I think this was a dealer install, not a factory install?
I have seen them in a basic color such as white, a vinyl roof (often brown) and painted to match the vehicle. There is no hard and fast factory rule on your hardtop so go with what you like.
The dark grey is hard to contrast with a color as it is a shade, so I suggest another shade from black through white. a matching grey would look splendid, white a bit odd and black would maybe make it look shorter. I plump for grey to match.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
post #4 of 10 Old 12-06-2018, 10:25 PM Thread Starter
Razorcj7
Razorcj7's Avatar
1980 CJ7
I am not sure if it was a dealer or a factory install, the codes didn't tell me much off the vin and tag.
I was thinking same color grey but maybe 2 shades darker.
Razorcj7 is offline
post #5 of 10 Old 12-07-2018, 04:42 AM
pedal2themetai
1956 CJ5
HI, from what paint I can see it looks like your top was Factory installed (I don't think many built in the 80's would be without a top) and in body color.
good luck
tim
Razorcj7 likes this.
pedal2themetai is offline
post #6 of 10 Old 12-07-2018, 06:22 AM
Nick4320
Nick4320's Avatar
If you are thinking about keeping the hard top black i would suggest restoring it and not painting over it.
https://www.homedepot.com/p/Flood-Pe...4-04/100130893
This stuff cleans up the top well, gets back that black color and gives it a shine
Nick4320 is offline
post #7 of 10 Old 12-07-2018, 07:06 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'd go black on the top. Never cared for the matching colored tops, because they never truly matched. Also, use satin, not gloss. You can rattle can it, but a 2-part automotive paint, specifically blended for fiberglass tops, will last much longer.
Don't paint your fender flares, it won't last more than few months. Trust me. Instead, go to Walmart and pick up some black Kiwi shoe dye. Put 2-3 coats on, allowing to dry completely and buff between coats. I did mine that way almost 2 years ago, and they still look like the pic below.
Good luck,
Matt
Matt1981CJ7 is offline
post #8 of 10 Old 12-17-2018, 02:24 PM Thread Starter
Razorcj7
Razorcj7's Avatar
1980 CJ7
Has anyone done a Winter Camo Wrap on their CJ7? Would love to see pictures.
Razorcj7 is offline
post #9 of 10 Old 07-29-2019, 03:29 PM Thread Starter
Razorcj7
Razorcj7's Avatar
1980 CJ7
Updating my build:
Completed:
-OME Suspension and YJ Conversion
-Exhaust
-Hardtop repaired and painted
-Side Steps
-31" BFG AT/TA KO2
-Most Black parts powder coated
-Window Tint
-New Carb - Cannot seem to get to run correctly so....(Howell FI on order)
Razorcj7 is offline
post #10 of 10 Old 06-12-2020, 09:09 PM Thread Starter
Razorcj7
Razorcj7's Avatar
1980 CJ7
I finally got most of the upgrades completed, never ended up doing the FI as a friend said I should drive it around for awhile before I decide on an engine swap.
Next order of business is Fender Flares, Black Mirrors, LED lights with Black Bezels, Remove some surface rust off some underbody parts and clean in the wheel wells. Looking for stock seats!
cjoffroad likes this.
Razorcj7 is offline
