LED Dash Lights - Page 5 - JeepForum.com
 33Likes
post #61 of 100 Old 01-06-2020, 05:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by uw91 View Post
Has anyone done red with the OPs setup? I loved the red of my Audi and would like to replicate it. Also, I have AC, is that gonna make the swap a pain in the ***??
I would need the following:
6 12v red led lights for the controls
4 red BA9S bulbs for clock, tach, battery, oil
3 red BA9S for speedo
2 green BA9S for blinkers
1 Red BA9S for brake
1 Blue BA9S for brights
1 orange BA9S for 4x4
Would that do the trick? Did I misread the setup?
The light positions have a blue cover over the bulbs so you would have to remove the cover.
Yes, the AC will make it difficult but not impossible.
uw91 likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #62 of 100 Old 01-06-2020, 06:30 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I believe 2700k is the normal incandescent light color, so if you got an LED that color, would you need to worry about the blue color, as that would tint it green like OEM.
Sent from my VS995 using Tapatalk
Rick
Cutlass327 is offline
post #63 of 100 Old 01-06-2020, 10:39 AM
uw91
uw91's Avatar
Thank you. I'm going to need to drop my dash to put the driver side windshield nut back on, so this is probably going to be a non-issue.
I've ordered up all the lights and am excited to get this baby comletely LEDed.
PNW Represent
uw91 is offline
post #64 of 100 Old 01-06-2020, 10:41 AM
backupoffmefoo
backupoffmefoo's Avatar
1981 CJ7
UW91,
Could you post the part numbers and a link to where you bought them? If that info was posted earlier in the thread I missed it.
Thanks in advance...
Sent from my iPhone using Tapatalk
I want my two dollars!
backupoffmefoo is offline
post #65 of 100 Old 01-06-2020, 10:45 AM
uw91
uw91's Avatar
Originally Posted by backupoffmefoo View Post
UW91,
No problemo:
12v LED for controls - https://www.superbrightleds.com/more...dc-led/55/344/
BA9S bulbs to replace factory in speedo and other gauges - https://www.ledlight.com/ba9s-6-led-light.aspx
backupoffmefoo likes this.
PNW Represent
uw91 is offline
post #66 of 100 Old 01-06-2020, 11:30 AM
backupoffmefoo
1981 CJ7
No problemo:
Awesome. Thank you.
post #67 of 100 Old 02-02-2020, 01:36 PM
uw91
uw91's Avatar
Silly question; Do you need the ignition on to see the gauge lights turn on? I got all the bulbs in the gauges swapped out and wanted to test it to see, but nothing turned on. Lights turned on and no matter what I did with the light knob they wouldn't show, leading me to believe I needed to have the ignition on.
I may also have a short somewhere b/c my clock was acting funky as I adjusted my lights.
Think I found my answer since much is connected to the box... Yes, switch matters.
PNW Represent
uw91 is offline
post #68 of 100 Old 02-03-2020, 04:05 AM
John Strenk
1976 CJ5
The Lighting circuit is seperate from the Ignition/Accessory circuit. You should not need the ignition on to see the gauge lights light up.
If you do, something is miss wired or your dash is not grounded.
uw91 likes this.
post #69 of 100 Old 02-10-2020, 09:03 AM
uw91
uw91's Avatar
Attachment 3880965
John, you said I would need to remove the blue covers to get the red tint to show correctly? Along with the other gauges, I imagine.
PNW Represent
uw91 is offline
post #70 of 100 Old 02-10-2020, 09:05 AM
John Strenk
1976 CJ5
Hmm... Didn't think about those..
Doable but not easy to reseal.
post #71 of 100 Old 02-10-2020, 09:32 AM
uw91
uw91's Avatar
It looks like I could maybe (carefully) take a drill bit and bore out the 3 pins that hold it to the gauge. If I don't do that, I'm getting purple gauges, right?
PNW Represent
uw91 is offline
post #72 of 100 Old 02-10-2020, 09:36 AM
John Strenk
1976 CJ5
I think filtering colors is a bit different than adding colors.
Not sure what you get.
post #73 of 100 Old 02-10-2020, 02:40 PM
uw91
uw91's Avatar
I took some needlenose plyers to those little cups and was able to sorta twist/distort them out. I'm simply worried to **** now that I have some wiring issue bc I can't see the lights on when I plug the battery in. Ugghhhhh
PNW Represent
uw91 is offline
post #74 of 100 Old 02-10-2020, 11:15 PM
uw91
uw91's Avatar
Whelp, did some upgrades and though the speedo gauge indicators are bright as hell the other reds are not so bright. I'm almost wondering if I didn't get the lights as far pushed in as I should have? (2nd pic) I know on the gauges I'll have to either go back to my former why lights or I will need to simply get some new gauges from Speedhut or whatever the place is. So frustrating b/c I was excited to see some brighter reds from the gauges.
Side note: I think my wiring is majorly effed. Blinker lights were stuck on (not that I don't have everything put back together) and my light switch doesn't dim these at all. I think I just screwed myself and opened a monster pandora's box.
EDIT: Yup, I effed em up. I have the damn plastic ring facing incorrectly for the dash labels... I need to pull off all the spades and redo them so that the LED is closer to the label. Frick.
PNW Represent
uw91 is offline
post #75 of 100 Old 02-11-2020, 02:12 AM
whollsee
1982 CJ7
Speedo blinker lights stuck on is possibly not enough resistance in the circuit. Had that issue even with an upgraded LED friendly flasher unit. I had replaced all blinker bulbs with LEDs. Ended up leaving the side marker/blinker bulbs incandescent instead of adding resistors. Fixed the problem. Not sure if you changed them all.
uw91 likes this.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
