Leaning lower on Driver's side - JeepForum.com
post #1 of 50 Old 08-23-2011, 06:47 PM Thread Starter
kcarlsonjeep
1979 CJ5
I just installed a 4" bds lift in March. Went from SOA to a spring under.
Anyway after 4 months of driving and a few trail rides the jeep
is a half inch higher on passenger side than driver's side.
Don't really know what would cause this. Any suggestions would
be appreciated.
kcarlsonjeep is offline
post #2 of 50 Old 08-23-2011, 07:27 PM
85LaredoCJ7
85LaredoCJ7's Avatar
Same problem, but OME leafs are only days old....
The Dude abides....
85LaredoCJ7 is offline
post #3 of 50 Old 08-23-2011, 07:39 PM
twinstickd20
twinstickd20's Avatar
1979 CJ7
I'm in the same boat and I also have ome rear springs, maybe the driver side settled first.
My Build Thread
twinstickd20 is offline
post #4 of 50 Old 08-23-2011, 07:46 PM
85LaredoCJ7
Exactly...OME heavy rears all the way around.
The Dude abides....
post #5 of 50 Old 08-23-2011, 07:52 PM
twinstickd20
1979 CJ7
Mine are only a few weeks old, I just wonder if the passenger side will settle and level it out but if not I'll will just deal with the gangsta lean
My Build Thread
post #6 of 50 Old 08-23-2011, 08:03 PM
molsenice
molsenice's Avatar
1964 CJ5
I ended up putting 3/4 in block under the high side (between the axle and spring). 45 bucks for new u bolts, but dead level - money well spent
shim the high side
molsenice is offline
post #7 of 50 Old 08-23-2011, 08:09 PM
heisman01
2015 JK Wrangler
From what ive seen ever cj5 leans on the driver side unless corrected, I remember reading it was a factory issue as in new off the lot leaning.
heisman01 is offline
post #8 of 50 Old 08-23-2011, 08:11 PM
85LaredoCJ7
"F" that....if mine doesn't settle out, I'll be sending the driver's side back.
The Dude abides....
post #9 of 50 Old 08-23-2011, 08:17 PM
heisman01
2015 JK Wrangler
Its more of a frame/body fit issue, I put a 1/2" spacer on the drivers side body mount and it helped it alot.
post #10 of 50 Old 08-23-2011, 08:31 PM
85LaredoCJ7
Mine is kind of excessive at this point.....what is the actual problem? When I look at my front shackles, the driver's side is kicked farther out than the passenger when sitting on level ground.
The Dude abides....
post #11 of 50 Old 08-23-2011, 09:02 PM
afgd1
my 84 does it too, even after 4 inch lift, still does it put inch and half spacer on rear doesnt do it on front was told factory problem also,
afgd1 is offline
post #12 of 50 Old 08-23-2011, 10:09 PM
Blue83CJ7
Blue83CJ7's Avatar
1980 CJ7
My 2 month old rough country 4" does the same...
I have tried breaking in the right side springs by parking it up on curbs at the supermarket and rocks in the driveway, and also hitting the curb (similar to a speed bump) on the right side of my driveway at speed to see if I can get the right side to start sagging more too... Good thing my brakes work.
My wife saw me do it the other day and thinks I am nuts
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #13 of 50 Old 08-23-2011, 10:20 PM
firewalker909
firewalker909's Avatar
I put a 4" SkyJacker lift on my '73 and after 6 months it actually leans to the passenger side. Maybe I should put an OME on the drivers side and level it out.
I really don't mind. It seems to be the character of an old Jeep.
firewalker909 is offline
post #14 of 50 Old 08-24-2011, 04:43 AM
Btowntaz
Btowntaz's Avatar
1980 CJ7
80 CJ-7 with a 1" lean to drivers side. Sounds like the infamous CJ lean. Pretty common from what I have found.
My Jeep build:
Originally Posted by SaskCJ7 View Post
First off, whoever invented Torx bolts should be shot in the face, burned then pissed on.
Btowntaz is offline
post #15 of 50 Old 08-24-2011, 05:01 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm not sure I've ever seen an old CJ without "Jeep Lean". And I've never had a vehicle that didn't get it eventually.
Could it be that the steering components add enough weight to sag the driver's side a little? Dunno.
Now, you guys have me curious if my new OME setup is already showing it. I'll have to check.
Hey 85Laredo, do you have a front-on pic of your rig? We could compare to see if there's truly something amiss with yours.
Matt
Matt1981CJ7 is offline
Leaning drivers side rear shackle, HELP PLEASE Strings72 Jeep CJ Forum 16 03-20-2011 09:19 PM
Jeep leaning to one side ScoobyDooJeep Jeep CJ Forum 15 09-29-2010 01:26 PM
CJ7 leaning towards driver's side CALOcruiser Jeep CJ Forum 7 02-27-2010 09:50 PM
Different size front wheel cylinders on driver's side and passenger's side ariasbunch Jeep CJ Forum 3 07-13-2009 12:46 PM
Off kilter on the driver's side DonQuixote Jeep CJ Forum 9 05-08-2006 08:25 AM
