Leaking a.c. compressor - JeepForum.com
post #1 of 9 Old 06-03-2020, 01:33 PM Thread Starter
agear
I have aluminum threads on my a.c
(Long story short )Sanden compressor that I messed up . Its leaking compressor oil now. I'm guessing thread sealant is a no go for an a.c. system. Is there anything I can do ? I guess they're pipe threads ???? I'd have to figure out what threads they are and buy a die. You know how aluminum is - very flaky.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 9 Old 06-03-2020, 02:29 PM
Fourtrail
1974 CJ6
Which compressor cylinder head is it? Probably easier to just replace the bad head.
https://www.acparts.com/product-cate...en/back-heads/
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 9 Old 06-03-2020, 02:47 PM Thread Starter
agear
http://www.acparts.com/product-categ...en/back-heads/
M or K. That's not bad. What happens when you take the head off ? Granted the refrigerant will be evacuated and you'll have to put a vacuum on it after. Will a bunch of oil come out ?
agear is offline
post #4 of 9 Old 06-03-2020, 03:05 PM
Fourtrail
1974 CJ6
Good video on replacing the compressor head
post #5 of 9 Old 06-03-2020, 03:23 PM Thread Starter
agear
Heck yeah except I think I might have to take the compressor off to do that .I have to make sure the head is mounted on the back end and not top side. If it's just on the back I'll have to take it off or oil will spill everywhere.
agear is offline
post #6 of 9 Old 06-03-2020, 10:19 PM
RedNeckCorvette
1979 CJ7
I wish I understood code?
srd ot offbto DC o that .I have to make sure
RedNeckCorvette is offline
post #7 of 9 Old 06-03-2020, 10:42 PM Thread Starter
agear
Sorry I edited the previous post
agear is offline
post #8 of 9 Old 06-04-2020, 02:33 PM Thread Starter
agear
My head is mounted vertically so I'd have to remove the whole compressor to replace it. I could do it . But of I can use a sealer that would be good.
agear is offline
post #9 of 9 Old 06-07-2020, 02:23 AM Thread Starter
agear
I found the problem. The o-ring was shaved s little The compressor head's male fitting threads had a big chip where the o-ring sits but there was still meat on there for the o-ring to sit . So I was just careful tightening it down -we shall see.
agear is offline
