Leaf Spring Help - JeepForum.com
 3Likes
  • 1 Post By BagusJeep
  • 1 Post By bruinjeeper
  • 1 Post By devildog80
post #1 of 10 Old 10-27-2021, 06:10 PM Thread Starter
davcono
davcono's Avatar
Leaf Spring Help
I have an 84 CJ7. I am pretty sure the springs are factory. I am running 31s and Bilstein shocks. The Jeep sits nicely, and I do not off-road. Also, I only use a bikini top. My rear springs are sagging on the left side so I would like to replace the rear pair. I count 7 leaves. (6/1?). I'm guessing the Jeep came with a hard top, but I really don't know. I found the chart below on line. I'm guessing the 6/1, 900 lb springs were for a Jeep with a hard top. Just wondering if I go to a 4 leaf, will I get a softer ride without affecting ride height? What would you recommend for replacement springs? Would appreciate any advice.
davcono is offline
post #2 of 10 Old 10-27-2021, 06:44 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Check here:
https://www.generalspringkc.com/leaf...-dj/1976-1986/
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #3 of 10 Old 10-27-2021, 09:10 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
You have a Chevy 350 up front, an AX15 trannie, some built axles and little else. That puts you in the category of an I6.
When Jeep turned out your Jeep they used many different springs. A short list to give you an idea:
I4 - Without hardtop - light duty - 4 leaf
I6 - Without hardtop - light duty and Limited Soft Ride - 5 leaf
I6 - With hardtop (and most common on all CJs) - 6 leaf
V8 - Without hardtop - light duty - 6 leaf
All - heavy duty - 7 leaf
All - extra heavy duty - with full wrap on ends - 9 leaf
If I was lightly loaded and looking for a smoothish ride then 5 leafs and toss the heavy duty springs.
254Triple likes this.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #4 of 10 Old 10-27-2021, 09:23 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
even with all the cross referencing, no chart can give you a level ride height due to the fact of the uncontrolled variables (time +usage on your current sets). I would just spring for (pun intended) an entirely new set of 4 to be sure you end up level.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #5 of 10 Old 10-28-2021, 08:40 AM Thread Starter
davcono
davcono's Avatar
Originally Posted by Hurricane4 View Post
Let me pose another question. In measuring I am finding about a 1/2 to 3/4 inch drop on the left side. Is it possible that over time there is a bit of a twist in the frame that would account for that and that replacing springs is a waste of time and money?
davcono is offline
post #6 of 10 Old 10-28-2021, 09:07 AM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Jeep Lean ???
https://www.cj-8.com/threads/jeep-lean-thoughts.50161/
Winston Churchill
post #7 of 10 Old 10-28-2021, 09:10 AM
Axhammer
Axhammer's Avatar
My All original suspension leans to the left slightly, it is common. I guess there was a recall by AMC years ago, but I’m not familiar with what years it applied to.
I can say this, the flat bracket for the steering stabilizer that goes under the drivers side axle perch, acts as a shim to make the Jeep lean to the drivers side from day one. The recall involved shimming the passenger rear spring perch, so it was just a band aid approach to fixing the problem.
If I was in your shoes, I would replace all fours springs, and make a shim for the passenger front spring perch, and install it during the spring swap. If it still leaned to the drivers side, I would shim the passenger rear perch to fix it, the way AMC did it back in the day.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #8 of 10 Old 10-30-2021, 09:44 AM
Feray1948
When I studied mechanical engineering at university, we had to solve similar problems. This helps me now to understand more about how the car works and what is best for it. I often ordered on https://uk.edubirdie.com diagrams and detailed explanations in the form of essays for papers. I can recommend that you fix this by using the coil pads on the right coil, which has the slackest, or on both of the right coils, for example, 1 inch. To do this, measure the left and right coils from where they are to the frame to find out how much their slope is. Then you can get spacers closer to the amount.
Feray1948 is offline
post #9 of 10 Old 10-30-2021, 10:34 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
As the story goes, AMC built hundreds of CJs on frames that were twisted due to improper shipping methods. The result was a noticeable lean to the driver's side, which got labeled as "Jeep Lean".
They issued a recall on it. Their bandaid fix was a 1/2" shim on the rear passenger spring perch, as Axhammer said.
Some guys have gone to the extreme of cutting and re-welding the frame to straighten out their Jeep Lean, but it's a pretty involved repair. Google "Jeep Lean", and you will get more info than you will care to read.
Matt
Matt1981CJ7 is offline
post #10 of 10 Old 10-30-2021, 11:57 AM
devildog80
devildog80's Avatar
1981 CJ5
Get a bigger "Shotgun", and the lean will level out.
Axhammer likes this.
'81 CJ5, 258 I6, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31
devildog80 is offline
