Joe's CJ-7 restomod build - 1984 - 350ci - Page 4 - JeepForum.com
 8Likes
post #46 of 99 Old 06-09-2019, 07:51 PM Thread Starter
CJ7 Joe
Well I got ahead of myself and mounted the tub. Then I realized I should really have cleaned it better! I think because I’m doing a mock-up then remove and paint, I didn’t think it was a big deal. But after mounting the tub, I couldn’t stand the dirt and grease on the tub on the restored frame and drivetrain. So off if came!
While I had it off if scrubbed 95% of the gunk off the bottom. Then I used a wire wheel on a drill and cleaned up all the bare metal. Windshield hinge area, door hinges, tailgate hinges, and the firewall areas where the battery box mounts. Then I spray painted it just to hold off rust till it gets final strip and paint.
The next posts are going to be a ton of pics of the tub, but I want to document the condition. The only rust I can find at all is under the roll bar mounts.
87676B63-1ED4-4908-8318-BBA82A12B75D_1560128020867.jpg   BAAE9193-8D0E-49E7-9FC5-BA918996D6EA_1560128041606.jpg   6B8A79E0-0A05-4EB4-8B6E-8E6531167F00_1560128058303.jpg   521CD959-3B2E-4BD0-8335-B21E6CEE3B03_1560128072794.jpg   CAAA044C-A39D-47CA-92BD-C2A8E90C48B7_1560128088620.jpg
CJ7
CJ7 Joe is offline
post #47 of 99 Old 06-09-2019, 07:57 PM Thread Starter
CJ7 Joe
More tub pics
300590A9-796F-44D1-A9B9-A2B277AD1919_1560128146301.jpg   265F0B04-4C47-43AF-BC17-DFE1CB19908B_1560128161880.jpg   0B452774-50DD-42C7-A264-3B980D209318_1560128182862.jpg   60AC24C1-6613-4874-8037-EA1ADC102669_1560128198375.jpg   3F6DC37B-14F1-41D1-BAA6-6A686BFEB520_1560128213968.jpg
CJ7
CJ7 Joe is offline
post #48 of 99 Old 06-09-2019, 07:59 PM Thread Starter
CJ7 Joe
And more tub pics
99C9BE72-337A-4A38-AA0D-F2920211EAD0_1560128262097.jpg   ADE8739F-6823-4DF4-B7C0-4C085157DB7A_1560128276682.jpg   4403B6A6-9D25-47A7-8AC4-20436E7CDFBD_1560128290845.jpg   ABA8CAA1-DF66-458A-9587-FDAF34F4786D_1560128305252.jpg   F1F01CE1-8581-4EB5-8D38-0162BEB4D694_1560128325500.jpg
CJ7
CJ7 Joe is offline
post #49 of 99 Old 06-09-2019, 08:00 PM Thread Starter
CJ7 Joe
And more tub pics. Under the roll bar areas.
BFD39ADA-E99D-4AA8-A0AD-6739662F4758_1560128374507.jpg   84E9FF15-4582-43D2-A665-1105CF880467_1560128391175.jpg   D9F7B218-4A79-4E75-A99B-1F4BBA55CFAD_1560128407687.jpg   A8013C91-974C-4DD2-9597-D12BA5F6797C_1560128423203.jpg
CJ7
CJ7 Joe is offline
post #50 of 99 Old 06-09-2019, 08:02 PM Thread Starter
CJ7 Joe
And finally, the tub back on the frame! I’m going to name the CJ “Spot”. Sounds appropriate!
4953BC85-13D2-44BF-8B43-BE390DDA7DB7_1560128519898.jpg   D9AC5CCD-4180-462F-8633-A338115E7961_1560128534409.jpg   CD6ADC8F-8F9F-47A4-8BAA-064FD988A08C_1560128546209.jpg   B9798B7A-9147-4E24-836D-AF8DAE035134_1560128558022.jpg
CJ7
CJ7 Joe is offline
post #51 of 99 Old 06-10-2019, 05:05 PM
MetalMountainGoat
MetalMountainGoat's Avatar
That tub appears to be in pretty good shape. Shouldn't have too much rust repair to do on it.
MetalMountainGoat is offline
post #52 of 99 Old 07-07-2019, 07:08 PM Thread Starter
CJ7 Joe
Today the engine got cleaned up, then the fenders and grille mounted. Hoping to start her back up soon but I needed to get the radiator mounted. Next is installing the tranny cooler.
I do have to remove the drivers fender just to trim my motor mount. With the engine shifted towards drivers side, the mount barely touches the fender.
9F9BF063-00B3-4FAE-9328-C26AFD84C0BA_1562544390239.jpg   F1F98DFA-DB34-4954-A11F-AE42F0AA68B9_1562544415867.jpg   5AA745E2-F637-477F-9C40-A969A084993B_1562544429769.jpg
CJ7
CJ7 Joe is offline
post #53 of 99 Old 07-20-2019, 06:28 PM Thread Starter
CJ7 Joe
Initial run with 700R4! Got the tranny cooler installed permanently. The lines are ran but just held into place with zip ties. I still have to put the p-clamps on. But I was able to run the tranny for the first time and do the initial fill up! I’m pretty excited! I doubt I’ll have it running again for a little bit as I plan to tidy up the tranny lines then work on installing the steering column and the master cylinder.
303FB3A3-5232-4BE5-A78C-D698F601694B_1563665274814.jpg   9F8D00A8-4941-4E4B-BA9C-04C27131E1F5_1563665290182.jpg
CJ7
CJ7 Joe is offline
post #54 of 99 Old 07-20-2019, 06:33 PM Thread Starter
CJ7 Joe
Video of run.
https://youtu.be/W7XmVziaBGk
CJ7
CJ7 Joe is offline
post #55 of 99 Old 08-09-2019, 02:20 PM Thread Starter
CJ7 Joe
Haven’t done much lately besides installing the windshield with new cowl seal, wipers installed with linkage greased and new pivot covers, and everything tested.
After that I decided to clean up the axle covers and polish the wheels. They were so dull and I figured I’d polish them up to give a boost to the appearance and hopefully also my ambition level. I need to get moving on it more, been slacking off.
24309BE5-B60B-4BAB-B085-81940FFC002B_1565378420338.jpg   60737C39-1428-4A45-B9E7-C38942A8E737_1565378442155.jpg
CJ7
CJ7 Joe is offline
post #56 of 99 Old 08-09-2019, 03:29 PM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
The wheels cleaned up nice. Hopefully that is what you needed to get back to work.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #57 of 99 Old 08-25-2019, 06:23 PM Thread Starter
CJ7 Joe
Today I got a bit done on the CJ. I permanently mounted all the transmission cooler lines. Took all day lol. I had to make brackets with the correct angles, then avoid where the exhaust will be, then jump from the engine to the frame with the run. Then I mounted along the frame and up next to the radiator. The tranny cooler is mounted completely independent of the radiator allowing one or the other to be removed without taking the other out as well. Also they are mounted so the fenders can be removed independently as well. No p-clamps on the fender or grille!
11EA73D6-B004-4A15-9BE1-4E38019F7992_1566775344239.jpg   372E0536-86FD-40B3-84BE-332A8FF890AE_1566775369776.jpg   F70297DB-C0A4-4847-B800-A8FA9ED8AB47_1566775383507.jpg   C57A3FB3-0898-432E-84CF-76D4DE056613_1566775398967.jpg   4681645F-AA55-44C8-A6E9-89096B23FDAC_1566775411803.jpg
CJ7
CJ7 Joe is offline
post #58 of 99 Old 08-25-2019, 06:29 PM
MetalMountainGoat
Super clean install on the lines. Hell super clean jeep all together.
post #59 of 99 Old 08-25-2019, 06:32 PM Thread Starter
CJ7 Joe
I’m backtracking a little bit in time as I forgot to post this. But I did the windshield install. I painted the tub and the windshield frame where the hinges would touch. I painted underneath the hinges. Then I mounted everything with stainless steel hardware. Also greased up the windshield wiper linkage and mounted the motor. Added some new wiper gaskets and new windshield wiper blades. Also added a new seal between the windshield and tub. Also mounted the sun visors. Most of this has new stainless steel hardware that came with the kit but there are a few areas that I had to use the old screws. Remember this is all coming back apart for final paint later on down the road.
20E9F55A-11F0-4576-951D-B38FE3B1108B_1566775912598.jpg   D897B2AA-7DBE-4A9F-A4C9-62663E233E9F_1566775925330.jpg   9969976D-A88C-40F0-A6D1-10BE20CA9EB8_1566775935822.jpg   1D8CE7FA-8DA0-43BA-A39B-59B43B141B89_1566775946749.jpg   D6A9E3BB-8E4D-465A-A221-80CAD5D0462E_1566775959096.jpg
CJ7
CJ7 Joe is offline
post #60 of 99 Old 08-25-2019, 08:02 PM Thread Starter
CJ7 Joe
Thanks! I appreciate it. I’m trying to go slow and get it right.
CJ7
CJ7 Joe is offline
