Joe's CJ-7 restomod build - 1984 - 350ci - Page 2 - JeepForum.com
 8Likes
post #16 of 99 Old 12-27-2018, 09:18 PM Thread Starter
CJ7 Joe
Well today was a good step forward! Finally decided to take the leap forward to swapping in an automatic tranny! My good friend stopped over and helped me out and we removed the Dana300 and the SM465! Also removed the bell housing and the clutch and pressure plate!
CJ7
CJ7 Joe is offline
post #17 of 99 Old 12-28-2018, 08:00 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
What auto are you planning to use?
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #18 of 99 Old 12-28-2018, 09:41 AM Thread Starter
CJ7 Joe
Going to go with a 700R4. I’m hoping that will be a great choice for cruising! It has a 350 sbc with 33” tires and 4:10 gears.
I do realize the front driveshaft will be close to the pan but will work that issue once I get to it. Some have had no issues so I’m hoping!
CJ7
CJ7 Joe is offline
post #19 of 99 Old 01-02-2019, 12:52 PM
EricRThompson
1979 CJ7
Great find! Looks like all the parts are in great shape. Is that an original frame? Looks brand new.
EricRThompson is offline
post #20 of 99 Old 01-03-2019, 07:55 AM Thread Starter
CJ7 Joe
It is the original frame - its solid no rust. The only issues were the tub, which actually wasn't "too bad". But since I cant do metal fab, I sold it and bought an almost rust free OEM one from the same year. The rest of the body is fine.
I ordered the 700R4 tranny and other goodies from NOVAK - so I'm excited waiting for them to come in!
CJ7
CJ7 Joe is offline
post #21 of 99 Old 01-03-2019, 03:14 PM
EricRThompson
1979 CJ7
Where did you find the tub?
post #22 of 99 Old 01-03-2019, 03:53 PM
Flyrod04
Flyrod04's Avatar
sweet build! I will have the same running gear in mine, 350 with the 700R4. I had to do a full frame swap, then i will be ordering from Novak for the tcase adapter.
i am excited to see how your build goes!
Flyrod04 is offline
post #23 of 99 Old 01-03-2019, 05:46 PM Thread Starter
CJ7 Joe
The tub came from Rudy's. Post 3-7 show the tub removal and new tub purchase! Rudy happened to have a 1984 tub so I was pumped to have the correct OEM metal.
CJ7
CJ7 Joe is offline
post #24 of 99 Old 02-05-2019, 06:16 PM Thread Starter
CJ7 Joe
Today the 700R4 came in from Novak. It’s the stage 2 build. Also ordered the adapter and a new input shaft for the D300. Also a twin stick for the D300 and a Lokar 12” for the tranny. Shifter boots, tunnel cover, tranny cooler. Pretty excited to start some more work if it ever gets warm.
I think next step is pilot bearing removal and identification and ordering a new flex plate.
02564BC6-ECED-4C0D-8E13-82B31EB0BE46_1549412127501.jpg   4FD6CA23-4592-40AC-A1CB-C17AD757B658_1549412150983.jpg
CJ7
CJ7 Joe is offline
post #25 of 99 Old 02-13-2019, 11:04 AM Thread Starter
CJ7 Joe
Well last night I finally got the new flex plate mounted up. It was a $60 JEGS SFI rated flex plate. Used ARP bolts and proper thread locker and torques. This thing is warped like crazy!!! Off it comes - getting shipped back to JEGS. If you ever install a new auto tranny - CHECK YOUR RUN-OUT before you mount up the tranny and ruin it!
NOVAK recommended a ATI Z-111 which is less than $20 from Advanced Auto. I guess thicker isnt always better. I'm picking up the standard duty one tonight for try two!
CJ7
CJ7 Joe is offline
post #26 of 99 Old 02-13-2019, 11:48 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
That's pretty crazy. Can you see the warp if you lay it on a flat surface?
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #27 of 99 Old 02-13-2019, 12:23 PM Thread Starter
CJ7 Joe
It wasn’t too bad on the countertop. I think the stamped center part is not welded in parallel with the outer gear ring. Just a guess. It just frustrates me that money gets you crap anymore. Where is quality control on aftermarket parts?
CJ7
CJ7 Joe is offline
post #28 of 99 Old 03-20-2019, 02:48 PM Thread Starter
CJ7 Joe
Well the 700R4 is in!! I finally got a good flywheel. It’s very flat on runout. Installed new flywheel, checked starter engagement, then I installed the 700R4. Needed 0.090 shims and longer bolts bolting the torque converter to the flywheel so I could keep the converter forward movement within spec. 3/16” is max and I was at 1/4. With the shims that brought me below 3/16”.
Next I had to swap out the Dana300 input shaft with a new Novak shaft to match the 700R4. Then the Dana300 bolted right up! It’s pretty far aft.
Driveline angles and driveshaft configurations should be interesting!
EE0E03A3-98B5-453C-8BA3-1D0274B99C6F_1553111127292.jpg   27C602D3-A0D8-469B-BE2E-2CB5706C2AA4_1553111140447.jpg   7322C060-4CF0-4F53-B253-5C7A8E8FFD6E_1553111154674.jpg   067E2119-D00F-45FD-A7C6-9ABB07A4A21B_1553111167341.jpg
CJ7
CJ7 Joe is offline
post #29 of 99 Old 04-13-2019, 10:03 PM Thread Starter
CJ7 Joe
Well I have not added to the post in a bit so here are a few upgrades. First the pulleys on the 350 would not line up and it bugged me. It seemed that both the alternator and the power steering pump were further forward than the crank and water pump pulleys. I struggled with this a bit and finally decided a pulley shim kit was the best option. I shimmed out both the water pump pulley and crank pulley. Now all the belts seem to align!
CJ7
CJ7 Joe is offline
post #30 of 99 Old 04-13-2019, 10:10 PM Thread Starter
CJ7 Joe
Next step was to replace the crappy bellhousing bolts with ARP bolts! Simple swap but I really wanted ARP on this bellhousing to engine block setup. Torqued to 45 ft lbs per ARP instructions.
CJ7
CJ7 Joe is offline
