Jeep died after fill up (fuel fitler) - JeepForum.com
 3Likes
post #1 of 43 Old 05-01-2019, 05:15 PM Thread Starter
MetalMountainGoat
Took the jeep on it's maiden voyage today, and everything was all good until I filled it up. Filled it up, and made the turn out of the gas station, and it died. Fuel pump runs just like it supposed to, but will not start. Runs if I pour gas in the carb. Is this a fuel filter problem. I am thinking that maybe I stirred up some crap in the bottom of the tank when I filled it up and caused this. I am going to change the filter tomorrow and see what happens. Any suggestions would be great?
My Jeep has a 350 SBC with electronic fuel pump.
MetalMountainGoat is offline
post #2 of 43 Old 05-01-2019, 07:52 PM
Fourtrail
1974 CJ6
In-tank pump or external? carb or fuel injected? does it pump out fuel if you disconnect the fuel line and run the pump?
trailhead2004 likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 43 Old 05-01-2019, 10:32 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Try emptying the filter on to your hand, Give it a good tap.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 43 Old 05-01-2019, 11:28 PM
ddawg16
ddawg16's Avatar
Need more info.
Where is the fuel pump? Electric pumps are better pushers than pullers.
Carb or FI?
What did you do with the return line to the tank?
Does it make a difference if the gas cap is on or off?
ddawg16 is offline
post #5 of 43 Old 05-01-2019, 11:42 PM Thread Starter
MetalMountainGoat
It is carb. Pump is edelbrock electric pump located on the inside of the driver frame rail right in front of the tank. Have not removed filter yet, but I suspect it is the culprit. I am not sure how the return is ran (if it even has one). PO installed pump, I simply rewired it correctly with painless relay kit. Removing filter tomorrow to see if I have pressure at the filter.
post #6 of 43 Old 05-02-2019, 12:04 AM
ddawg16
ddawg16's Avatar
That is not a bad position. Mine is on the cross member in front of the tank.
The filter should be 'before' the pump.
I would take off the gas cap and try it.
Your gas tank has 3 lines going to it.
Fuel pickup.
Fuel return.
Vent - which goes to the charcoal canister....which I'm betting is not hooked up.
That vent is real important. And hurts nothing....and helps a lot.
My money is on a venting issue. If you pull the gas cap off and it starts pumping gas.....then you have a vent problem.
ddawg16 is offline
post #7 of 43 Old 05-02-2019, 09:59 AM Thread Starter
MetalMountainGoat
Removed carb line and ran pump. Fuel is getting to carb. Put line back on and poured a little gas in carb and it fired up and ran like normal. Did have some blye/white smoke. What could be going on?
post #8 of 43 Old 05-02-2019, 10:16 AM Thread Starter
MetalMountainGoat
Found out another thing. If I remove the gas tank cap, it wont start again. I have to pour fuel into the bowls to get it to start. As long as I dont remove the cap, it starts and runs as many times as I turn the key. But as soon as I remove the cap and put it back, no start.
post #9 of 43 Old 05-02-2019, 10:16 AM
ddawg16
ddawg16's Avatar
Black smoke is rich fuel (flooded)
White/Blue is typically water and/or oil. You might have a leaky valve stem seal.
Run it for a few miles then pop the plugs out and look at them.
ddawg16 is offline
post #10 of 43 Old 05-02-2019, 03:34 PM
LumpyGrits
Cj
Make sure the fuel line hose clamps really clamp and the fuel line isn't cracked.
Sounds kinda like the pump is pull'n in air from somedangplace.
Check the pump's fuel PSI.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #11 of 43 Old 05-02-2019, 03:47 PM Thread Starter
MetalMountainGoat
I drove it for over an hour today, and it ran like a top. Seems to be some kind of venting issue/carb loosing prime when I open the fuel filler neck. Doesn't have any problems until then.
I am going to drop the tank to put in a new sending unit as soon as I run this tank dry. I will check everything at the tank then.
post #12 of 43 Old 05-02-2019, 03:55 PM
Fourtrail
1974 CJ6
First to check is the float bowl level, just taking the cap off and putting it back on won't drain the fuel (if the bowls are full) and cause the Jeep to not start/run only a few seconds. When you pull the fuel line from the carb, how strong is the fuel output with the pump on? If you put your finger over the outlet does it build pressure? Taking the cap off may release the small amount of pressure that is in the tank and cause the pump to loose prime and dumping fuel in the bowls is filling them up enough to get the jeep running until the pump regains prime. Ideally the pump should be at/below the fuel level and if it is mounted high on the frame rail, that can be part of your issue.
post #13 of 43 Old 05-02-2019, 03:58 PM Thread Starter
MetalMountainGoat
I don't think it's mounting location has anything to do with it. This Jeep has ran started and ran everytime I've turned the key until yesterday. The pump may be loosing prime, but it sure wouldn't re prime without a little help yesterday. Right now it is running great, but I am going to have to figure this issue out soon.
post #14 of 43 Old 05-02-2019, 04:38 PM
LumpyGrits
Cj
Hope your exhaust pipe is on the other side from the FP.
LG
post #15 of 43 Old 05-02-2019, 05:00 PM
Fourtrail
1974 CJ6
Ah, guess we have different definitions of maiden voyage then.
1983 CJ-7 258ci Fuel Delivery Problems Jeepdad2830 Jeep CJ Forum 5 04-03-2019 10:14 PM
Jeep 4.0 I6 engine crank no start, no spark, no Fuel Ridettu21 Jeep CJ Forum 11 02-19-2019 03:39 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Adjustable FPR and cross flow fuel rail on the cheap Cobra Jeep YJ Wrangler Technical Forum 6 12-30-2018 07:22 AM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
