Jeep control issue - JeepForum.com
 3Likes
post #1 of 16 Old 01-07-2020, 07:25 PM Thread Starter
Nolan3838
Nolan3838's Avatar
I recently purchased an 85 CJ7. The Jeep also had a Cummins 4BT swapped in along with some beefed up running gear and is sitting on 39” tires. My issue is that when I’m accelerating the Jeep pulls one way, when I let off the throttle it wants to pull the other way suddenly. I have to jerk the wheel just to stay going straight. This doesn’t seem like a front end issue at all. There is obviously a lot more torque coming from the 4BT and was wondering if this could be causing a good deal of axle wrap. Would Axle wrap cause this sort of drastic control issue? Would torque bars/ladder bars resolve this? Thanks in advance
Nolan3838 is offline
post #2 of 16 Old 01-07-2020, 07:37 PM
MrButterfield
MrButterfield's Avatar
1976 CJ5
Right off the bat, I'd check to make sure my spring perches, axle u-bolts, bushings, bearings, etc were all in order in the rear end. You shouldn't be getting any torque steer from a rear axle. I cant imagine axle wrap causing the conditions you mention.
Cutlass327 likes this.
MrButterfield is offline
post #3 of 16 Old 01-07-2020, 07:38 PM
BrutusBlue
1982 CJ7
Does it pull hard to the left when you accelerate and then want to return to the right when you let off? I would say that this is not axle wrap is rather just strong torque. Does it do this only under hard acceleration? What is your suspension set up like? Axle wrap should produce a noticeable bounce or vibration feeling type grab under hard acceleration. Are you spring over?
BrutusBlue is offline
post #4 of 16 Old 01-07-2020, 07:40 PM
skizriz
skizriz's Avatar
1978 CJ7
Rear locker?
Cutlass327 and cjoffroad like this.
skizriz is offline
post #5 of 16 Old 01-07-2020, 07:42 PM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
I would think it would be a loose suspension part rather than axle wrap. From your profile picture, it looks like you have a spring over which is going to have wrap, but I wouldn't expect that to cause steering issues. Does it have a locker or a spool in the rear?
Terry Howe
'49 Willys CJ-3A
TerryHowe is offline
post #6 of 16 Old 01-07-2020, 07:46 PM Thread Starter
Nolan3838
Nolan3838's Avatar
Originally Posted by skizriz View Post
Rear locker?
It does in fact have a Detroit locker. I completely forgot to mention this
post #7 of 16 Old 01-07-2020, 07:47 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Are your engine and transmission mounts in good condition?
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #8 of 16 Old 01-07-2020, 07:49 PM Thread Starter
Nolan3838
Nolan3838's Avatar
Yeah they are
post #9 of 16 Old 01-07-2020, 07:50 PM Thread Starter
Nolan3838
Nolan3838's Avatar
Yep locker in the rear
post #10 of 16 Old 01-07-2020, 08:02 PM
Cutlass327
Cutlass327's Avatar
1930 CJ2
Make sure the tire pressures are equal, and tread depths are equal. I can tell when one tire is lower psi (slow leak somewhere) in the rear because I get that rear shift when I accel/decel with my locker. Seems the difference in diameter makes it more noticeable.
Rick
1978 CJ5 5.0HO/T177/D300 TerraLow 4:1 kit, '86 D30/D44 3.54 WT axles w/Aussies, 'glass body, 33x12.5 ProComp A/T, TDK galv'd frame, 2.5 OME YJ lift - DD and weekend toy
Cutlass327 is offline
post #11 of 16 Old 01-07-2020, 08:05 PM Thread Starter
Nolan3838
Nolan3838's Avatar
I could definitely see how that would be the cause. Pretty sure that is. I’ll check tire PSI on both tomorrow and see if that helps. Thanks for the input
post #12 of 16 Old 01-10-2020, 01:31 PM
Tinker0000
If the tire pressure is good, I'd check for a possible broken axle on the left rear. The locker would be compensating as if the wheel was on ice or muddy slop.
Tinker0000 is offline
post #13 of 16 Old 01-11-2020, 11:05 PM
LumpyGrits
Tire diameter must be equal to reduce torque steer.
DL's are well known for this.
Gary
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #14 of 16 Old 01-13-2020, 08:07 PM
ctorj
1977 CJ7
If you can Post a picture of the steering linkage.
About 4 years ago when I had my 4bt in my cj7, I had the same issue when I turned the fuel up and got on the gas pedal hard. My issue was the driver side up the jeep was lifting and made the jeep pull one way when i got on the throttle hard. It ended up being the steering.
ctorj is offline
post #15 of 16 Old 01-13-2020, 09:10 PM
backupoffmefoo
backupoffmefoo's Avatar
1981 CJ7
I had some scary control issues in mine for a while. It wasn't exactly the same as you are describing... but to fix it I ended up replaced almost all the steering. The culprit ended up being that my steering gear box was loose. Tightening that up and adding a steering gear box brace finally fixed it for me. Runs straight as an arrow off the line now and will do 75 mph on the hwy if needed.
I want my two dollars!
backupoffmefoo is offline
