Jeep CJ- Lighting Upgrade Installation - Page 2 - JeepForum.com
 33Likes
post #16 of 93 Old 02-19-2014, 08:58 PM
cw05
That is a very nice result based on your pre and post pictures! Thanks for writing this up. I have two questions:
1. Is there any point in replacing the OEM light harness at the same time to make sure the wiring is updated from the switch to the relay?
2. What is the advantage of this Daniel Stern prefab relay vs. another popular one that people from this forum have used as there seems to be a wide gap in cost?
http://www.ebay.com/itm/290956459559...84.m1423.l2649
Thanks again for simplying what can otherwise seem like a daunting task to some of us.
cw05 is offline
post #17 of 93 Old 02-19-2014, 09:18 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
1. The relays don't require a lot of voltage from the switch, so its not necessary to replace the factory wiring from switch to relays, unless it's in bad shape.
2. The advantage is high grade components and a harness that is custom made for a CJ.
Matt
Matt1981CJ7 is offline
post #18 of 93 Old 02-20-2014, 05:36 AM Thread Starter
Matt1981CJ7
1981 CJ7
I should add, I definitely paid a premium for my lighting package by going thru Daniel Stern. After doing a few searches, it appears he puts a healthy markup on all the bulbs and harnesses.
I also found out Daniel has the harnesses made by a company called Susquehanna Motorsports in PA., and you can buy directly from them, eliminating Daniel's markup.
Overall, I probably paid 25% more then I would have if I shopped around and pieced the package together myself. I guess that's the price for convenience.
Aside from that, I'm very pleased with the upgrade. I took the Ol' Girl for a spin late last night and couldn't believe the improvement. It left me wondering why I didn't upgrade years ago.
Matt
post #19 of 93 Old 02-20-2014, 06:04 PM
ben_badassjeeps
ben_badassjeeps's Avatar
I just ordered a similar kit from Daniel for my JK. I too went for the Cibie's with the Narva 100/55W combo... after looking at your before and after shots, all I can say is WOW. Can't wait to install this. Pricey perhaps, but he has to make a living too and his knowledge and expertise has to be worth something too.
Ben Whitney, Owner
Boss Research Inc.
Phone: 778-435-2169
E-mail:
Website:
Use the coupon code: "jeepforum2014" for a 5% discount on all of our Currie Enterprises, Genright Offroad, RiverRaider Offroad and RCV Performance Gear!
ben_badassjeeps is offline
post #20 of 93 Old 02-20-2014, 06:09 PM Thread Starter
Matt1981CJ7
1981 CJ7
Agreed.
Paying a extra hundred bucks, or so, doesn't kill me. And the convenience of a one-call plug and play solution makes it well worth it, IMO.
Matt
RedNeckCorvette likes this.
post #21 of 93 Old 02-20-2014, 07:32 PM
78FordF150
78FordF150's Avatar
1983 CJ7
Nice write up. I'm going to have to put this on my to do list.
Thanks
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #22 of 93 Old 02-21-2014, 01:14 AM
chet44
Saved to favorites!
Definitely doing this when the weather breaks.
chet44 is offline
post #23 of 93 Old 02-21-2014, 05:59 AM Thread Starter
Matt1981CJ7
1981 CJ7
Thanks for the kind words, gentlemen. I'm glad I may have inspired a few of you.
This was probably one of the simplest and most effective upgrades I've made to my CJ. And it made my heap safer. I guess I never realized just how bad CJ lights are, until now.
Another nice feature is this upgrade doesn't alter the factory wiring. It can easily be disconnected and returned to the original configuration, if needed, tho I can't imagine why someone would do that.
Matt
post #24 of 93 Old 02-21-2014, 08:21 PM
mvigo
mvigo's Avatar
Nice job once again Matt. If you have the time folks, you can save a few extra $$'s and buy the parts only from Daniel Stern and build the harness yourself. That also gives you the luxury of placing the relays/fuses where they would best suit your needs. Either way, Daniel's parts are top shelf vs. the "cheaper" crap out there...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #25 of 93 Old 02-23-2014, 09:10 AM
Pirate40
Pirate40's Avatar
1977 CJ5
Great write up Matt! This is on my spring to do list!!
Pirate40 is offline
post #26 of 93 Old 02-23-2014, 10:37 AM
JeffreyCharles
JeffreyCharles's Avatar
1976 CJ5
I did the same thing, from Mr Stern, about five years ago. First upgrade to the Jeep after I bought it. At the time I was pulling down big bucks and decided the extra cost of going through him for the convenience of what amounted to plug 'n' play was worth it. Nowadays I'd scrounge to build it for less. Either way, the results were excellent and it's still one of the best upgrades I've done. Nice write-up!
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #27 of 93 Old 02-23-2014, 05:27 PM
rixcj
rixcj's Avatar
1979 CJ5
Nice work, Matt. Thanks for sharing. The improvement is impressive!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #28 of 93 Old 02-23-2014, 07:01 PM
bamasteeler
bamasteeler's Avatar
I got a set of 4 Bosch relays I think out of a caddy in the jy, now just gotta get my lazy self to buy some wire and fuses and wire it up...
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #29 of 93 Old 02-24-2014, 05:30 AM Thread Starter
Matt1981CJ7
1981 CJ7
For those of you who want to build your own harness, here's a good pic of the parts you will need. The only thing not shown is wire, and perhaps some shrink-wrap.
Matt
post #30 of 93 Old 03-02-2014, 10:34 AM
JeffreyCharles
1976 CJ5
Heh, I looked at that and thought "Hey, that looks like my kitchen table woodgrain!" :-)
Here's a shot with the wiring put together and ready to install.
Jeffrey Charles
