Jeep cj full door latch rod bends - JeepForum.com
post #1 of 5 Old 11-22-2019, 06:21 PM Thread Starter
agear
Been working on my full doors and I was messing with the rods that run to the latch. Right now they're bent out of whack, hard to install and the regulator hits them when I roll the window up or down . Anybody have any good pics or tips ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 5 Old 11-22-2019, 07:58 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
If you got me a few weeks ago, I could have sent you pictures. I rebuilt my full doors from two complete sets. I took the best part from each to build the one I will keep. I put the remaining pieces together anticipating selling them.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #3 of 5 Old 11-23-2019, 08:08 AM
pedal2themetai
1956 CJ5
here's a link to a bunch of pictures
https://www.google.com/search?q=87+C...8Oive-jh1SdjVM
pedal2themetai is offline
post #4 of 5 Old 11-23-2019, 10:44 AM Thread Starter
agear
Thanks guys ! I got them bent . I think they'll work but for some reason my latch isn't opening the door even If i disconnect the rods and operate the latch by hand....... ?
Update I think I got it. Same problem I was having with the other door. The rods have to be as straight as necessary to allow the unlock/lock lever to cycle through full range of motion before the next step (opening the door) will work.
I'm learning the doors a little. The rods have to be bent to clear the window track and regulator but not be so bent they wont reach the latch levers to allow the levers the full range of motion. And the feel of the lock button depends on the bend/ overall length after bending of the rod rods too. It all has to have freedom of movement
agear is offline
post #5 of 5 Old 11-24-2019, 10:30 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
And lots of oil!!! I use WD40 and then white silicone grease to keep them moving. If they start to gum up, they will not work.
I saw one once after a bit of paint that the painter had threaded the rod through the window regulator, did neither any good.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
