Installing floor pans. Need direction. - JeepForum.com
post #1 of 31 Old 09-17-2009, 10:25 AM Thread Starter
DEEPsneaky
Hey guys I picked up a 84 cj-7 that need s the floor pans replaced. I have all the parts I need. I'm trying to figure out what welder to buy and I'm just wondering if anyone has done this before. If anyone can give me some do's and don't on replacing floor plans please let me know.I will be getting started tommorow.
DEEPsneaky is offline
post #2 of 31 Old 09-17-2009, 10:30 AM
CSP
Do you already know how to weld??
CSP is offline
post #3 of 31 Old 09-17-2009, 10:39 AM
leavundst
Junior Member
Are you planning to do future welding repairs? If not it will be cheaper to find a place to have it fixed. As for the pans you can make your own or for $35 a piece buy them from Quadratec.
Jeep Replacement Panels - Quadratec
If the rust is not that bad maybe you can patch them or put diamond plate over them.
leavundst is offline
post #4 of 31 Old 09-17-2009, 10:53 AM
daltonw
1981 CJ7
I would recommend a 110 welder. I have a lincoln and it works awesome for body work. I've used it a BUNCH for jeep sheet metal. You basically keep going around the piece your welding in so it doesnt get too hot in one place otherwise it'll warp.
daltonw is offline
post #5 of 31 Old 09-17-2009, 12:02 PM
jscherb
You don't need a welder for floor pan replacement. It is much easier to use automotive structural adhesive, it's plenty strong enough if done properly, and much more rust resistant than a weld bead you probably can't seal well (especially if you're new at welding). Details in this post: https://www.jeepforum.com/forum/f8/ga...ml#post6731486, go to that post to see the explanation that goes along with these photos:
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #6 of 31 Old 09-17-2009, 12:07 PM
dzride
dzride's Avatar
I used 120 Amp, 230 Volt Flux & MIG Welder from Harbor Freight Tools and it's worked fine for me.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
dzride is offline
post #7 of 31 Old 09-17-2009, 05:10 PM
Bubba Ray
Try Classic Ind. for your repair panels. Much thicker and better formed than the others.
Bubba Ray is offline
post #8 of 31 Old 09-17-2009, 05:20 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Try here, the name says it all 16 ga steel:
http://www.rigidsteel.com/y10pC4tIGk0.html
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #9 of 31 Old 09-17-2009, 05:51 PM Thread Starter
DEEPsneaky
Thanks for the replies guys. I already have all the floor pans. I just need to intall them. I do not know how to weld but my friends are welders and I can learn. I want to know more about the adhesive. I could save alot of money that way.Also, How do I know how much of the old floor to cut out? I dont want to remove to much and be screwed. Do I need to worry about the tub flexing inward when I remove the floor pans?
post #10 of 31 Old 09-17-2009, 06:19 PM
jscherb
If you've followed the link in my post about the adhesive and you still have questions, let me know.
No, you don't have to worry about the tub flexing inward.
jscherb is offline
post #11 of 31 Old 09-17-2009, 06:22 PM
nshefbuch
1982 CJ7
i would NOT replace them with adhesive. i just bought my second jeep and the previous owner did this several years ago and now i'm replacing them myself. this time they are welded in. not that hard too. if your going to do it, do it right. as for sealing a weld, you use seam sealer in a caulking gun over top and bottom of all your welds. this stuff hardens and is paintable. if you do alot of trails or mudding i think you'll regret using an adhesive. just my opinion.
nshefbuch is offline
post #12 of 31 Old 09-17-2009, 06:31 PM
Coiz
Coiz's Avatar
1979 CJ7
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=55250
I have a similar welder, http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=55525, and mine has also worked great through my entire build. $140 shipped to my door is pretty amazing for how well it has worked.
It all depends on if you have access to a 220v supply. If you do I would go with a 220 machine. It's a lot easier to make a bigger welder work with smaller metal then it is to use a small welder on thicker metal.
PS. What is going on with the http links today?
Mike
Coiz is offline
post #13 of 31 Old 09-17-2009, 06:36 PM
daltonw
1981 CJ7
I do a bunch of welding almost everyday and I'd say use a 110 welder with flux. I've tried a 220 and it just goes right thru thinner metal. A 110 with gas I think would be optimal for welding sheet metal but I just use flux core. For anything but sheet metal tho I use a 220 mig
daltonw is offline
post #14 of 31 Old 09-17-2009, 06:39 PM
243
243's Avatar
1978 FSJ Cherokee
A 125A-135A MIG is all you need to weld up to 14ga easily. I would definitely recommend a 220V welder if you EVER think you might want to weld anything over about 3/16".
Dave's 78 Build
243 is offline
post #15 of 31 Old 09-17-2009, 06:41 PM
Fatman
Fatman's Avatar
2008 CJ7
Where in NC are you, might be able to give you a hand w this, if you're local
Thread Links:
Fatman is offline
new floor pans Jeepman065 Jeep CJ Forum 1 04-24-2006 07:38 PM
Floor Pans Sassy Jeep CJ Forum 4 03-27-2006 02:33 PM
CJ Floor pans? slick2570 Jeep CJ Forum 8 03-22-2006 07:46 PM
Floor pans Tri_X_Troll Jeep CJ Forum 4 01-25-2006 05:28 PM
Where to get floor pans....... dali555 Jeep CJ Forum 1 04-29-2005 11:43 AM
