The infamous T150 swapping fluid with D20 issue - JeepForum.com
 1Likes
  • 1 Post By 77jeepcj5
post #1 of 4 Old 08-24-2019, 09:55 PM Thread Starter
77jeepcj5
I know this has been beaten to death on here, but I never seem to find a solution on any thread, so here it goes. I rebuilt my T150 and D20. When I pulled the trans there was hardly any fluid in it, and way too much fluid in the transfer case. There also was no rear output seal on the trans. I installed the seal the right direction, fully seated it, and reattached the Tcase. The trans still dumped all the fluid into the T case. I removed the case yet again to find the seal had somehow worked it's way out a few millimeters. I pulled it, replaced it with a new output seal (fully seated), and still, it leaks into the T case. I've tried everything and am at a loss. In my defeat I started to wonder if I could potentially remove the rear output seal and just run a line from the fill plug of the trans to the fill plug on the Tcase so it would always even itself out. Thoughts?? Any help is appreciated. Thanks!
77jeepcj5 is offline
post #2 of 4 Old 09-01-2019, 10:23 PM Thread Starter
77jeepcj5
Bump. Crickets
post #3 of 4 Old 09-02-2019, 10:39 AM
RedNeckCorvette
1979 CJ7
For seals in general, If the shaft is worn use a jiffy sleeve, if the seat for the seal is worn ruff it up a bit with a pick or something to create ridges.
Good luck RN
RedNeckCorvette is offline
post #4 of 4 Old 09-07-2019, 07:54 PM Thread Starter
77jeepcj5
Thanks for the reply RN! I'll look up a jiffy sleeve
RedNeckCorvette likes this.
