Ignition lock cylinder replace write up needed? - JeepForum.com
post #1 of 4 Old 06-14-2021, 11:58 AM Thread Starter
Techlight
Hi All,
I've searched but keep coming up with dead links etc. Can someone point me in the right direction for a write up to change a tilt wheel lock cylinder. My Jeep will start without the key haha...had this thing for years and just figured this out.
Thanks in advance.
,[_____],
_-o||||||||o-_
()_)ŻŻŻŻ )_) 1984 CJ7 Renegade, 4.2L-TBI, D30, AMC20, 4.5" OME lift
Techlight is online now
post #2 of 4 Old 06-14-2021, 06:22 PM
Ollie09
1977 CJ5
It's a GM column. Go here to get all the info you need on GM columns. In you're case, I'd bet the rack is broken=common problem.
http://jimshea.corvettefaq.com/?cat=5
https://www.ebay.com/itm/31347045315...hoCFX8QAvD_BwE
Ollie09 is offline
post #3 of 4 Old 06-14-2021, 07:54 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I have Jeeps that start without the key. The lock cylinder is bust.
Yep, any GM column from the early 70s will be the same, most of the parts you can just get for a GM column. (cheap) The new lock cylinder will be a GM, may even come with a GM logo key. Just make sure you get the correct year, i got a Cherokee XJ lock mixed up with a CJ lock cylinder and found one was 1/16" longer, still drove it for 6 months even though it was not engaging very well.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #4 of 4 Old 06-15-2021, 01:39 PM Thread Starter
Techlight
Thanks for the info..I'll look around at GM parts.
,[_____],
_-o||||||||o-_
