Identify This Transmission Please - JeepForum.com
 4Likes
  • 1 Post By BrutusBlue
  • 1 Post By BagusJeep
  • 1 Post By John Strenk
  • 1 Post By CSP
post #1 of 12 Old 08-19-2019, 08:12 PM Thread Starter
trailhead2004
trailhead2004's Avatar
1980 CJ7
Iím tired of playing Google roulette with this one, and Qudratecís Knowledge pages donít seem to cover this one. Too old? Borg Warner all over the cases, it has the look of a T5 trans with the shifter tower, but whatís fooling me is that it says cast iron cases.
trailhead2004 is offline
post #2 of 12 Old 08-19-2019, 08:29 PM
Hoover7
Hoover7's Avatar
That looks just like my T-5, and the housing is completely aluminum (with the exception of the shift plate cover that is). Or could be a T-4 depending on the shift pattern (lacks the O-drive). Confused a little- Q-tech is saying the case should be iron? Or is your case iron?
Novak indicates that the case should be Al, and mine matches their description spot on.
http://www.novak-adapt.com/knowledge...s/manual/t4-t5
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #3 of 12 Old 08-19-2019, 10:08 PM
BrutusBlue
1982 CJ7
T5...looks like a 13-52 casting number to me. Look under Borg on the driver side below the shifter...if it says 13-52...T5. 13-51...T4.
Just double checked on my Scrambler T4.
trailhead2004 likes this.
BrutusBlue is online now
post #4 of 12 Old 08-19-2019, 10:14 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
they are aluminium light car transmissions. Iron cases do not need all the stiffeners
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 12 Old 08-19-2019, 10:33 PM Thread Starter
trailhead2004
1980 CJ7
First, this is a CL ad in my area.
A couple of things rang my bell and I wasn't sure what to think.
Cast iron doesn't match up. Every T5 I've seen is aluminum case. The QTec site doesn't show the shifter tower so I wasn't sure. However, the casting numbers were out of the QTec range as well. I figured one of you would either confirm my suspicions or add to my angst.
I already have 2 T5's sitting on the shelves with no prospect of using them, this one is going to pass into history for me.
post #6 of 12 Old 08-20-2019, 07:31 AM
BrutusBlue
1982 CJ7
Except that the case is aluminum...despite what the ad says
post #7 of 12 Old 08-20-2019, 07:35 AM
John Strenk
John Strenk's Avatar
1976 CJ5
He probably saw the rust on the t-case mounting flange and though it was cast iron.
probably from the t-case.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 12 Old 08-20-2019, 08:07 AM Thread Starter
trailhead2004
1980 CJ7
Good point Bagus.
post #9 of 12 Old 08-20-2019, 09:45 AM
Hoover7
Hoover7's Avatar
Save one for me one, Trailhead! While I certainly recognize the weaknesses of the T-5, I've enjoyed mine, especially with the short, crisp throws of the aftermarket Hurst shifter, and having that 5th gear for highway travel is awesome. Our hills are tiny around here, relatively speaking. Although I'm sure others have had different experiences, in my twenty years of driving one, proper maintenance, correct gearing/tire size, and obviously, not pushing it with a V8 or hopping rocks, etc., have kept it from exploding!
However, I'm a realist and there's always that first time, hence, my humble request for you to 'save' one for me. Haha
Hoov
Hoover7 is offline
post #10 of 12 Old 08-22-2019, 02:06 PM
80cj
80cj's Avatar
1980 CJ5
Got a magnet?
80cj is offline
post #11 of 12 Old 08-23-2019, 12:58 AM Thread Starter
trailhead2004
1980 CJ7
Originally Posted by 80cj View Post
Got a magnet?
Yup. Donít have the transmission. Post #5.
post #12 of 12 Old 08-25-2019, 10:38 PM
CSP
Look at the case around the output shaft. It's obviously aluminum.
I have an NP435 that someone wrote T18 on the aluminum top cover with a Sharpie. It's still an NP435, despite a prior owner not knowing any better.
jeepster4245 likes this.
CSP is offline
