identify this noise?? - JeepForum.com
post #1 of 10 Old 05-12-2019, 09:32 AM Thread Starter
farmboy999
Question identify this noise??
85 cj7/258.
So i've got this sound coming from under the hood. I can't really tell exactly where its coming from other than its the front or drivers side around the carb. Tightened belts and pinched a bunch of hoses to see if maybe one was leaking. It only starts after the engine has warmed up a bit and run for a few minutes.
Hopefully this video works..thanks for any help.
https://photos.google.com/share/AF1Q...ZOR29QUHhHdUd3
farmboy999 is offline
post #2 of 10 Old 05-12-2019, 10:09 AM
shadoow
Link didn't work for me. Check for vacuum leaks and that your intake/exh manifold bolts are tight
shadoow is offline
post #3 of 10 Old 05-12-2019, 01:14 PM
LumpyGrits
Cj
Check your PS fluid level.
Remove 1 belt at a time and see if the noise stops.
How old are the belts?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 10 Old 05-12-2019, 02:42 PM
TIPPEDITOVER
Brakes are for quitters
TIPPEDITOVER's Avatar
1978 CJ5
Sound was loudest above ps pump.
Ongoing CJ-5 to CJ-6 Build:
TIPPEDITOVER is offline
post #5 of 10 Old 05-12-2019, 03:59 PM
only in a jeep cj
Is that a 4.0 head on your block causing the intake manifold to sit high and the ps bracket holes to not line up?
Could an intake port be off and its whistling.
But yes, it does sound louder above the ps pump.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 10 Old 05-13-2019, 06:29 AM Thread Starter
farmboy999
You might be right on the 4.0 head...i always wondered why they didn't line up. It was that way when i bought it. PS fluid is fine...could the pump be making that noise?
post #7 of 10 Old 05-13-2019, 01:14 PM
LumpyGrits
Cj
If you take the belt OFF-You'll know......
LG
post #8 of 10 Old 05-16-2019, 10:04 AM Thread Starter
farmboy999
good point...i'll try that this weekend
post #9 of 10 Old 05-16-2019, 11:11 AM
ddawg16
ddawg16's Avatar
You can take a length of hose....water hose works fine....hold one end to your ear and move the other end around to pinpoint the source.
ddawg16 is offline
post #10 of 10 Old 05-16-2019, 11:52 AM Thread Starter
farmboy999
great idea...i'll try and keep it out of the fan belt
Dana 35 troubles. Need advice! A9000 ZJ Grand Cherokee Forum 6 11-27-2018 09:07 PM
100$ Prepaid card free if u can identify noise ConceptTilCreat WJ Grand Cherokee Forum 6 11-12-2018 12:14 AM
Need Sherlock Homes for this one....suspension noise on WK MacJeepWk WK Grand Cherokee & XK Commander Forum 9 05-26-2018 07:11 PM
Can someone point me in right direction to try to identify noise on my '78? lostangel Jeep CJ Forum 19 05-23-2018 07:52 AM
Strange noise, can someone please identify this? PatrickThomas72 WJ Grand Cherokee Forum 4 04-14-2018 11:09 AM
