I need rivet nuts - JeepForum.com
post #1 of 15 Old 10-19-2021, 06:02 PM Thread Starter
jchal3
1934 CJ7
I need rivet nuts
Anybody here know where I can get some 1/2 X 13 rivet nuts.... biggest I can seem to come up with is 3/8.
I am trying to remount my transmission mount / skidplate, and need to attach it to the frame.
I have a t150 transmission, and an 81 frame and crossmember so we are doing some fab work.
Thanks
Sent from my SM-N960U using Tapatalk
jchal3 is offline
post #2 of 15 Old 10-19-2021, 06:59 PM
sonnychiss
1978 CJ5
Mcmaster carr has them. Another thing I learned here, Mcmaster carr has a huge selection of such things.
https://www.mcmaster.com/rivet-nuts/...nt-rivet-nuts/
sonnychiss is offline
post #3 of 15 Old 10-19-2021, 07:39 PM Thread Starter
jchal3
1934 CJ7
I didnt see 1/2in, but ill look again...one of my go to places for sure though.
jchal3 is offline
post #4 of 15 Old 10-19-2021, 09:23 PM
sanddrag
Do you have a tool that will pull rivet nuts that big?
sanddrag is offline
post #5 of 15 Old 10-19-2021, 10:07 PM
StoneTower
StoneTower is offline
post #6 of 15 Old 10-19-2021, 10:12 PM
StoneTower
If you don't have the correct tool, you can use this method. You will want to use anti-seize on the bolt and the threads so you do not mess things up.
post #7 of 15 Old 10-20-2021, 05:18 AM
keith460
keith460's Avatar
A couple of years ago I was trying to find 7/16-14 Rivet-nuts but never did find them. Seems they make 3/8-16 and then 1/2-13 but never the in between 7/16-14.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 15 Old 10-20-2021, 05:36 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
These folks have most every fastener I've ever looked for:
https://www.fastenal.com/product/fas...sExpanded=true
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #9 of 15 Old 10-20-2021, 05:39 AM
keith460
keith460's Avatar
I know Fastenal, but they don't have 7/16-14's rivet-nuts.
1984 CJ-7 Renegade
keith460 is offline
post #10 of 15 Old 10-20-2021, 05:47 AM Thread Starter
jchal3
1934 CJ7
Thanks for the help guys...after looking again McMaster had the 1/2-13 i was looking for....also I won't be buying an installation tool after the attached video.
jchal3 is offline
post #11 of 15 Old 10-21-2021, 10:01 AM
torkman1983
1983 CJ7
I did exactly what you are doing but used 7/16 bolts. After I inserted the rivet nuts I put a few spot welds on their face and then ground them down a bit flatter. Tested them and they would all take 80 lbs of torque...figured that was more than enough. Good luck.
torkman1983 is offline
post #12 of 15 Old 10-21-2021, 12:12 PM
StoneTower
I would bet you could put some Loctite or epoxy on the rivet before inserting it to seal the joint and help lock it in place. I am sure corrosion and rust do not help the holding power after a few years.
post #13 of 15 Old 10-21-2021, 01:23 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Look forward to seeing you install these in your build thread update Jason!
Hoss
I used to be a people person, until people ruined it...
JoonHoss is offline
post #14 of 15 Old 10-22-2021, 09:23 PM Thread Starter
jchal3
1934 CJ7
Pics to come soon guys, but installing those things was a chore....
jchal3 is offline
post #15 of 15 Old 10-23-2021, 02:11 PM Thread Starter
jchal3
1934 CJ7
Check on my 1981 kentucky cj7 build thread to see the installed nuts, and crossmember
jchal3 is offline
