I need help wiring turn signals/ hazzards to a toggle switch. - JeepForum.com
 1Likes
post #1 of 36 Old 09-05-2015, 05:56 PM Thread Starter
THECJ7
1982 CJ7
Cj I need help wiring turn signals/ hazzards to a toggle switch.
Hello everyone. I am new to the forum thing I have an 82 CJ7 and am putting in a custom dash and I need to wire my turn signals and hazards to toggle switches. Has anyone on here done this before? Any help would be greatly appreciated.
THECJ7 is offline
post #2 of 36 Old 09-05-2015, 06:12 PM
John Strenk
John Strenk's Avatar
1976 CJ5
1: One toggle switch for turn signal and one toggle switch for hazard
2: two toggle switches for turn signal and 1 toggle switch for hazard?
3; Just two toggle switches for turn signal and turn both on at the same time for hazards?
If you want just two switches (#2) then ou will need two switches like this:
John Strenk is offline
post #3 of 36 Old 09-05-2015, 06:16 PM Thread Starter
THECJ7
1982 CJ7
One toggle switch for turn signals one toggle switch for hazards.
82 CJ7 Chevy 350 Turbo 350
THECJ7 is offline
post #4 of 36 Old 09-05-2015, 06:40 PM
John Strenk
1976 CJ5
Two Switches and two Relays
post #5 of 36 Old 09-05-2015, 06:42 PM
John Strenk
1976 CJ5
It's easier to use the original or aftermarket turn signal switch
Unless you are going to use separate turn signal and brake lights.
The problem is keeping the one brake light on when the turn signal is flashing.....
post #6 of 36 Old 09-05-2015, 06:48 PM Thread Starter
THECJ7
1982 CJ7
Thank you. I am trying to wire it off of the original wiring harness if it is possible.
THECJ7 is offline
post #7 of 36 Old 09-05-2015, 07:05 PM
John Strenk
1976 CJ5
Cut the plug off an original turn signal switch and use those wires. Then it will plug right in.
post #8 of 36 Old 09-05-2015, 07:22 PM Thread Starter
THECJ7
1982 CJ7
I am currently using that picture you posted. I have power to the middle pole on an on/off/on switch and turn flasher, and left front and left rear lights hooked up to an on pole and the light come on and I can hear the flasher but the lights aren't flashing.
THECJ7 is offline
post #9 of 36 Old 09-06-2015, 05:42 AM
Mike Romain
Flasher is on the power line to the switch so it runs both sides.
Mike
Mike Romain is offline
post #10 of 36 Old 09-06-2015, 05:47 AM
John Strenk
1976 CJ5
Which picture?
Did you just use a Switch?
If you want to experiment, do it like this but the brake lights won't work
post #11 of 36 Old 09-06-2015, 06:18 AM
John Strenk
1976 CJ5
Ultimately you will need to do this:
post #12 of 36 Old 09-06-2015, 07:46 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This is a great example of how these things increase in complexity very quickly. I had to laugh when I read the whole tread up to the previous diagram. My first thought was that the Jeep would trade hands 3 times, end up back here, and everyone would be trying to understand why in the world the PO had wired things in this manner.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #13 of 36 Old 09-06-2015, 11:55 AM Thread Starter
THECJ7
1982 CJ7
What type of relays are you using in that last picture?
THECJ7 is offline
post #14 of 36 Old 09-07-2015, 02:14 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Any particular reason not to just go the easy route and use the OEM design?
Rick
Cutlass327 is offline
post #15 of 36 Old 09-07-2015, 05:32 AM
jay-h
This is like what I have in my CJ2A
http://www.amazon.com/Omix-Ada-17232...0_SR160%2C160_
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
