I'm baaa-aaack - Page 5 - JeepForum.com
 43Likes
post #61 of 104 Old 06-11-2018, 10:02 PM Thread Starter
jeepskate
Picked up the frame & assorted parts from the powder coater this afternoon, so it's just about time to start making this look like a Jeep again (need to hit everything with the tap & die kit to clean up the threads from the galvanizing). Pics after this should be of a rolling chassis.
34847712_10214212166316774_8174907297982578688_n.jpg   35142501_10214212166676783_6240716875567726592_n.jpg   35026648_10214212167076793_8346621662434689024_n.jpg   35086709_10214212167476803_957628405354856448_n.jpg   35151490_10214212167916814_8316674139674902528_n.jpg
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,4.5" RE XD,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: 360,T-999,D300,D30/A20,1-piece shafts,rear discs,33" Fun Country's.
jeepskate is offline
post #62 of 104 Old 06-19-2018, 01:00 PM Thread Starter
jeepskate
Almost rolling...didn't have a 9/16-20 bottoming tap to clean out the threads in the u-bolt skids so I could install the sway bar & shock studs. Getting ready to leave for vacation, so no Jeep work for the next couple of weekends
35485165_10214254190207345_1423302928684285952_o.jpg   35473285_10214257529610828_7062816561400119296_n.jpg   35817923_10214257530050839_7808763801309806592_n.jpg   35748977_10214257530490850_6699847715573989376_n.jpg
post #63 of 104 Old 07-30-2018, 10:28 PM Thread Starter
jeepskate
Catch up time for this thread...next two posts are old but will get things up to date...just got back from seeing my new grandson in Japan...
post #64 of 104 Old 07-30-2018, 10:34 PM Thread Starter
jeepskate
Back from vacation...Bora Bora was absolutely beautiful!!! Add it to your bucket list...took two years of planning, reservations & saving & using a Venture card for travel points, but it was SO worth it...never took so many pictures before in my life. We rented an over the water bungalow that used to be owned by Marlon Brando across from the lagoon from the motu that the airport is on. It has it's own small dock, so we got door to door service for the water-based activities that we did. Heading back out to Japan in a couple of weeks, grandson is due any day now (wow, I feel old!!).
She's a roller again!! Cleaned out the threads on the u-bolt skids, installed the steering box brace & started hooking up the stainless steel brake lines & hoses.
36379027_10214344898234989_8666880275432603648_n.jpg   36543864_10214344898554997_6250078568538177536_n.jpg   36321766_10214344897954982_5806603008879886336_n.jpg   36316751_10214335608922762_1800924210059542528_n.jpg   36866251_10214398929825745_140234530505097216_n.jpg
36723862_10214398930545763_1854983576139857920_n.jpg   36736095_10214398931065776_9202291650171240448_n.jpg
post #65 of 104 Old 07-30-2018, 10:44 PM Thread Starter
jeepskate
Not a lot of time, but lot's happening. Set the body on so that I could start mocking everything up & making any necessary adjustments & drilling holes ahead of painting. Monday was delivery day as my Bulltear order finally arrived as did my grandson!! Malachai clocked in at a touch over 9 pounds and 20 inches (both my son & his wife are ~6' tall, so not surprised). Leaving for Japan on Saturday to visit & help out, so two more weekends of no Jeep progress, but it's worth it
37221770_10214456164496576_2761180796097134592_n.jpg   37185963_10214456164016564_7949936563125747712_n.jpg   37150898_10214456253618804_2256189901621952512_o.jpg   37169880_10214467479819452_8739768623519760384_o.jpg   37731712_10214515463219007_8230455089274290176_o.jpg
frunk3 likes this.
post #66 of 104 Old 07-30-2018, 11:42 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
Very nice work Jeepskate!
And congratulations on the new grandson!
jeepskate likes this.
trailhead2004 is offline
post #67 of 104 Old 08-13-2018, 08:25 AM Thread Starter
jeepskate
Back at it working on the mock up...I think I would have pulled my hair out if I hadn't gone with the Willys-Overland Repli-Tub option to correct the body mounts...darn near everything else on this tub is off. Triple tap on an extension cord to keep my drill (switching between a step bit & combo drill/tapping bits) & two angle grinders (one with a cut-off wheel, the other with a flap disc) at the ready. The fit & finish is a bit disappointing for the price tag, but I'll make it work.
39010604_10214650580716860_5846266653901324288_n.jpg   39032468_10214650581236873_6793219681818771456_n.jpg   39042059_10214658424032938_5470825154328133632_n.jpg   38992277_10214658424392947_5957325712082862080_n.jpg   39105156_10214658425072964_1087544367125626880_n.jpg
trailhead2004 and STJP like this.
post #68 of 104 Old 08-13-2018, 10:14 AM
Nick4320
Hey Jeepskate, where did you get your front and rear bumpers from? i haven't seen a set like that for CJs. Ive always been a fan of that pre-runner style bumper
Nick4320 is offline
post #69 of 104 Old 08-13-2018, 10:41 AM Thread Starter
jeepskate
The front is a Fly-N-Hi/FST that was on my CJ-7 (switched to a higher clearance YJ/TJ one with adapter brackets for it) that I've had for about 15 years, not sure if they're still making them. The rear is an Olympic for a YJ/TJ that I redrilled to fit the CJ. Smittybilt makes front bumper adapter brackets, so you should be able to pick out just about any YJ/TJ pre-runner that you like.
I do have the matching FST rear bumper that I'm not going to be using available if you're interested.
Last edited by jeepskate; 08-13-2018 at 10:42 AM. Reason: Added info about adapter brackets
post #70 of 104 Old 09-07-2018, 08:40 AM Thread Starter
jeepskate
Still mocking up, hoping to finish this weekend and get the body out to paint here shortly while it's still warm. Decided on Ford Nitrous Blue.
40072180_10214751848528492_6863170963765198848_n.jpg   40031609_10214751847928477_5116253304573132800_n.jpg   40098622_10214759556641190_7057608277898559488_n.jpg   39934509_10214759554481136_7786402376205729792_n.jpg   40211735_10214759555921172_8031196901984436224_n.jpg
40082797_10214759557041200_5997273280212369408_n.jpg   40097751_10214751848968503_5565890604702892032_n.jpg   40197120_10214759557801219_6700073179882192896_n.jpg
post #71 of 104 Old 09-07-2018, 08:51 AM Thread Starter
jeepskate
As she sits right now. Front clip is off (hood is in the house garage for installation of the louvers, grill is in the basement for fitup of the radiator, trans cooler & AC condenser), windshield frame is in the basement for installation of a better cowl seal & the wipers (went with the WipeBoy billet setup), dash is in the garage for sanding & painting (going with Toyota Electric Blue on it for some contrast and also ordered SpeedHut gauges for it...caught the Labor Day sale). I had the machining students at work drill & tap some 1/4 flat stock that I had on hand to make the reinforcement & mounting points for the fenders & battery tray & drill out some bolts so that I can pass wiring through them. My Bulltear order came in a while back (timing cover, etc) and then I ordered the serpentine kit which arrived within a week, so once the body stuff is wrapped up I'll finish assembling the engine (have to check with the coater to see what's going on with the ceramic coating on my manifolds, been a few months now).
40065046_10214751849528517_7446495868376580096_n.jpg   40599058_10214812886294398_4940633135516745728_n.jpg   40517732_10214801541130776_4269333539608068096_n.jpg   40763812_10214812885534379_4218685459892535296_n.jpg   40562593_10214801541450784_8356980277444083712_n.jpg
post #72 of 104 Old 09-07-2018, 09:03 AM
trailhead2004
1980 CJ7
Originally Posted by jeepskate View Post
As she sits right now. Front clip is off (hood is in the house garage for installation of the louvers, grill is in the basement for fitup of the radiator, trans cooler & AC condenser), windshield frame is in the basement for installation of a better cowl seal & the wipers (went with the WipeBoy billet setup), dash is in the garage for sanding & painting (going with Toyota Electric Blue on it for some contrast and also ordered SpeedHut gauges for it...caught the Labor Day sale). I had the machining students at work drill & tap some 1/4 flat stock that I had on hand to make the reinforcement & mounting points for the fenders & battery tray & drill out some bolts so that I can pass wiring through them. My Bullear order came in a while back (timing cover, etc) and then I ordered the serpentine kit which arrived within a week, so once the body stuff is wrapped up I'll finish assembling the engine (have to check with the coater to see what's going on with the ceramic coating on my manifolds, been a few months now).
Wow, she's really coming together Jeepskate! Looking sweet!
post #73 of 104 Old 09-09-2018, 10:20 PM Thread Starter
jeepskate
The mock up is pretty much done other than the parts that I took up to the house to work on & I'm starting to tear it back down for body work & paint. I'll finish engine assembly, drop the drivetrain in & finish plumbing everything while the body is away.
41323191_10214851289254448_6298545470587273216_n.jpg   41292270_10214851289934465_776021180736864256_n.jpg   41466960_10214851290574481_6789267921064427520_n.jpg   41287727_10214851289614457_2337518470331105280_n.jpg   41449355_10214858491114490_3651517380435116032_n.jpg
trailhead2004 likes this.
post #74 of 104 Old 09-11-2018, 12:16 PM
Asoude_1
1977 CJ7
Looks good. Cant wait to see it after the paint job.
Asoude_1 is offline
post #75 of 104 Old 09-11-2018, 02:01 PM Thread Starter
jeepskate
Almost forgot...these are on order: silver/blue for this Jeep, white/red for my CJ-7.
