Hutch's 1985 CJ7 Frame Off Rebuild - JeepForum.com
post #1 of 197 Old 03-08-2007, 03:04 PM Thread Starter
cshutchinson
Box Man
cshutchinson's Avatar
Just for my own use, this project started with the tear-down on November 28th, 2006.
I haven't posted any updates to this in a while, but here is what I started with
1985 CJ7 in near perfect condition outside of some of the typical problems.
I took the Jeep apart. Had the frame and body bead blasted.
I purchased:
ARBs for front and rear
4.56 gear sets
one piece axles kits
rear brake kit for rear
all new parts for front disc brakes
Warn Premium Hub system for Dana 30
Rubicon Express 4.5 Lift
I have done most of the work myself, but I had help with the differentials and lockers, brake install, and painting, oh and the bead blasting.
As far as I can tell, I am ready for tires and wheels.
I started out with RE monotube shocks but changed to these skyjacker hydros after i ran into length problems with the RE shocks on the front axle. See I chose to use the shock studs on the spring plate instead of the mounts on the axle which I cut off so I had to get longer shocs. RE didn't make any economical longer shocks besides the expensive resevoir shocks, so I changed to Skyjacker hydros to get a longer shock for the front spring plate mounts. I have the 4 RE shocks for sale as they are brand new. PM me if you want them.
I installed 4 degree steel RE shims in the front and 8 degree RE steel shims in the rear. I just bolted them into the spring packs.
I am building a 99 Vortec Chevy 350 block into a 383 stroker kit bored 30 over with Edelbrock ETec 170 Heads, 3705 Pro Flo EFI system currently. A 700r4 with an 1800 stall converter will be added to the motor and Dana 300. I am debating a 4 to 1 kit currently.
Here are my progress pics. Gosh I have been working on this a long time, so I hope you guys like it all. Thanks to BSERK for all the help and encouragement.
cshutchinson is offline
post #2 of 197 Old 03-08-2007, 03:09 PM
RLBJeep
I'm jealous...I wish I had the time, space and money to do that.
84 CJ7 w/ 258, T-176, Dana 300
RLBJeep is offline
post #3 of 197 Old 03-08-2007, 03:12 PM
BLS33
Chief of the brain police
BLS33's Avatar
That looks GREAT!
I am really looking forward to seeing it when its all finished. It should really be a beautiful piece of machinery when all is said and done. Keep up the good work!
BLS33 is offline
post #4 of 197 Old 03-08-2007, 03:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Man that is a beautiful chassis!! It deserves to be mounted on a spinning platform on a showroom floor somewhere.. Can't wait to see the rest of this build.. keep the pics coming!
BESRK is offline
post #5 of 197 Old 03-08-2007, 03:41 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
very nice..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #6 of 197 Old 03-08-2007, 03:44 PM
nichols077
nice keep us updated
nichols077 is offline
post #7 of 197 Old 03-08-2007, 04:02 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
what color are you going with?
looks nice so far.
Hoss
I used to be a people person, until people ruined it...
JoonHoss is offline
post #8 of 197 Old 03-08-2007, 04:09 PM
dodchall70
Very nice. I wish my frame looked like that.
85 CJ7, 258, Howell Fuel Injection, CRT Performance HEI Dist., 2" lift, Warn winch
Colorado Jeep Club Member #75
dodchall70 is offline
post #9 of 197 Old 03-08-2007, 05:41 PM Thread Starter
cshutchinson
Box Man
Hoss
I am going to use Flame Red. The identical color used now by Jeep.
post #10 of 197 Old 03-08-2007, 05:49 PM
Fuzz21
Guest
Very nice!!! Now throw some mud on it and the rest of us will be able to recognize it a little bit better
Fuzz21 is offline
post #11 of 197 Old 03-08-2007, 07:16 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
.. had to come back for a second look..
BESRK is offline
post #12 of 197 Old 03-08-2007, 07:21 PM
jlutsey
1981 CJ7
Well Done, That's one nice shop!!!
"If you haven't tried it you should,
these things are fun and fun is good!"
81 CJ 7 Renegade. 304, edelbrock performer intake, Holley 600, HEI, K&N, 33x12.5x15
jlutsey is offline
post #13 of 197 Old 03-08-2007, 08:59 PM
Carmell CJ
Carmell CJ's Avatar
1978 CJ5
WOW, man that is sweet !!! Now Im inspired to start some planning
1978 CJ5, let the mods begin.
Carmell CJ is offline
post #14 of 197 Old 03-09-2007, 11:44 AM Thread Starter
cshutchinson
Box Man
Thanks for all the positive comments guys. I really appreciate it!
post #15 of 197 Old 03-09-2007, 11:52 AM
Fatman
Fatman's Avatar
2008 CJ7
almost making me wish I went with disks on the rear, ..... almost
Looking good, keep the pics coming.
Looks like you and I are about the same stage. I just droped in the motor last weekend
Thread Links:
Fatman is offline
CajunCJ's 85 Frame Off and Rebuild CajunCJ Jeep CJ Forum 32 07-31-2013 04:04 AM
64 cj5 frame up rebuild molsenice Jeep CJ Forum 324 08-19-2012 10:38 PM
1985 cj7 w/1991 wrangler frame burrap Jeep CJ Forum 1 11-17-2008 08:41 PM
OPinions on using YJ tub and YJ frame to rebuild my 7 Bard Jeep CJ Forum 4 01-29-2008 12:15 AM
Need help on a frame up rebuild BrianC Jeep CJ Forum 5 03-07-2007 07:10 PM
