[HOWTO] CJ7 82-86 Speedometer tear down & gauges tests - JeepForum.com
post #1 of 12 Old 02-03-2015, 03:58 AM Thread Starter
stgil
1982 CJ7
[under construction...]
Hi,!
The Speedometer in is Natural Enviromnent: Jungle wire
As shown LOT of wires!!!...
Here the detail:
The ORANGES wires: dashboard ligths
The GREEN with BLACK stripe wire : LEFT turn signal
The GREEN wire : RIGHT turn signal
The GREY wire: High beam indicator
The MAUVE with WHITE stripe : to Coolant Temperature sender
Coming together:
The RED and BLACK wires : BRAKE indicator
The RED and ORANGE wires : 4WD the indicator
and finally ...
The RED and PINK wires : that goes to the FUEL sender ...
We will try to tame the speedo by extracting from its jungle (all done by hand: no need for special tools except a wrench with 3/8" socket to release the 4 3/8" nuts from the dashboard...)
front view...
To see what was under the hood ... a small screwdriver stroke to 4 edges in order to extract the chrome bezel...
and 2 screws from the top ...
That appear the differents parts counters (BE CAREFULL to the differents Needles: they are no longer protected !!!)
The other side: 192000Km (~120000mi) : the brake in (not sure about the english word) is quite finished
the detail of the instant mechanism speedometer / odometer ...
the other side ... we can see the odometer mechanism ... and the spring of the speed needle ...
back to the other side ... where still located 2 temperature and fuel gauges ...
We return the beast ... (ACHTUNG! of the Needles) to see in detail the connections ..
side fuel gauge (note the different labels ...)
temperature gauge side ...
Unscrewing all these screws with a 3/8 "socket ...
EDIT: John Strenk says (aka "CJ7 electric Guru" ):
"to be very careful if the threads are rusty when taking the nuts off here
If you put on too much force you can break the board and cause the regulator to be loose and/or short out.
I've seen them twisted around inside before.
This allows us to remove the 2 inners gauges ... (Carefull: look for the error )
Next episode coming soon , stay tuned!
FYI: This speedo runs like a charm ... again !
[under construction]
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->https://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #2 of 12 Old 02-04-2015, 03:35 AM Thread Starter
stgil
1982 CJ7
Episode #2 (I've added too some comments in the episode #1)
We'll take care to fuel gauge ... with a small screwdriver on the front unclipped it...
GENTLY taken away... DO NOT touch the needle as musch as possible ...
the inner part:
For that matter, will be detailed:
Another detail showing one of the notch to perform the needle setting: in making the move upwards or downwards
one can vary the stroke of the needle ...
The good news is that we are not obliged to open the gauge to be able to adjust ... it is accessible from the outside ...
here the 2 adjustables notches:
Some details of the interior before moving to another gauge ...
the contactor of the bimetallic ...
Turning now to the temperature gauge ...
Which is opened like the previous ...
We see that it is simpler: no voltage regulator ...
But it has the settings notches too...
also accessible from the outside ...
Next episode: the gauge test...stay tuned...
Regards,
Gilles
stgil is offline
post #3 of 12 Old 02-05-2015, 01:49 AM Thread Starter
stgil
1982 CJ7
Time to test the gauges!
Diagnosis of the fuel gauge:
We make sure we have the following resistances:
S to ground : 68-72 ohms
S to I : 19-21 ohms
S to A : 19-21 ohms
I to A : Zero (0) Ohm
I grounded : 49-51 ohms
A to ground : 49-51 ohms
So that's how the measurements with a multimeter in ohmmeter position:
It is a little high ... but nothing major ...
Always out of range (slightly) ... but since my gauge was working properly, I can only assume that when it does not work
it's not for 1 or 2 Ohms difference.
And it can be explained because I add resistance of the speedometer housing (1 Ohm is very little) may be some
oxydation too ... I think the value would have been correct if I had taken ON the casing of the fuel gauge ...
Temperature gauge diagnosis:
To be on the correct operation of the gauge, we make sure we have the following resistances:
S to A 19-21 ohms
FYI:
I highly recommend to CHECK ALL these values when reassembling the speedometer...
In my case, one of terminal of the gauges was in contact (unintentionally, of course) with the speedometer housing ...
If I had plugged as is: I had to say bye bye gauges! and maybe speedometer too...
To be continued ... stay tuned : next episode (hope last) : bimetal / voltage regulator (High ) technology !
@ John Strenk: if you want to comment, this post is yours!!!
Regards,
Gilles
stgil is offline
post #4 of 12 Old 02-05-2015, 02:55 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You are doing great! Keep it up!
But it's not a voltage regulator. More of a Pulse Width Modulated Current limiter.
Back in the day, most mechanics were lucky to have an analog voltmeter nothing fancy like an o-scope, The pulses just fast enough to move an analog meter to around 5 volts so if the mechanic saw 5 volts on his meter he knows the regulator was working. Fast DVM's today can actually resolve the 12 volt pulses coming from the regulator. They can also tell you the duty cycle.
One neat thing about these gauges and the regulator is that they are not sensitive to polarity meaning they work with negative ground or positive ground systems. The also automatically adjust or changes in temperature to keep the gauges in calibration. They work with any voltage from 6 volts to 24 volts, maybe even 48 volts but I haven't tested them that high yet.
And they are impervious to EMP bursts....
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #5 of 12 Old 02-05-2015, 03:07 AM Thread Starter
stgil
1982 CJ7
Hello John,
They talk about "Regulateur de Voltage" in the French FSM... But I agree it's PWM !
You're right:
They talk about "Voltage regulator" because the local FSM ask to mechanics to test the Voltage on the terminals with
a multimeter (quite easy to found instead a oscilloscop, in a workshop ) in AC Voltmeter mode :
you may read ~5V instead of 12V: => Voltage Regulator, for a mechanic
And I agree too: this technology is simple/tough (EMP Nuke Proof for sure (But I don't think it's your main concern in this case )), reliable and quite indescructible IF understood and checked...
Not sure that nowadays fuel/temp gauges cars will work in 30+ years like this one...
Regards,
Gilles
stgil is offline
post #6 of 12 Old 02-05-2015, 08:55 AM
wm69
How does one adjust the sweep of the needle using the slots on the back of the gauge?
Dad's Scrambler reads 3/4 tank when full, and has since they day he brought it home from the dealership.
wm69 is offline
post #7 of 12 Old 02-05-2015, 09:06 AM Thread Starter
stgil
1982 CJ7
Hello,
>>> This way <<< Please
Regards,
Gilles
stgil is offline
post #8 of 12 Old 02-05-2015, 09:46 AM
Dborns
Awesome write-up, thanks Gilles. I have a speedo in my box of parts that I dont know the working condition of. This will help me troubleshoot any issues.
Dborns is offline
post #9 of 12 Old 02-05-2015, 09:55 AM
Blutarsky
Blutarsky's Avatar
1982 CJ7
If we have an old speedo, can we do these tests or others to determine if it is good or not without opening and disassembling it?
1982 CJ-7
My build thread ruined by the fine folks at photobucket, repaired by a lot of tedious hours.
Blutarsky is offline
post #10 of 12 Old 02-05-2015, 10:00 AM
John Strenk
1976 CJ5
Yes,
There are some links in my sig that should help you.
Stgil is just going over everything in the speedo.
post #11 of 12 Old 02-06-2015, 01:05 PM
Blutarsky
Blutarsky's Avatar
1982 CJ7
Yes,
Thank you, I don't want to derail the thread, could you perhaps PM me a recommended meter for a noobie?
1982 CJ-7
post #12 of 12 Old 05-23-2020, 12:01 PM
kuss312
Very helpful thanks for taking the time to write and photograph!
kuss312 is offline
