Howell TBI wiring mounting and placement. Examples please. - JeepForum.com
 4Likes
  • 3 Post By Brianscj5
  • 1 Post By CSP
post #1 of 12 Old 06-20-2021, 08:30 AM Thread Starter
weapon
1983 CJ7
When I first installed the Howell system, Just ran the wires and let everything hang out the bottom of the dash. Now that I have everything out, I would like to button it all down nicely against the interior firewall. Need some photo examples of how, where your mounted everything for the cleanest look. Thanks.
In addition, how/where did you mount the service light as to still be able to be seen but does not mess up the oem aesthetics?
weapon is offline
post #2 of 12 Old 06-21-2021, 03:18 PM
Axhammer
Axhammer's Avatar
When I removed the Howell kit from my Jeep, the computer had been installed behind the glove box. They pop-riveted the bracket to the air duct, and then Velcro’ed the box in place. But if I remember correctly tie wraps were actually securing it, because they only installed the pile Velcro, no loop Velcro to actually make it connect.
As far as my CEL, they put it front and center….which I didn’t like. I have gotten used to it, since installing my 4.0 based stroker engine. I would have put it down low, without cutting a hole in the dash had I installed it. But, like I said, I’m used to it now, and it works like it should with my new engine.
In the future I’ll probably go with a Speedhut cluster, and weld the hole shut.
E6529B89-188B-47BC-B22B-D228C733ECA6.jpg   CE6D4462-604D-4F2A-B95F-95549597F94A.jpg   C5500CB9-5467-42D6-BEDE-27A6FF8D5C4C.jpg
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #3 of 12 Old 06-21-2021, 05:35 PM Thread Starter
weapon
1983 CJ7
Yes. That is where the computer goes. I am asking about the dangling wire to the left.
weapon is offline
post #4 of 12 Old 06-21-2021, 05:53 PM
jay-h
I have a separate gage pod for trans temperature, vacuum and fog lights. I stuck my CEL there. As far as the rest of my wiring, it's probably listed as an evironmental hazard
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 12 Old 06-21-2021, 08:16 PM Thread Starter
weapon
1983 CJ7
Ha. Mine was all hanging out the bottom like spaghetti. Want to clean it up now that I repainted and lined the tub.
weapon is offline
post #6 of 12 Old 06-23-2021, 12:22 AM
Brianscj5
I bought this
Sent from my IN2017 using Tapatalk
John Strenk, weapon and Rtracy2001 like this.
Brianscj5 is online now
post #7 of 12 Old 06-23-2021, 05:50 AM Thread Starter
weapon
1983 CJ7
Originally Posted by Brianscj5 View Post
I bought this
That is awesome. I wish I had a spot for it but my dash is now perfect and I am not cutting any new holes in it. haha.
weapon is offline
post #8 of 12 Old 06-23-2021, 11:00 AM
sanddrag
Where did you buy that light?
sanddrag is offline
post #9 of 12 Old 06-23-2021, 11:02 AM
Brianscj5
https://www.ebay.com/itm/Custom-Jeep....m46890.l49286
post #10 of 12 Old 06-28-2021, 10:38 AM
43Duc
43Duc's Avatar
1982 CJ8
If your dash is now perfect you might as well cap it w/ some Speedhut gauges which have a check engine light as part of the speedo. That's what I did. Before that I had a stereo block off plate that i put a hole in and mounted a check engine light.
1982 Jeep Scrambler
43Duc is offline
post #11 of 12 Old 06-28-2021, 11:40 AM Thread Starter
weapon
1983 CJ7
nah. I have collected nearly all nos gauges. going for original look.
weapon is offline
post #12 of 12 Old 07-01-2021, 05:00 PM
CSP
Bundle the wires and put them in loom. Secure the ALDL connector up under the dash where you can't see it. Don't overthink it
You could add a small tab similar to an underdash switch bracket for the check engine light.
Axhammer likes this.
CSP is offline
