How to tell difference between 4.2 and 4.0 engines? - Page 2 - JeepForum.com
 2Likes
post #16 of 24 Old 05-09-2019, 10:34 AM
KLG79
On a 4.2 the intake and exhaust ports are on the same plane. Inline.
On a 4.0 the intake ports are higher than the exhaust ports.
Sent from my iPhone using Tapatalk
KLG79 is offline
post #17 of 24 Old 05-09-2019, 12:01 PM
StrippedTorx
StrippedTorx's Avatar
Originally Posted by JoonHoss View Post
Originally Posted by StrippedTorx View Post
Does it have a carb
A 4.0 can have/ run a carb too. They didn't come that way, but can relatively (and easily) be converted to run a carb
Hoss
I agree but that would be out of the ordinary. He has a 7. Somebody swapped in a 258 from a yj. If it was fi I would assume he has a 4.0. Not to many people around here running a 258 with fi.
StrippedTorx is offline
post #18 of 24 Old 05-09-2019, 12:08 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
The OP indicated his fuel pump is on the block, in front of the distributor. If it is still functioning, then I do not believe he could run FI on the lower pressure the mechanical pump generates.
Conclusion: his engine has a carb.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #19 of 24 Old 05-09-2019, 01:35 PM
CSP
Better yet, he has a 4.2. The 4.0 casting didn't allow for mounting of a mechanical fuel pump (which was already stated in this thread).
CSP is online now
post #20 of 24 Old 05-09-2019, 02:17 PM Thread Starter
Joncure
I'd say good work detectives! Yes my intake and exhaust manifolds are in line. It is carb'd (Weber 38), and the fuel pump location!
Joncure is offline
post #21 of 24 Old 05-09-2019, 02:22 PM Thread Starter
Joncure
And manifold date stamp says '88
Joncure is offline
post #22 of 24 Old 05-09-2019, 02:22 PM Thread Starter
Joncure
4.2!
Joncure is offline
post #23 of 24 Old 05-16-2019, 04:51 AM
zouaveherb
Originally Posted by Joncure View Post
Disclaimer: Now I'm quoting here from Wikipedia but...….
"The 4.0 engine, which was introduced in 1986 for the 1987 model year, was a further evolution of AMC's 258 six.[16] It had a 3.875 in (98.4 mm) bore and a 3.414 in (86.7 mm) stroke giving it a displacement of 241.6 cu in (4.0 L).[17] Connecting rod length was 6.125" - similar to the discontinued 199 which was phased out in 1970."
It was introduced in 1986 for the 1987 model year on the Cherokee/XJ. It was not used on the YJ until 1990 for the 1991 model year. Also, the YJ 4.2 had a 2-barrel Carter BBD carburetor while the 4.0 is fuel injected. I know this because I had a 1987 YJ and a 1990 YJ. My friend's sister had a 1991 YJ.
/herb
zouaveherb is offline
post #24 of 24 Old 05-17-2019, 08:13 PM
ShadowsPapa
1994 ZJ
My 87 Comanche Sportruck had the 4.0 - also had uneven idle issues the dealership said "welcome to renix"...........
By the way - pictures
Black engine - 4.0 or 242, blue engine - 258 or 4.2
ShadowsPapa is offline
7/16th Head Bolt for 4.0 head on 4.2? Per ARP...is that right? Vernors YJ Wrangler Technical Forum 2 05-07-2019 08:59 PM
4.2 to 4.0 swap? Robbiescd YJ Wrangler Technical Forum 11 05-03-2019 12:39 PM
Stock 4.0 HO EFI vs 4.2 with 4.0 Head and stock EFI lebowski94 Jeep CJ Forum 27 11-14-2018 12:54 PM
4.0 Engine Swap Complete trwedgn YJ Wrangler Technical Forum 1 03-11-2018 09:20 AM
Whatťs the difference between 4.0 and 4.2 oil dipsticks? olbluejeep Jeep CJ Forum 3 03-01-2018 10:04 PM
