How to tell difference between 4.2 and 4.0 engines? - JeepForum.com
 2Likes
post #1 of 24 Old 05-08-2019, 01:36 PM Thread Starter
Joncure
Joncure's Avatar
I'm wondering if there are any clear ways to visually tell the difference between the 4.2 and the 4.0 engines. I'm trying to figure out which I have in my 85 CJ7. I'm about 97% sure its an engine from an 88 wrangler, since it takes an 88 model oil filter (found that out the hard way!) and valve cover gasket.
The valve cover doesn't say 4.2 or anything else on it like I've seen on others. I also know its not the original engine since the PO told me that the spare engine that came with it was the original.
Joncure is offline
post #2 of 24 Old 05-08-2019, 02:12 PM Thread Starter
Joncure
Joncure's Avatar
One difference I know is that the valve cover on my engine has a lot of bolts (not sure the # right now, but in the teens), and the oil filter is the 20mm metric thread type. I think those suggest the 4.0
Joncure is offline
post #3 of 24 Old 05-08-2019, 02:19 PM
Fourtrail
1974 CJ6
Casting number on the block is the best. On a machined flat on the right side of the block between #2 and #3 cylinders. You may also need the head casting number if it has been changed from stock.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 24 Old 05-08-2019, 03:07 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
If I am not mistaken, the 88 YJ still had a 4.2. The 4.0 wasnt available in the YJ until 91.
So, if the engine came from an 88, its a 4.2
JoonHoss likes this.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #5 of 24 Old 05-08-2019, 03:11 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
This.
The 4.2 (258) was made until 1990
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #6 of 24 Old 05-08-2019, 03:16 PM Thread Starter
Joncure
Joncure's Avatar
Disclaimer: Now I'm quoting here from Wikipedia but....
"The 4.0 engine, which was introduced in 1986 for the 1987 model year, was a further evolution of AMC's 258 six.[16] It had a 3.875 in (98.4 mm) bore and a 3.414 in (86.7 mm) stroke giving it a displacement of 241.6 cu in (4.0 L).[17] Connecting rod length was 6.125" - similar to the discontinued 199 which was phased out in 1970."
Joncure is offline
post #7 of 24 Old 05-08-2019, 03:19 PM
LJameson
LJameson's Avatar
I also think all 4.2s have a spot for a fuel pump, while the 4.0 never did.
1976 CJ7 Restoration:
LJameson is offline
post #8 of 24 Old 05-08-2019, 03:27 PM Thread Starter
Joncure
Joncure's Avatar
So where would the fuel pump be located for the 4.0? My engine has it on the block in front of the distributer.
Joncure is offline
post #9 of 24 Old 05-08-2019, 03:49 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Originally Posted by Joncure View Post
Disclaimer: Now I'm quoting here from Wikipedia but...….
Nope!
Wikipedia the YJ, 4.2 was used until 1990
Now then, if it was out of a Cherokee or Comanche, that's a different story. Those motors would have had like 15 bolts holding down the aluminum valve cover IIRC.
Hoss
post #10 of 24 Old 05-08-2019, 07:58 PM
CSP
"The 4.0 engine, which was introduced in 1986 for the 1987 model year,"
The missing part of that statement relevant to the OP, is that the 4.0 was only found in the Cherokee and Comanche until 1991 when it made its debut in the YJ.
CSP is offline
post #11 of 24 Old 05-08-2019, 08:05 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
The fuel pump on the 4.0 is in the gas tank. The fuel injected engine requires much high pressure than the carb engine. The FI pump pushes the fuel to the injectors; the carb engine sucks the fuel like through a straw.
Tim
87MJTim is offline
post #12 of 24 Old 05-08-2019, 08:17 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
if you look on the inlet manifold near the front you should find a round date stamp, this was the casting date of the manifold.
You should also find on the engine block the casting number.
AMC
1981-85
258 4.2 3.75 L-6 7/16" Head Bolts
3235444
3933000
3224480
3241656
3235477
AMC
1986
258 4.2 3.75 L-6 1/2" Head Bolts
3235444
3933002
3235477
AMC
1987-89
258 4.2 3.75 L-6 2.06" Crank Neck, Spec. if Alum. or Plastic Valve Cover, 1/2" Head Bolts
3235444
3661
3727
zarnold likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 24 Old 05-08-2019, 08:25 PM
StrippedTorx
StrippedTorx's Avatar
Does it have a carb
StrippedTorx is offline
post #14 of 24 Old 05-08-2019, 10:45 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
One will run and idle great and not leak, the other pukes oil and emits blue smoke. Lol. Good luck.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #15 of 24 Old 05-09-2019, 09:28 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Originally Posted by StrippedTorx View Post
Does it have a carb
A 4.0 can have/ run a carb too. They didn't come that way, but can relatively (and easily) be converted to run a carb
Hoss
7/16th Head Bolt for 4.0 head on 4.2? Per ARP...is that right? Vernors YJ Wrangler Technical Forum 2 05-07-2019 07:59 PM
4.2 to 4.0 swap? Robbiescd YJ Wrangler Technical Forum 11 05-03-2019 11:39 AM
Stock 4.0 HO EFI vs 4.2 with 4.0 Head and stock EFI lebowski94 Jeep CJ Forum 27 11-14-2018 11:54 AM
4.0 Engine Swap Complete trwedgn YJ Wrangler Technical Forum 1 03-11-2018 08:20 AM
Whats the difference between 4.0 and 4.2 oil dipsticks? olbluejeep Jeep CJ Forum 3 03-01-2018 09:04 PM
