JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   How to tell difference between 4.2 and 4.0 engines? (https://www.jeepforum.com/forum/f8/how-tell-difference-between-4-2-4-0-engines-4355061/)
Joncure 05-08-2019 01:36 PM
I'm wondering if there are any clear ways to visually tell the difference between the 4.2 and the 4.0 engines. I'm trying to figure out which I have in my 85 CJ7. I'm about 97% sure its an engine from an 88 wrangler, since it takes an 88 model oil filter (found that out the hard way!) and valve cover gasket.
The valve cover doesn't say 4.2 or anything else on it like I've seen on others. I also know its not the original engine since the PO told me that the spare engine that came with it was the original.
Joncure 05-08-2019 02:12 PM
One difference I know is that the valve cover on my engine has a lot of bolts (not sure the # right now, but in the teens), and the oil filter is the 20mm metric thread type. I think those suggest the 4.0
Fourtrail 05-08-2019 02:19 PM
Casting number on the block is the best. On a machined flat on the right side of the block between #2 and #3 cylinders. You may also need the head casting number if it has been changed from stock.
87MJTim 05-08-2019 03:07 PM
If I am not mistaken, the 88 YJ still had a 4.2. The 4.0 wasnít available in the YJ until 91.
So, if the engine came from an 88, itís a 4.2
JoonHoss 05-08-2019 03:11 PM
This.
The 4.2 (258) was made until 1990
Hoss
Joncure 05-08-2019 03:16 PM
Disclaimer: Now I'm quoting here from Wikipedia but...Ö.
"The 4.0 engine, which was introduced in 1986 for the 1987 model year, was a further evolution of AMC's 258 six.[16] It had a 3.875 in (98.4 mm) bore and a 3.414 in (86.7 mm) stroke giving it a displacement of 241.6 cu in (4.0 L).[17] Connecting rod length was 6.125" - similar to the discontinued 199 which was phased out in 1970."
LJameson 05-08-2019 03:19 PM
I also think all 4.2s have a spot for a fuel pump, while the 4.0 never did.
Joncure 05-08-2019 03:27 PM
So where would the fuel pump be located for the 4.0? My engine has it on the block in front of the distributer.
JoonHoss 05-08-2019 03:49 PM
Originally Posted by Joncure (Post 40612483)
Disclaimer: Now I'm quoting here from Wikipedia but...….
Nope!
Wikipedia the YJ, 4.2 was used until 1990
Now then, if it was out of a Cherokee or Comanche, that's a different story. Those motors would have had like 15 bolts holding down the aluminum valve cover IIRC.
Hoss
CSP 05-08-2019 07:58 PM
"The 4.0 engine, which was introduced in 1986 for the 1987 model year,"
The missing part of that statement relevant to the OP, is that the 4.0 was only found in the Cherokee and Comanche until 1991 when it made its debut in the YJ.
87MJTim 05-08-2019 08:05 PM
The fuel pump on the 4.0 is in the gas tank. The fuel injected engine requires much high pressure than the carb engine. The FI pump pushes the fuel to the injectors; the carb engine sucks the fuel like through a straw.
BagusJeep 05-08-2019 08:17 PM
if you look on the inlet manifold near the front you should find a round date stamp, this was the casting date of the manifold.
You should also find on the engine block the casting number.
AMC
1981-85
258 4.2 3.75 L-6 7/16" Head Bolts
3235444
3933000
3224480
3241656
3235477
AMC
1986
258 4.2 3.75 L-6 1/2" Head Bolts
3235444
3933002
3235477
AMC
1987-89
258 4.2 3.75 L-6 2.06" Crank Neck, Spec. if Alum. or Plastic Valve Cover, 1/2" Head Bolts
3235444
3661
3727
StrippedTorx 05-08-2019 08:25 PM
Does it have a carb
RARECJ8 05-08-2019 10:45 PM
One will run and idle great and not leak, the other pukes oil and emits blue smoke. Lol. Good luck.
JoonHoss 05-09-2019 09:28 AM
Originally Posted by StrippedTorx (Post 40612831)
Does it have a carb
A 4.0 can have/ run a carb too. They didn't come that way, but can relatively (and easily) be converted to run a carb
Hoss
The time now is 05:51 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
