How to place hard door vent window seal ? - JeepForum.com
post #1 of 9 Old 10-10-2019, 03:24 AM Thread Starter
agear
I got new seals for the vent windows on my 84 cj7s hard doors. Does anybody know how to replace those ? Can they be done with the door fully assembled ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 9 Old 10-10-2019, 05:49 AM
Hoover7
Hoover7's Avatar
Some disassembly will be required to replace those seals. Here's a great write up on repairing doors. Hope it helps-
https://www.jeepforum.com/forum/f8/g...ml#post8290416
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #3 of 9 Old 10-10-2019, 12:54 PM Thread Starter
agear
https://www.jeepforum.com/forum/f8/ga...ml#post8290416
Hoov
I didnt see it there when I looked . Have you ever done it ?
agear is offline
post #4 of 9 Old 10-10-2019, 01:16 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I've replace the vent window seals on my doors. I've kinda forgotten the details, but I don't recall it being too difficult.
What problems are you having?
Matt
Matt1981CJ7 is online now
post #5 of 9 Old 10-10-2019, 01:49 PM Thread Starter
agear
Matt
I haven't started yet. I just didnt want to take them off and run into any trouble, like needing a special tool .....
I got it started. I see a 1/2 inch nut and spring on one end . Maybe it will come out just removing that.
agear is offline
post #6 of 9 Old 10-10-2019, 02:01 PM
abark
I'm in the middle of doing this right now and have run into two issues. First, that nut is rusted to the bolt so I broke the connection at the vent window frame. Once I get it loose I will JB weld it back in to see if that works. The second issue is getting the new seal to seat in the fairly flimsy frame without distorting the frame. Still working on that one.
abark is offline
post #7 of 9 Old 10-11-2019, 03:28 AM Thread Starter
agear
Yikes ! Thank you
agear is offline
post #8 of 9 Old 10-11-2019, 04:08 PM Thread Starter
agear
Yeah my bottom stud with the spring snapped too . I still have enough stud to where I can wedge something in between the lip of the stud and the frame. Some e clips would work good here. I'm wondering if I should just leave my other vent window alone.
agear is offline
post #9 of 9 Old 10-14-2019, 01:05 PM Thread Starter
agear
Update I ended up drilling the flat part of the stud and putting a cotter pin through it to keep it up in the window
agear is offline
