How much Por 15 for frame - JeepForum.com
post #1 of 4 Old 08-26-2009, 12:46 PM Thread Starter
seagrave
Am getting ready to prep my frame. Was wondering for those that used Por 15 how much did you use for the frame?
seagrave is offline
post #2 of 4 Old 08-26-2009, 12:52 PM
nshefbuch
1982 CJ7
did mine a few years ago
bought a gallon and only used like maybe 1/4 or LESS. more towards less
take care of the can and the paint will last forever. i've stored the rest in another can and paint is still like brand new.
i've coated three frames now and still have about half a gallon left.
best product i've ever bought, worth the money
nshefbuch is offline
post #3 of 4 Old 08-26-2009, 12:55 PM
Coiz
Coiz's Avatar
1979 CJ7
A pint should be enough to cover just the frame with at least two coats. I used a quart and got three coats on the frame, axles, springs and other miscellaneous parts.
Mike
Coiz is offline
post #4 of 4 Old 08-27-2009, 08:43 AM
mcmud
1983 CJ8
Being rather particular...I use two colors. First coat is not so difficult to achieve the 6 mil thick cover that is recommended but the second is. Say if I use silver, grey or white 1st and then finish with black. It will allow you to better see that proper coating is applied. A pint of each will be sufficient, and have some left over for another task. Then remember to top coat with Chassis Coat Black.
I store these products with a layer of plastic shopping bag between lid and can...in the fridge.
mcmud is offline
back half of cj5 frame to replace rotted cj7 frame? jedsled Jeep CJ Forum 8 05-30-2011 06:11 AM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 09:44 PM
Stock Frame Vs. Mandrel Bent Frame HeepToJeep Jeep CJ Forum 8 05-10-2009 07:28 AM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 11:44 PM
Rear shackle to frame bolts, how do you get in the frame? Blthomas Jeep CJ Forum 5 02-19-2009 08:26 PM
