how much antifreeze? 50/50? - JeepForum.com
 8Likes
post #1 of 35 Old 10-11-2009, 11:27 PM Thread Starter
shok47
1983 CJ7
when I did the timing chain on my 83 cj7 258, I drained the radiator and did not keep the stuff. I realized this stuff is more complicated than just filling it up. I bought some peak 50/50 antifreeze and coolant and put in about 16 cups of 50/50. should I keep doing that till it fills?? I should be checking the temps too but my gauge is not working.
shok47 is offline
post #2 of 35 Old 10-12-2009, 07:17 PM
Killian
Killian's Avatar
Haynes says that it holds 10.5 quarts - at 50/50 that would be about a gallon and a half and then the rest de-ionized water.
It is hard enough to remember my opinions, without also remembering my reasons for them!
Friedrich Nietzsche
Killian is offline
post #3 of 35 Old 10-12-2009, 07:22 PM
WayneMeuir
1980 CJ5
I thought it was supposed to be mixed straight 50/50. If that is corect, why would you add anything except more of the 50/50 Premix?
Wayne
pedal2themetai likes this.
WayneMeuir is offline
post #4 of 35 Old 10-12-2009, 07:26 PM
ksheffer08
1981 CJ7
I think 50/50 is more expensive per ounce than straigth coolant. and if your in a climate that never sees cold weather, a higher water content will be more effective. the ethylene glycol reduces corrosion, and prevents freezing so many people will run 70/30 or something.
ksheffer08 is offline
post #5 of 35 Old 10-12-2009, 08:03 PM Thread Starter
shok47
1983 CJ7
Im in MA so I see some cold, nothing much below 0. I been putting 50/50 peak mix. I my heater is not working right now. should run it??
shok47 is offline
post #6 of 35 Old 10-13-2009, 06:27 AM
Killian
Killian's Avatar
No. I meant it to be that if you mix your own 50/50 blend, you would need to have a gallon and a half of antifreeze with as much de-ionized water (~12quarts).
If you buy 50/50 premixed, then obviously you need 3 gallons to make sure you have enough to fill the radiator (with some left over for the neighbors loud dog). I would recommend a 50/50 blend either way.
btw... I love dogs
Friedrich Nietzsche
Killian is offline
post #7 of 35 Old 07-04-2020, 06:18 AM
Raleighwood007
Raleighwood007's Avatar
Don’t use Deionized water even if the bottle on coolant or antifreeze says to do so. Always use distilled water.
Deionized water is water that is acidic from the H+ ions. The PH acidic and as a result attempts to correct this by pulling metal from the radiator (it will corrode the water blocks to get
its ions back) to correct the imbalance. While the significance of the PH isn't anything to be concerned with right away, over time this can have an effect on a radiator. Using deionized water a few times really isn't a big deal, but being left in for an extended period of time can have harmful effects.
Distilled water is distilled water. Neutral PH and no mater how many times it is steamed, it is still distilled water. This is why all race orgs say to use "distilled" water only vice deionized OR distilled water.
Raleighwood007 is offline
post #8 of 35 Old 07-04-2020, 06:48 AM
jay-h
50/50 is slightly more expensive (won't break the bank) but eliminates all need to calculate when adding, and all need to find properly purified water. Modern antifreeze is also anti-boil so it's really advisable to stay around 50/50 even in warm climates
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #9 of 35 Old 07-04-2020, 06:56 AM
jay-h
Originally Posted by Raleighwood007 View Post
Deionized water is water that is acidic from the H+ ions. The PH acidic and as a result attempts to co.
Yes this is correct. Requote for emphasis.
I worked in engineering for a valve manufacturer. Valves for DI water were typically nonmetallic. Even stainless steel was attacked.
JeepRonibo likes this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #10 of 35 Old 07-04-2020, 01:21 PM
StoneTower
I use the concentrate because it is cheaper. I buy the distilled water at Walmart or some other discount place for about 89 cents per gallon. I mix up 2 gallons of 50/50 and start with that. I then use a red Solo cup (that is marked antifreeze with a Sharpie) and add 1 cup of antifreeze and then one cup of distilled water until the system is topped off.
50/50 is generally what is recommended for most applications. Pure water cools better than water with antifreeze in it. The heat is able to transfer to the radiator better from pure water than a water antifreeze mix. If you live in a really hot climate, and never go to a cold climate, you can run less antifreeze in the mix. Antifreeze has some lubricating properties for the water pump and it also prevents corrosion in the cooling system.
StoneTower is offline
post #11 of 35 Old 07-04-2020, 08:17 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I use premix to prevent corrosion and because it is easy to top up. We do not have cold here and the exact ratio is not important to me rather than stopping the Jeep from rusting from the inside out through the core plugs.
As antifreeze tends to leak out of Jeeps I do not buy the epensive ones, the OATs and hybrids, just old fashioned IAT is fine. They get checked every few weeks for colour changes and level.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 35 Old 07-04-2020, 10:51 PM
StoneTower
What is the cause of the leak? The cooling system is one of the fluid systems that does not leak on my Jeep. The antifreeze stays in until I decide to drain it.
With the "Solo cup method" you can mix as much or as little as you need. If you only need a little, you use a 1/4 cup of antifreeze and a 1/4 cup distilled water.
FYT...distilled water is what your wife is suppose to use in the steam iron. We always have some around. When I flush my 7.3 diesel in my truck, I buy 15 gallons at a time.
post #13 of 35 Old 07-05-2020, 07:29 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Mixing your own AF is not only cheaper, but gives you the chance to change you mixture.
Easiest way is to dump half a gallon of AF into the radiator, then refill the other half with water and continue filling the cooling system (50/50). Once you empty the first jug, you can use it for mixing the next batch.
Don't mix heavier than 50/50 if you live in hot weather.
You can go 70/30 in extreme cold temps.
You can monitor your mix with a cheap tester.
Don't forget there are numerous additives that will increase heat transfer and reduce deposits and cavitation.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #14 of 35 Old 07-05-2020, 07:48 AM
bob4703
1974 CJ5
In this corner of God's green earth we don't use antifreeze. We use coolant!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #15 of 35 Old 07-05-2020, 07:57 AM
Submariner
Submariner's Avatar
1976 CJ5
You need to fill your system with the MIX. Do not add water. It already has water added for your convenience.
Something to think about in the future. When buying 50/50 mix, you are buying WATER. Hmmmm.
Buy regular antifreeze is the stuff you add water to to make sure you have the correct amount. Get the little guage/meter/tool to check the level of antifreeze you have in your rig and adjust it to your needs. use something like this, ABN Deluxe Antifreeze and Coolant Tester Hydrometer Tester Automotive Antifreeze Tester for Ethylene Glycol Coolant
Submariner and you wonder why I am this way LOL
Submariner is offline
how much antifreeze? 50/50? shok47 Jeep CJ Forum 6 10-12-2009 02:04 PM
Antifreeze Everywhere Big Block Jeep CJ Forum 6 01-26-2009 06:41 PM
Antifreeze in the oil Jeepdude84 Jeep CJ Forum 9 09-29-2008 04:28 PM
antifreeze/coolant GeauxJeep Jeep CJ Forum 5 03-12-2008 09:34 AM
Need help with 304 (antifreeze leak) zeke01 Jeep CJ Forum 4 03-01-2007 06:17 AM
