Horn not working - JeepForum.com
 6Likes
  • 1 Post By jeepster258
  • 2 Post By John Strenk
  • 1 Post By CJ7-Tim
  • 1 Post By Hoover7
  • 1 Post By Hotrodssnova
post #1 of 9 Old 12-09-2018, 06:18 PM Thread Starter
clarkg
1980 CJ7
Horn not working
I can't get my horn to work.
I removed the horn and connected a test light in its place. When I pressed the steering wheel horn button the test light came on, so I know I am getting voltage to the end of the wire that connects to the horn.
I connected a meter from a spot on the horn frame to the horn positive terminal. When I pressed the horn button on the steering wheel, I got 12.5V. When I switched the meter over to ohms I got 58 ohms.
This is the second horn I have tried. The first one I tried read open circuit with the ohm meter.
Do I just have two bad horns? These are both used horns. I would have thought if I could measure resistance through the horn it would probably be good.
What is inside a horn? Anything serviceable?
clarkg is offline
post #2 of 9 Old 12-09-2018, 06:23 PM
jeepster258
Try connecting the horn straight to the battery and see if it works. That would determine if the problem is the horn or the circuit.
trailhead2004 likes this.
jeepster258 is offline
post #3 of 9 Old 12-09-2018, 08:51 PM Thread Starter
clarkg
1980 CJ7
Thanks for the suggestion. I already did that and the horn did not work.
clarkg is offline
post #4 of 9 Old 12-09-2018, 09:05 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Did you check the ground? You can have 12,5V and a perfect horn but a bad ground will stop it. CJs are notorious for this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 9 Old 12-09-2018, 09:31 PM Thread Starter
clarkg
1980 CJ7
You are correct that grounds are usually a problem. I think my problem is the horn.
Is there any way to repair a horn or do you just have to replace it? What is inside?
clarkg is offline
post #6 of 9 Old 12-10-2018, 04:53 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Just a coil and a contact.
thumperjohn151 and clarkg like this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #7 of 9 Old 12-10-2018, 05:50 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Horns usually get rusty inside and they are not worth the time/effort to repair. Stop by any auto parts store, Farm and Fleet, Walmart type store or junkyard and pick up some replacements.
clarkg likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #8 of 9 Old 12-10-2018, 08:25 AM
Hoover7
Hoover7's Avatar
I recently picked up this set, and have been exceptionally pleased - nice deep sound and plenty loud - not to mention inexpensive. The only snag was that I needed to splice in a second connector on the existing harness for the second horn. Although I hate modifying the harness, this has been a good upgrade IMO.
https://www.summitracing.com/parts/hla-007424801
Hoov
clarkg likes this.
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #9 of 9 Old 12-10-2018, 11:22 AM
Hotrodssnova
Hotrodssnova's Avatar
1981 CJ5
I just tested my dead horn last night as well. Bought a new one at the parts store for 17.00. Still in the package, but installing tonight.
clarkg likes this.
Hotrodssnova is offline
